Question about Epson Perfection 4990 Flatbed Scanner
Scanner wont scan transparencies properly
I have the Epson Perfection 4990 Photo scanner. It scans reflective document table material fine, but just recently it has been having problems scanning transparent material. The preview and scan alike show up like digital woodgrain, fading to white. It appears if the upper scan light is stuck or somthing? Who knows. It is also scanning very slowly in this mode. A new development. Any ideas would be greatly appreciated.
  • 2 more comments
  • reddirtrose Mar 11, 2008
    I have an Epson perfection photo 4870 and it has suddenly stopped giving me the option of scanning film. I couldn't find my installation cd, but I downloaded the drivers from Epson and reinstalled the software. no difference, no film.
  • lbailey Jun 27, 2008
    I have the exact same problemas manfred_lou. My 4990 just started dioing this today. It worked fine yesterday and in the past, so I don't think it has anything to do with Vista (I have been using Vista for a year). Everything manfred_lou wrote is exactly what's happening.
  • MuKatie2 Jul 04, 2008
    Epson Perfection 4990 Flatbed Scanner worked beautifully in 2005 when first purchased. It has been awhile since I've needed to scan negatives. A couple of months ago, I made an attempt, and was unable to do so. Since we were leaving on a trip, I did not take any steps to solve the problem. Today, I attempted each of the Online Support suggestions, and even uninstalled/reinstalled the software. Updated drivers were downloaded and installed, as well. Result: Unable to scan ANY NEGATIVES. The "Reflective" document type still works fine. Numerous attempts to send an email to Technical Support failed. The message screen continued to open to say that this email address is already in the system. Duh! it should be since the product had been registered online. What's with Epson?
    Does Epson expects me to BUY A NEW SCANNER?
    I'm opened to any steps that will lead to the capability of scanning negatives. Anyone able to help?
  • bopucelj Sep 27, 2008
    I have the same problem and solution 2 doesn't work at all, have anybody luck with solution?
    Problem Solver:
  • 5 Answers
I have the same problem with my 4990. This began when I moved to a new computer running Vista. I've updated all drivers to the latest version including Epson Scan for Vista but the only thing the 4990 "sees" is reflective documents. Negatives are not recognized at all. I know this is probably a different problem from what you are having but the effect is the same.
Posted on Jul 03, 2007
    Novelist:
  • 110 Answers
On the 4990, make sure that you have unlocked the lid of the scanner. The lock is located underneath the lid.
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Posted on Aug 22, 2008
Hey everyone,
I was having the same issues, but solved it by:
1) making sure the emulsion side of the film was facing up, toward the light from the top of the scanner.
AND
2) make sure the film is loaded into the film holder properly. Click your window's "Help" button, then "Troubleshooting," then, "Film Scanning Problems" to see the correct way to load your film. The tabbed part of the plastic film holder needs to be at the bottom left-hand corner for it to read the image correctly.
Purpleshirt
Posted on Dec 15, 2008
Hi, and thanks for your help. sad little noises on start up
Hello b3toed - sorry you're having problems; let's see what can be done.
First, there is a transportation lock on the scanner. (If you have a manual, it will tell you more about this.) Make sure it is unlocked.
Second, test the connection between the scanner and your computer -- make sure it's snug (well connected).
Third, if you were scanning a transparency just before this happened, make sure you've removed the reflective document mat.
After checking these things, turn it off - pause - then turn it back on. Best wishes for good results! -- ambssdor --
Jan 14, 2010 | Epson Perfection 2450 Photo Flatbed...
My computer and scanner intermittently can't communicate. I am mainly scanning in photo transparencies at the moment - four at a time, using the "professional" setting in the software. Typically it...
I had that problem. I was using the USB ports that came with my computer. I added an IDE USB card in my computer. I haven't had a problem since.
JNHV23
Jan 10, 2010 | Epson Perfection 3170 Flatbed Scanner
Document Type "Film" greyed out
Close Epson Scan, unplug the TPU, plug it in, turn off the scanner, turn it on, reopen Epson Scan.
Feb 16, 2009 | Epson Perfection 4870 PRO Flatbed Scanner
Need a document feeder for 4990 scanner
I don't believe it is possible to add a paper feed to this scanner. The only hopper fed scanner of which I'm aware is the Kodak s1220.
Jeff Underwood 1Scan.co.uk
Feb 13, 2009 | Epson Perfection 4990 Flatbed Scanner
4990 scanner
Nothing is wrong if your scan turns out good
Jan 22, 2008 | Epson Perfection 4990 Flatbed Scanner
Epson 3490 does not find the slide I put in the correctly positioned provided frame
Dec 28, 2007 | Epson Perfection 3490 PHOTO Flatbed...
Dull negatives
are you using the a transparency adapter on the negatives?
Oct 16, 2007 | Epson Perfection 3200 Photo Flatbed...
Epson perfection 4990 photo scanner
Sep 25, 2007 | Epson Perfection 4990 Flatbed Scanner
Microsft Vista doesn't support 4990 negaives scanning
try using a third party scanning solution EPSON is known not to keep up their drivers so many third party solutions have popped up. I like one called vuescan http://www.hamrick.com/ it works for MAC and PC and is not very expensive
Jul 03, 2007 | Epson Perfection 4990 Flatbed Scanner
Epson Perfection 4990 Flatbed Scanner Logo
729 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
