Question about Apple iPod nano chromatic
Hi I bought my husband a red apple ipod chromatic for christmas and when I went to change his music it deleted all his previous files and wouldn't let me add new ones. Itunes said I needed a disk. So I continued to try and now I have a blank screen. Please help
  • 790 Answers
Hi
Reformat your Ipod then test run.
Thanks!
Posted on Dec 29, 2008
My friend gave me a chromatic apple ipod. If I turn it on what I got is only the apple logo. I cannot turn it off after that. I tried to connect it to any of my computers including my computer with...
Hi x1mega...
When the Apple Logo is stuck
If this happens, put the iPod into Disk Mode through the diagnostic menu.
Then connect the iPod to your computer and update or restore the iPod.
Sometimes you can get away with just updating the iPod, so try that first, but usually you have to restore the iPod .
As always make backups of your music files, because the restore procedure will eliminate them.
Free Answer...Please take time to rate me
Jul 12, 2011 | Apple iPod nano MP3 Player
Tip
How to Put Load(s) of Music on Ipod Chromatic
HELLO,
This will show you how to use minimum space to have maximum music files on you Ipod Chromatic.
STEP 1: Locate all your music files that you want to upload on you iPod.
(Using Either PC or MAC )
STEP 2: Categorize and name a folder, called musice. If you have
different music files, name other folders music 2, (for mp3)
music 3, (for wma), etc...
STEP 3: Put the different music files in their seperate folders. And then
put all those folders in the main folder called Music.
STEP 4: Plug in your Ipod, and run it in My Computer. Click on the
Music folder, (If using Windows: >>> Right ~ Click on Taskbar
and Click Tile Windows Verticlly). Then Drag and drop the folder
called Music into the Music Folder of your Ipod.
STPE 5: Close all files on the Computer, safely remove the Ipod via device
Manager on Taskbar, (if using Windows).
STEP 6: Enjoy more music for less space :)....lol
on Jan 30, 2010 | Audio Players & Recorders
Hellew there i bought a new ipod and i m uanble to edit the files and its says the data is full and i need to delete ....but i m uanble to delete files,.....when i bought the ipod i happd to delete some...
Put your ipod in Disk mode, in this way you will be able to delete de music files manually.
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
Feb 08, 2011 | Apple iPod nano
My green Apple Nano Chromatic iPod's batter life & other problems
turn the backlight down or maybe let it charge even when the battery says its fully charged!
Dec 15, 2009 | Apple iPod nano MP3 Player
How to restore an iPod
If you have a backup before, go onto iTunes, right click on your device on the left-hand side bar, and their should be an option 'Restore From Backup', or something similar, click that and it'll restore your iPod to a previous backup.
iPod Data Recovery software can help you, it enables you preview and recover all contents from the iTunes' backup file, including your iPod photos, videos, notes, calendar and contacts.
Oct 10, 2009 | Apple iPod nano
How do you delete songs from your Apple iPod 4 GB Silver?
You can set your iTunes to "manually manage music and video", then plug in your iPod to iTunes, and delete the songs from your iPod with iTunes.
Or you may try this ipod tool, it can help you delete iPod music easily, Much better than iTunes
http://www.ipod-transfer-copy.com/ipod-iphone-to-computer-transfer-cucusoft.html
Hope it helps.
Sep 07, 2009 | Apple iPod nano
Charging or plugging in my Ipod chromatic
i have the SAME problem but i bought mine 5 days ago so its suppsd to be brand new!! ='[ *sob* it just got 'stuck' all of a sudden and wont respond to anything! :S
Jan 30, 2009 | Apple iPod nano MP3 Player
Cant delete songs off my ipod
Two possible solutions:
Solution 1. Go to iTunes, go to Edit, Select All, go to Edit once again, select Delete. This will clear your whole music library. Connect you iPod and let it sync. It will delete everything in your iPod. The problem with this is that it will delete all your music in iTunes as well so you better back it up elsewhere.
Solution 2. Go to iTunes, connect your iPod, let it sync. Do not disconnect your iPod. On the left hand side of the screen you will see "Library", "Store", "Devices", etc. Go to "Devices" and you will see your iPod's name there. Click on it and you will see on the right hand side of your screen your iPod, with some menus tabs. On the first tab (Summary), make sure that "Sync only checked songs" is activated. Then go to the second tab ("Music"). Make sure "Sync music" is activated and "Selected playlists" is also activated. Make sure NONE of the playlists is activated. At the bottom right hand side of the scree there is a button that says "Sync". Press it and it will sync no songs into your iPod. That should clear the songs but leave the contents in iTunes intact. If you want to put some playlists in your iPod, then check only those and only those will be added to your iPod.
Hope this helps.
Jan 01, 2009 | Apple iPod nano MP3 Player
Recover deleted music from apple ipod nano blue 8gb
There are several advanced and user-friendly application available for iPod data recovery. Kernel Recovery for iPod tool is one of the effective program, By using this application, you can quick recover deleted or lost files or folder from iPod. Get more details about this software visit http://www.ipodfilerecovery.com/
Dec 22, 2008 | Apple iPod nano
IPod Classic won't recharge
This will reset your ipod hopefully it helps
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step
  • Aug 12, 2008 | Apple iPod classic MP3 Player
    Apple iPod nano chromatic Logo
    70 people viewed this question
    Top Apple Audio Players & Recorders Experts
    TO Lady
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
