Question about Canon MX700 Office All-In-One InkJet Printer
MX700 Canon Printer
Every time I switch the printer on I get an error 5200 code.
  • Anonymous Jan 25, 2009
    EVERYTIME I TURN ON PEINTER ERROR 5200 COMES ON
  • Thomas F. Schneider May 11, 2010
    Two replys taken for another site:
    In many earlier-model Canon bubble-jets, Error 5200 indicated an error with the printhead. Not sure if the error codes are the same on your printer.
    I had the same problem. I disconnected the power and reconnected it and everything worked fine.
    President:
  • 8,637 Answers
Normal 0 This doesn’t help fix all printers because each situation is different and in most cases we don’t have enough information to determine the fix. So hope this will provide some help.
Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
  • skibdr Oct 17, 2010
    The problem seems to be the printhead is overheating (b/c ink is low, I guess ink helps cool the head). If you're like me, you probably tried to squeeze the last print out, after the low-ink warning had been on for some time. Well, now we've screwed up the unit by running it dry on ink.
    Be sure you have full ink. Take out your ink (cover it with tape to prevent drying). Take the printhead out. Clean it under HOT HOT HOT water until ink STOPS flowing out. Dry it next to a fan (overnight if you live in a humid climate). Reinstall the print head. Reinstall ink cartridges (make sure they have ink in them). While holding the power button, plug the unit back in. Simultaneously press the reset button twice to return the unit to factory settings. Give it a second. Then, unplug it. Then, plug it back in. Wa-La. It should work fine.
    Never let the ink run dry. That's the lesson I learned!
Canon troubleshooting
Hi Nolan,
Error code 5200 indicates that print head temperature error occurs. This error usually occurs in case of ink low or third party or refill ink usage.
I hope the following link will answer your question clearly. :)
Canon Printer Error 5200
Jan 11, 2014 | Office Equipment & Supplies
Error 5200 of canon pixma mx328. i already tried turning it on and off several times and even got the cartridges and returned them back but still when i tried to print a page error 5200 still...
Error no 5200 is caused by its temperature high.. to solve your problem follow the instruction given below::
1. Turn Off printer, cable power still plug in.
2. Press Stop/Reset button, don't release the button.
3. Press Power button by holding without release and than release Stop/Reset Button.
4. Press Stop/Reset button two times (2x) now release the Power Button.
5. Wait until service mode to zero (0).
6. Turn off the Printer, cable power still plug in.
7. Press Stop/Reset button, don't release it.
8. Press Power button don't release & than release Stop/Release button.
9. Press Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off printer, and loose cable power, wait for one (1) minute.
11. Connect cable power, turn on printer again, now this printer ready to use.
Aug 23, 2011 | Canon MX300 Office All-In-One Printer
My printer canon mx700 has error 5200, what I have to do to fix it. Thanks.
This is a printhead overheat error but both the printhead and main logic board should be changed together and it would cost over 3/4 of the price of a new machine. So i would buy another machine rather than go for a repair.
Srri.
Jun 19, 2011 | Canon PIXMA MX700 All-In-One InkJet...
What does an error 5200 mean?
(1) With the printer turned on, unplug it
(2)Open the top and bring the ink cartridge holder to the middle
(3)Raise the gray bar and remove the print head assembly with the cartridges in it
(4) Lower the gray bar with the head missing and close the top with the head out
(5) Restore the power,wait til the printer wakes up
(6) It will tell you to put in the cartridges
(7) Restore the print head, close the top and the printer should resume working.....
it is a printer head error and some solved it that way ..after you do that it will resume the function and work ..
_________________
Jun 01, 2010 | Canon PIXMA MX700 All-In-One InkJet...
What does 6A60 error message indicate and how do I resolve on my Canon MX700 all in one machine.
6A60 error is an APP (Application Printer) position error. It means that an error has occurred when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Thank you!
Nov 02, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Printer error code 5100 I had a business card paper jam in my Canon MX700. I removed the back panel & was able to clear the obstruction, but I keep getting the Error code: 5100. I've tried turning the...
Hi You can Try
Same old Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Feb 16, 2009 | Canon MX700 Office All-In-One InkJet...
I560 error code 5200
Orange 10 5200 Replace the BJ Cartridge(Printhead)
Cartridge Overheat 8 x
7 times in orange/green 5200 Cause: The print head's temperature is abnormally high tnx and good day!!!!!
Apr 07, 2008 | Canon BubbleJet i560 InkJet Printer
Canon MX700 Office All-In-One InkJet Printer Logo
928 people viewed this question
old marine
old marine
