Question about Samsung SyncMaster 710N 17 in. Flat Panel LCD Monitor
Problem LCD screen stays white bright after switch button is OFF ??
Hi please help I have a relatively new model SyncMaster 710n monitor and after few days a notice that when I shutdown my SyncMaster and after few hours turn it on and again shut it down on power switch he stays with bright white screen like some back light. I do not know when was first (failure) but this seems that happening vary often.. sorry on my english. Is this power failure, capacitator... he is second monitor on my VGA card (ati 9200) regards Thanks
  • JP Miami Feb 24, 2008
    LCD shows all white
    Samsung syncmaster 204b
    My LCD can turn on and off using the power switch at the front (Control panel) but it doesn't show anything on it not even the menu when I press the menu button. Also the refresh button works but no output in the screen is displayed.
Some capacitors need to be replaced,which would have burnt out due to power fluctuations
Posted on Jul 31, 2007
Samsung Syncmaster 710N PROBLEM !!!
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 10, 2010 | Samsung SyncMaster 710N 17" LCD Monitor
I have the syncmaster 710N. I recently had a
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it on eBay.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Feb 24, 2009 | Samsung SyncMaster 710N 17" LCD Monitor
Driver of samsung monitor
I will go with Cropp on this one however if you cant find it at that site you may also try driver guide.com
Jun 06, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Flickeing like a dying fluorescent light bulb
Actually this is a 'warning' signal from your lcd monitor. The problem is your lcd ccfl lamp are near to their life, need to change. The ccfl lamp like our home fluorescent lamp, when the lamp need to dead, the lamp will flickering first, after some time, will totally off(dead). So, this is a signal for you. Some lcd monitor, when their inverter board are using fairchild inverter ic(oz series), will easily shutdown your monitor when they detected some flickering on your screen (ccfl lamp). If you need more information on repair your lcd monitor please visit http://www.fastrepairguide.com . Thanks.
Jan 17, 2008 | Samsung SyncMaster 710N 17" LCD Monitor
hi
I am a technician-informatic. I have repaired about 40 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
thank you
Oct 29, 2007 | Samsung SyncMaster 710N 17 in. Flat Panel...
Syncmaster 710N resolution problem
no,
the LCD display don't harm the eyes cause don't spreed radiation.
preferred resolution 1280x1024 at refresh rate of 60Hz is not optimal.
the samsung 710N can easy handle 75Hz at 1280x1024 so just change it.
Jan 30, 2007 | Samsung 710N V2 (Ivory) 17 in. Flat Panel...
Samsung SyncMaster 710N 17 in. Flat Panel LCD Monitor Logo
333 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
