Question about Audiovox SMP3338 (512MB) MP3 Player
Venturer smp3-338 Malfunctioned and windows not recognize it.
Hi! GUys I am using venturer smp3-338 for a time, but other day while copying songs i just unplug it....what i think is happened is it's software is corrupted, now when ever i plug it to my pc I get message that the device is Malfunctioned and windows not recognize it.
Any idea how ti fix it again, and enjoy music.
Thanks
USB device not recogniszed. The device has malfunctioned and windows does not recognize it
You may need USB drivers to recognize the USB drive, especially if it's an older copy of Windows. I would check with the manufacturer for drivers if that's the case. Maybe try it in another machine to make sure it's not defective too.
Mar 27, 2014 | Electronics - Others
G25 wheel, usb device not recognized
Hi Telemachou,
You might want to call the Logitech Customer Care, try on another computer/Playstation, if the problem persist, then you should get a replacement for hardware failure.
Thanks and have a nice day
J -
May 30, 2010 | Logitech G25 Wheel And Pedals Set
My laptop doesn't recognize my Sansa MP3 Player. I want to copy songs to my mp3 player but it is not copying
Try using the Windows Media Player ... open the program then connect your mp3 player and see if it recognizes it ... sometimes the software that comes with the players are inferior to what is standard on your pc ... Also it may take a few times for it to recognize it .. .load your music into your library and sync it from there ...hope this helps
Apr 20, 2010 | SanDisk Sansa e260 MP3 Player
Problem recognizing songs in sansa e260 mp3 player.
From what I'm hearing you don't have a good driver. If you still have the disk use that. If not google it or something. I have a Sansa e260 as well so I would suggest loading the songs on in windows media player rather that windows explorer. If you open Media Player and then go to sync and it does not recognize your device, then you have a bad driver. If not, then start syncing your songs that way.
Hope everything works,
Fixer Guy
Feb 04, 2009 | SanDisk Sansa e260 MP3 Player
Been in prison for a long time...
Hi:
1.- Insert Card in the PC slot, your computer instantly is going to recognize your device emitting an audible midi sound.
2.- go to my computer
3 check on my computer windows if the device is present with a letter
E:\, or F:\ if yes, right click on the letter that corresponds to the device, choose format, once formated you are able to copy your songs. Minimize it using - top right corner.
go to the folders you keep your songs I hope you have MP3 format instead WMA format. (MP3 takes less space on the device)
select your songs highlighten them using CTRL C once selected R click, select copy open E;\ or whatrever be your drive and r click on a blank space in the opened E:\ or F:\ window and select paste.
Hope it helps. DH
Dec 15, 2008 | SanDisk 2GB microSD Memory Card
When I download songs one day the next day download songs it removes some songs I already had on the mp3 even though I have plenty of space for the songs.
It seems to me that you are using windows xp and thus facing this problem.I will suggest you to use windows vista and format the mp3 in fat32 partition and then copy paste the songs..It will be working fine......................
Sep 24, 2008 | Apple iPod touch
My computer doesn't recognize the Sansa c240
The songs are in the wrong format - convert them to mp3
Read my "Tips and Tricks" on song formats for more detailed info
Mar 31, 2008 | SanDisk Sansa c240 MP3 Player
Mymusix (PD 135-02) 1GB MP3 player files not recognized by my computer
MyMusix MP3 Player PD-6110 doesn't show up on my computer. I'm using Windows 98SE and downloaded the driver I needed but I still can't find this device.
Nov 22, 2007 | MyMusix PD-135-02 MP3 Player
Audiovox SMP3338 (512MB) MP3 Player Logo
98 people viewed this question
Top Audiovox Audio Players & Recorders Experts
John
John
Chinmay Joshi
Chinmay Joshi
Computer Links
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
