Question about HP LaserJet 2820 Printer
Hp 2820 scanner error 5
I have this problem and can't fix it after i repair a PCB on the scaner unit witch gives high voltage on the lamp,after that i change a lent cables!S0 the error remains !Pls don't tell me to contact the srvice couse i'm working at one !So, if u can give me another solution pls!i'm trying to fix it from 1 week already ! tnx !
  • 3 Answers
I'm not sure if this will help or if this is the same as i had but I had been given A laserjet 2820 which keep't coing up scanner error 5 the chap that had it before me contacted hp service & was told to replace scanner unit which he did & it was ok for a while like 6 months & started then started again.
The problem he had was powered up ok till it came to scanner bulb warming up the scanner unit moves back & forth then try's to escape through the right hand side of case.
This is because it cant see the home position white strip under the scanner glass all you have to do is remove top section of the scanner unit complete with scanner glass & clean the under part of the scanner glass the white strip is located under the wide gray panel as you look down on the scanner glass with the lid up. hope this is of some use. my unit has been working for some time now
Posted on Jan 01, 2009
I ran into this also. Kevin's solutions is one of many I have found. I also have found to simply check the small connectors on the scan bar as some times they vibrate loose over time. Remove them and re-seat them gently, being careful not to force them.
Posted on Mar 19, 2009
Printing blank copies
1. No transfer charging. A. The connector terminals of the high-voltage PCB make poor contact. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. B. Defective engine PCB. Replace the engine PCB and check for correct operation. C. Defective high-voltage PCB. Replace the high voltage PCB and check for correct operation. 2. No LSU laser is output. A. Defective laser scanner unit. Replace the laser scanner unit (see page 1-6-29). B. Defective main PCB. Replace the main PCB and check for correct operation. 3. No developing bias is output. A. The connector terminals of the high-voltage PCB make poor contact. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. B. Defective engine PCB. Replace the engine PCB and check for correct operation. C. Defective high-voltage PCB. Replace the high voltage PCB and check for correct operation.
Jun 09, 2015 | Kyocera Mita Drum Cleaning Blade Km 1620...
Erroe cod
=High density for the target at patch detection=
1. Clean the scanner's window.
2. Use your hand to check if the shutter of the Registration Patch Sensor Unit can be open.
3. Check if the window of the Patch Sensor (UN43/ UN44) is soiled.
4. Check scar on the ITB.
5. Check movement of the Registration Shutter Solenoid (SL02).COPIER > FUNCTION > PART-CHK > SL to move SL02
6. Check the harness/connector between the DC Controller PCB (UN09/J12) and the Patch Sensors (UN43/J4007, UN44, J4006).
7.Replace the Drum Unit (M)
8.Replace the Registration Patch Sensor Unit
9 Replace the ITB Unit.
10. Check conduction of the fuses (FU5, FU8) in the DC Controller PCB (UN09).
11. Replace the Primary Transfer High Voltage PCB (UN04)
12. Replace the Developing High Voltage PCB (UN07)
13. Replace the Primary Charging High Voltage PCB (UN06)
14. Replace the Auxiliary High Voltage PCB (UN08)
15. Replace the Replace the DC Controller PCB (UN09)
Apr 26, 2014 | Canon for IMAGERUNNER C2020 C2050 C2058...
HP Laserjet M2727nf Mfp Printer Scanner Error 8
The HP M2727 has a known issue with the scanner error 8 and bad formatters. HP has extended the warranties on this product. I suggest you contact them directly and they will most likely exchange the unit.
Nov 08, 2011 | HP Laserjet M2727nf Multifunction Printer
Officejet G95 scaner falier
Hi its normal one of two things 1 the scanner unit is being stopped or snagged as it travels
to test this lift the lid switch on an look to see if it is obstructed.
2 the lamp in the scanner unit is not putting out enough light, the machine monitors the light out put and if insufficient it gives a scanner error.
I'm sorry to say the the cost of a scanner unit normal puts the machine beyond economic repair
But google hp partsurfer this will get you parts
good luck Ian
Mar 25, 2011 | HP OfficeJet G95 InkJet Printer
When we make copies they come out really, really dark. We have the setting as light as it will go. How can we resolve this?
  • try this when a dark image of original.
  • clean the scanner cavity,lenses,mirrors,scaner lamp reflector
  • adjust/increase scaning lamp voltage (on lamp regulater pcb)
  • clean/adjust hight of charging corona wire
  • adjust bais voltage in servce mode (add function then both key2 and 8 saimantaniously then add funtion)
  • adjust/replace cleaning blade
  • replace scanner lamp
  • Try this when zed black copy came out
  • check scanner lamp is working
  • check developing unit connection and contacts
  • check drum earthing contact
Jan 06, 2011 | Canon NP 6230 Copier
"scanner error 5 turn of then on" reads on the display screen
Sorry but I have a bad news. Scanner error 5 or 8 means that the scanner lamp is not able to move and if it does it cannot go all the way. The printer need service, probably a new scanner. The repair might be too complicated and expensive (over $250) I suggest to get a new one. HP can provide a deal to recycle the unit and give you a credit, maybe not a lot but its something.
Aug 30, 2010 | HP LaserJet 2840 Printer
Scanner error 5 or 6 in hp 2840 printer clean glass /lamp but nort working
Replace the Scanner assey, If it's same, Replace the formatter board.
Jan 19, 2010 | HP LaserJet 2820 Printer
Scanner error 5
The problem is in the scanner section.There is too mush ash on the mirrors and scanner lamp.You can fix it just like disassembly the printer and pull out the scanner section.Open it cover and inside you'll see the mirrors.Clean the ash from mirrors using cloth which leaves no hairs.
WARNING! If you don't have a technical skills don't try to do anything.
If this not help you need to replace the scanner section.
Nov 18, 2009 | HP LaserJet 2820 Printer
HP Printer Color LaserJet 2840 Printer makes clicking noise and shows on display: Scanner bulb warming up - scanner error 5 Turn off then on but this does not work. Is it mechanical problem or software...
I Have A HP Laserjet 2820 on power up went through to scanner bulb warming up then made a clicking noise comming from scanner unit it was trying to escape the case. if this is the same as yours the problem is that the scanner unit can't find the home position strip mounted betweent the gray case wide piece right hand side as you look down on scanner unit with lid up & the top of the scanner glass inside the scanner unit to get to it you must remove top section of the scanner unit & cleean underside of scanner glass please E-mail me if you want full instruction.
Oct 13, 2008 | HP LaserJet 2820 Printer
Minolta CF900 error C0660
There should be a lamp regulator PCB check the fuse on it. Also, if you move the scanner out of HP will it find HP again? Also, how offten does it show up scines the last time?
Feb 20, 2008 | Office Equipment & Supplies
HP LaserJet 2820 Printer Logo
3,344 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
