Question about Kodak EasyShare Z712 Digital Camera
Kodak Z712IS-batteries die so quickly
I'm using the Kodak rechargeables...just put new ones in 3 days ago...already the camera won't even stay on long enough for the zoom lens to move out...Don't know what to do now....bought this camera less than one year ago.... I have the same "Problem" too, because this camera needs KODAK Klic-8000 LI-ION Batteries. It does not work fine with regular rechargeables batteries, usally you will get the same poor performace that you are describing with regular batteries. But there is a BIGGER problem, i bought a chinese Klic-8000 on ebay and my z712 don't even turn on, the battery its OK, because i had test it with a multimeter and it's holding good energy. I have read here, in another post, that some one have this problem too, i don't know if this guy bought a chinese battery or a ORIGINAL Kodak battery, but seems that even with this kind of batteries you can have problems too. I will try a 1800 mAh CRV3 battery, i hope that it arrives in this week from China, if you wish, i can tell you if this battery is good enough to take a decent number of pictures.
NOTE: Sorry if my english is not good enough, i'm from Mexico.
  • Dober Jan 12, 2009
    Now i'm trying a 1800 mAh CRV3 chinese battery, and it works fine. I really don't know if my Klic-8000 from china it's defective but i have heard that some users have problems too with the Klic-8000 in a Z712 camera.
    Thanks for your help.
  • babasahib Feb 09, 2009
    I put a new battery in my recent bought Z712 in less than 10 seconds the camera will turn off. I am unable to enjoy the camera. Is there a solution?
    Brigadier General:
  • 5,158 Answers
You can't really get around the fact that digital cameras create a heavy strain on batteries. rechargables are the only way to go with them. now about the chinese battery. the voltage may be fine but that is not under load (being in the camera during operation) so it's deceptive about the voltage.
Robert
Posted on Jan 10, 2009
2 Suggested Answers
SOURCE: Bought the Kodak Klic-8000 battery
Put a small piece of two sided tap in the grove, about 2 x 2 x 1 mm and see it it slides the switch completely, don't remove tap from the outerside.
Posted on Apr 29, 2009
Why are the batteries dying so quickly in my Kodak 12MP?
The main complaint against compact digital cameras used to be battery life. This was in the days when a 4 or 6MP would have been top-of-the-range.
The life of standard zinc-carbon batteries could be measured in minutes rather than hours and decent alkaline batteries might last the duration of a wedding but might not.
Manufacturers rushed to produce better batteries to meet the booming new market and the camera manufacturers began fitting rechargeable lithium batteries as standard in basic and lower cost cameras and with further developments in technology batteries now last much longer.
Leaving the batteries fitted into the camera when it wasn't being used didn't help much as the circuitry had to be kept alive to retain the settings.
Your camera might have a fault causing the batteries to discharge quickly but if it is working ok, probably not. If you have long experience with your camera and it has suddenly started costing lots of batteries it might be a good idea to update it. It has certainly been many years since Kodak cameras had the reputation for quality...
Meanwhile I suggest you use only high-capacity lithium batteries and remove them when the camera is not going to be used for a while.
Feb 28, 2015 | Kodak Cameras
It depends, if you are using regular Alkaline batteries, those are known to go dead really fast. Better if you try some rechargeable batteries with a rating of at least 2100mAh, anything smaller than that will drain just as quick as Alkalines.
Feb 28, 2015 | Kodak Easyshare C182 12MP Digital Camera
I accidentally left my camera on, and the battery died. Later, when I plugged it in to charge, the charger light just binks orange continuously. The camera won't turn on at all, and I can't get the...
I think the battery was already damaged,a rechargeable battery once you use it,it needs to recharge again so that the battery memory will stay longer.use a new one,regards....
Jul 03, 2011 | Samsung SL102 Digital Camera
Put brand new batteries in camera took three pic then they die
Hi, you will only solve this by buying the official KODAK battery (KLIC-8000) - NZD52.00 retail here in New Zealand. Even the generic CR3V rechargeable batteries dont work, so dont waste your $$ on them.
Even now, with the 'official' battery, when taking flash photos or zooming a lot, I find that it is only taking around 150 - 200 shots, when Kodak boast over 400.
But I must say the capabilities of the camera (esp the quality video) outstrip any annoyance battery wise.
Hope this helps, regards Wayne
Mar 28, 2009 | Kodak Easyshare Z812-IS Digital Zoom...
Kodak DX3900 camera can't get power from battery
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Mar 13, 2009 | Kodak EasyShare DX3900 Zoom Digital Camera
Help with s630 Digital Camera
Rechargable batteries actually do not recharge the 100 times advertised. After maybe 10 times they are reduced in capacity noticably. For instance, new alkaline batteries will last me maybe 60 pictures, however the rechargables are only good for about 5. To test this try taking out the batteries, and put back in before you wish to try them, also turn off the flash if it is not needed.(flash uses a lot of power)
Apr 11, 2008 | Samsung Digimax S630 Digital Camera
EasyShare Z712IS
the camera will work with any brand of lithium but only the KLIC 8000 battery will work as a rechargeable
please look at your getting started guide and check page 1, there's an illustration of the 3 types of batts that will work:
lithium crv3, lithium aa and klic 8000
ni-mh is really not compatible
please check at the bottom of your camera, the three types of batts I mentioned are engraved at the battery door
thank you
Dec 31, 2007 | Kodak EasyShare Z612 Digital Camera
Camera keeps turning off
Digital cameras are very Voltage Sensitive. Using Nicad or NiMh batteries will not only , "Not" solve the problems above but will
actually aggravate the above problems for one reason.
Rechargable NiCad or NiMh batteries only produce 1.2 volts fully charged and will only give you 2.4 volts when used in pairs with this camera. This falls below the cameras desired 2.8 - 3.0 voltage requirement and will only result in about 30-40 pictures at most.
This camera requires a constant 2.8 - 3.2 volts to run properly. Kodak won't tell you this !!The camera was designed with Oxy Akaline batteries in mind.New alkalines will produce 3.2 to 3.4 volts in pairs but only for a short period of time.The issue with the Oxy Alkaline batteries is that they simply will not last very long in this camera due to its power requirements.
But there is a really great solution to the problem . You can purchase a CRV3 rechargeable Li-ion battery that fits right into this camera.
You will get a realistic 180-250 photos per charge.The Li-Ion battery maintains a constant 3.0 volts for a very long period of time
and will allow the camera to function the way Kodak originally intended it to and can be recharged. You will find rechargable CRV3 battery kits on ebay or other online battery stores at a very reasonable cost.
You can also use a Lithium Non rechargeable CRV3 battery that will give approx 250-300 photos per battery but you may
find non rechargeable Lithium batteries cost prohibitive.
I use the rechargeable Li-ION Battery exclusively in this camera and it functions perfectly since I switched. I have a pair
of CRV3 Li-Ion batteries so I always have a fully charge CRV3 ready to go.
For reference I was only able to get about 30 pictures with the high capacity 2800 Mah Rechargeable NiMH Batteries I used prior
to using the LI-ION Battery. I get on average about 175 pictures per full charge from the LI-ION Battery.
Jun 14, 2007 | Kodak EasyShare C875 Digital Camera
Kodak EasyShare Z712 Digital Camera Logo
456 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
