Question about Panasonic Panafax UF-780 Plain Paper Laser Fax
Fax machine with error code. Panasonic UF-780. Error: "Check cassette info code = 011"
  • Megan Range
    Megan Range Dec 30, 2008
    When I was attempting to unload and reload the cassette nothing changed. When the nurse working in this dept (at a hospital) tried the same thing it magically started working.
    We were both there and did nothing different so the cassette must have had to be in "just right". Hopefully this doesn't happen again, who knows what it will want then, a steak dinner?
    Thank you for your advice though, I appreciate it.
    Sergeant:
  • 284 Answers
You broke the tab on the back of the paper cassette. if you look in where the cassette goes on the back left you will see a hole with a sensor that looks kinda like a upside down letter U . put paper inbetween the sensor and the machine should say out of paper and put the cassette back and you should be fine
Posted on Dec 30, 2008
  • Paul Homuth
    Paul Homuth Jan 23, 2009
    if you thanked m,e for the advice why did you give me a bad raiting
What doe he code 011 mean and how do we fix it?
Error 011 indicates an error with the recording paper cassette. Re-install the cassette to clear the error. It's basically the bin that holds the paper that the paper tray leads into. Please post back with any problems or questions or just to rate the solution. Thanks very much!
Greg
Aug 10, 2009 | Panasonic UF-590 Plain Paper Laser Fax
We cannot recieve faxes check cassette error code 011
The small tip on the left side of the paper cassette is broken off.
wad up a small piece of electrical tape up and stick it into the black u-shaped sensor hole where the tip used to go in.
Jul 07, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Panasonic Panafax UF-880 Plain Paper Laser Fax - Info code 011
Remove the paper cassette completely, look in the cavity for a broken magnet or crumpled up paper. The machine thinks that there is no paper tray installed
May 08, 2009 | Panasonic Panafax UF-880 Plain Paper Laser...
Hello the Panafax UF 770 was donated to our school. We needed to figure out what this means: INFO. CODE=011? Can u help us please?
There probably a broken off magnet that sits in back of the paper cassette. If you have 2 paper trays, you should be OK without 1.
Jan 05, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
I got Panafax UF-595 and this fax keeps saying "check cassette info code=011" and does nothing else. What am I supposed to do to make it work?
There is a small plastic tab broken off of the front of the paper cassette.
remove the rear brown tray
remove the toner
set the machine on it's back side
stick the tape in the black U-shaped photo sensor at the bottom left corner of the machine to cheat it.
Dec 10, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
How to fix this code????
there is a little tab on the cassette that is broken. leave me a way to email or talk to you and this could be resolved
Sep 24, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Error message
o54 means you have a bad laser unit. Try unplugging power cord and replug.
Sep 02, 2008 | Panasonic UF-590 Plain Paper Laser Fax
Panafax uf-790 - info code = 011
Check cassette refers to the paper cassette. If there is no paper or the cassette is not seated correctly, then you will get that error. If you tried those, then check the left rear of the cassette for a tab. If that tab is broken off you will get this error and you need a new paper cassette. Good luck.
Jun 14, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
Recording Paper Cassette
Error code 11 means that it does not see the cassette in the machine,. there is a tab on the back of the cassette that is broken . thats why your getting that code.
if you leave me a msg that you want to fix this i will contact you
Oct 09, 2007 | Panasonic Panafax UF-595 Plain Paper Laser...
Panasonic Panafax UF-780 Plain Paper Laser Fax Logo
510 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
