Question about SanDisk Sansa e250 MP3 Player
I need help with my Sansa Sandisk e250R
Well Ive had it since last Christmas and recently its been acting strangely. Everytime i turn it on it says: Not enough room for Music DB. Please free 6 MB. I tried to free some room off there but i have 508 MB of free space. And I tried to fix it with a downloadable file and now it says "Please free 4MB" Im not sure how downloading the program freed up 2 MB but it still wont let me access my music
  • Crimson Karma Apr 27, 2007
    That didnt help. Will someone please help me?
  • Anonymous Jan 31, 2009
    Is there a way to fix this problem WITHOUT formatting the device? I have a ton of audio recordings saved on there that I sort of would miss.
What if it says need80 freed up and it doesn't show up when you click computer
Posted on May 25, 2012
OMG Guest you just helped me with a problem I've been faced with forever
THANK YOU
Posted on May 11, 2008
To fix it, format your Sansa. I had the exact problem. Plug it in, then in "My Computer" right click its icon and hit format. Do not select quick format. Then it will be fixed.
Posted on May 16, 2007
Need software for Sansa e250R
http://www.sandisk.com/sandisk-support/driver-download-wizard
Jul 28, 2010 | SanDisk Sansa e250 MP3 Player
Sansa e250R 2GB got hanged.
where is service center.. in chennai
Sep 23, 2008 | SanDisk Sansa c140 MP3 Player
SANSA e250r ??
my sandisk 250will not change songs it is stuck o #1 icannot move it up or down
May 03, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250R firmware
hey yeah i had the same problem with my sansa e250r. when mine does that i
1. turn it off
2. put the hold button on
3. hold down the rec. button
4. turn it back on
that will get you into recovery mode connect your data cable once you have hooked it up to your computer open my computer and you should see a 16mb drive there instead of your normal mp3.
once you see that open it up.
now go to http://www.sandisk.com/Retail/Default.aspx?CatID=1449 scroll down and click on download firmware link
once you have downloaded that file unzip it and copy the file that is inside to the 16mb drive that you opened up in my computer.
once you have done all the above,,
1. take the hold button off
2. disconnect the data cable
3. wait for it to reboot.
if the above dosent work you might wanna take it to the dealer.
hopefully this works for you as well as it did me. good luck
Mar 04, 2008 | SanDisk Sansa e250 MP3 Player
Sansa help
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Nov 27, 2007 | SanDisk Sansa m250 MP3 Player
4 GB micro sd and the Sandisk Sansa e250R...
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
Sansa help
Change the USB mode by going onto your MP3 and go to settings change it from MTB to the other mode then try to coneect it again.
May 25, 2007 | SanDisk Sansa e250 MP3 Player
I can't put songs on my Sansa Sandisk e250....
Hey to get music onto the Sansa e250R you have to plug the Sansa into the computer. Next go to mycomputer. Then onen ethier sansa or Removable Disk(F:). Then take the songs you want and drag them on to the white space under photos and vidos and all that other files. DO NOT PUT IT IN A FILE.
Jan 27, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
185 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
