Question about Radio Shack Pro-96 Scanner
Pro-96 scanner My unit has been in repair 3 times for the same problem. the last service call they actually replaced the system board. Problem: scanner will not work until it is hot. After leaving unit on for about an hour, I am finally able to use. Any thoughts?
  • 139 Answers
Check the Plug in where the Harness Comes into Look for Broken Conns,,,,
Posted on Jul 20, 2007
Problem f110
from service handbook:
[F110] Communication error between system CPU and scanner CPU
[F111] Scanner response abnormality
(1) Check if the harness connecting the SYS board and SLG board is disconnected or open circuited.
(2) Check the version of the system ROM on the SYS board.
(3) Check the version of the scanner ROM version on the SLG board.
(4) Replace the SYS board.
(5) Replace the SLG board.
from me:
Try power off, then press and hold 1 + 3 + * and power on
after
power off again, then press and hold 1 + 3 + # and power on
Apr 13, 2016 | Toshiba e-Studio 350 Copier
What is 811 error?
You cannot repair this error easily. Most times its the main board that has the problem but its more than likely to be the scanner pcb than the main board. I am actually in the middle of the very same error and have tried the main board and it is the scanner pcb that is causing this particular problem. As you do not state what model you have , I cannot give you a part number.
Oct 27, 2015 | OKI Office Equipment & Supplies
CODE ERROR 100 SHOVING IN I R 3300 CANNON XEROX
You may need to replace the laser, it may have failed, this is from the service manual
E100
0001 The BD signal is not detected 10 times or more within 10 msec in 5 msec
after the generation of the laser drive signal.
0002 While the laser is ON, the BD signal cycle is outside a specific range 20
times or more continuously.
0003 While the laser is ON, the horizontal sync signal cycle is outside a specific
range 20 times or more.
Main cause The wiring is faulty (short circuit, open circuit). The BD PCB is faulty. The
laser scanner unit is faulty. The DC controller PCB is faulty.
Action
1. BD PCB
Try replacing the BD PCB. Is the problem corrected?
YES: End.
2. Laser scanner unit, DC controller PCB
Try replacing the laser scanner unit. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
anual.
Aug 30, 2014 | Canon IR 3300 Digital Copier
Radio shack pro-96 scanner screen blinks and loss of audio
If the scanner's display locks up or does not work properly
after you connect a power source or install batteries, you
might need to initialize it.
This procedure clears all information you stored in the
scanner's memory. Initialize the scanner only when you
are sure the scanner is not working properly.
1. Turn off the scanner, then turn it on again. Multi-system
Trunking Scanner appears.
2. Press 0 while Multi-system Trunking Scanner appears.
3. Press 1.
4. Press ENT. Initializing please stand by. appears for about 5
seconds.
Do not turn off the scanner until the initalization is
complete. When the initialization is complete, M000
appears on the top line of the display. Bank 0 Ch 00
appears on the third line.
Notes
Notes
Jan 10, 2013 | Radio Shack Pro-96 Scanner
C-3c50
C3C50 at power up.
PROBABLE CAUSES:
1. Loose connectors or failed PWB-C board.
Reseat all connectors and then replace PWB-C board (p\n 65FA-9360) if necessary.
2. Poor connection for the interface cable between the MFP and scanner.
Reseat the MFP-to-scanner interface cable its a large molex cable with thumb screws to remove on the outside of case.(p/n 4581-6876-01).
3. Failed PWB-F board.
Replace PWB-F board (p/n 4025-0103-27). Flash MFP with most current firmware. The latest version firmware or system software is available via the Konica Minolta Download if you need help with this write me back.
4. Incorrect scanner serial number.
Access service mode and select System Input. Verify the correct scanner serial number has been input under Serial # Input.this is in Service mode. if you need help with this write me back
Nov 29, 2011 | Konica Minolta Minolta CF 2002 3102...
Air conditioning unit just stopped working , operation light blinking code 1, on a cmh3172, the ac guy sai blown pcb board, are they repairable or actually have to be replaced, he said everything else...
It is a common problem, usually associated with moisture physically on the board or improperly installed communication cable (18-22 AWG shielded stranded Cu cable required). The PCBs are tightly packed and are frankly not worth the time it takes to diagnose and repair them. Replace the PCB and make certain that the original install was done correctly with the correct materials.
Sep 04, 2011 | Sanyo 12KLS71 Split System Air Conditioner
Error message E100. How do I repair or reset the machine?
E100 Scanner unit failure
Cause: (1) Poor contact in the laser/scanner unit connectors(2) Defective laser/scanner unit(3) Poor contact in the ECU board connectors(4) Defective ECU boardSolutions: (1) Reconnect the BD board connerctor (J871), laser driver board(J801), and scanner motor connector (J851).(2) Replace the laser/scanner unit(3) Reconnect the ECU board connectors J913 and J914 correctly.(4) Replace the ECU board.
http://www.wupload.com/file/211837258
Aug 12, 2011 | Canon 730i Laser Printer
Hitachi model No 32LD6600B turned telly off at plug last night last night now will not come on no standby light if you heat power board it will come on and stop on until turn of at plug again Thanks
1. YOUR flyback is going bad 2. Peform a removal and replacement 3. check your error codes first to ensue nothing else exists 4. Proceed to change out the required parts 5. Observe all electrical risks 6. Order replacements from jimmyparts.com 7. Ensure to always remove power 8. Ensure to always use electrostatic wrist strap
Generally what occurs is the units soldered connections on the main projection board warm up as the system warms up. Thus, the loose capacitors, resisters, and diodes are causing the CHANGE when the system warms up. When metal contracts, it expands thus losing the connection needed for a solid connection. This process is normal after the units have reached their service life. Keep in mind that you can repair this but at the expense of time if you have never performed this type of work.
Jan 29, 2011 | Hitachi Televison & Video
I have had the unit for a year and a half and it started running hot and evidently burning out the support chips on the video card. It was repaired by an official Toshiba repair facility. The repair...
On the X305 the video card is actually 3 boards sandwiched together. there are 2 actual video cards plus the SLI control board. I have a feeling that Toshiba was just replacing the failed board and not actually addressing the cause. In your case I would say that either the SLI control board is faulty or there is an active component on the motherboard that is causing an over voltage issue in one of the video cards. In any case you are looking at some pretty serious money to get this issue resolved. I personally would try a reflow on all 3 graphics boards and if that didn't work I would look to replacing the motherboard and the video cards.
Dec 09, 2010 | Toshiba Qosmio X305-Q725 PC Notebook
Radio Shack Pro-96 Scanner Logo
117 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
xxxxxx xxx
Steve Allison
Steve Allison
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
