Question about Navigon 2100 Portable GPS Receiver
POWER SW ON TOP OF GPS WILL NOT POWER-UP SCREEN WITH 12V PWR.
GPS SCREEN WILL NOT ILLUMINATE WHEN 12-VOLT POWER CORD IS CONNECTED TO CAR POWER (POWER CORD LIGHTS UP) AND GPS POWER LIGHT ALSO ILLUMINATES IN UPPER RIGHT-HAND CORNER OF GPS BUT BLACK SCREEN IS OBSERVED WHEN POWER BUTTON ON TOP OF GPS IS DEPRESSED.
  • 790 Answers
Hi
please check the power lines the B+ remote is important to connect at all.. if this is not connected you got failure power!
thanks!
Posted on Dec 29, 2008
Using without parking break
Hi James,
Page 27 of the installation manual (http://www.wwstereo.com/_files/155788/documents/Kenwood--Manual.pdf) shows a connection to the parking brake light circuit. It is the Light Green wire labeled "PRK SW" shown below.
If it is connected the way it is drawn, the PRK SW wire is connected between the lamp and the switch that opens and closes depending on the position of the parking brake (set or not). 12 volts is always present from the battery to the top of the lamp. It passes thru the filament to the wire that goes the top of the parking brake switch. So, when the brake is OFF or disengaged, the lamp is off and 12 volts is present on the PRK SW wire to your Kenwood GPS. When you set the parking brake, the ground (symbol is the funny slanted lines under a horizontal line) just under the brake switch passes through the switch and changes voltage at the PRK SW to "ground" or 0 volts. When this happens, the ground on one side of the lamp with 12 volts on the other side of the lamp - make is turn on.
So, what does this mean? Simply tie the PRK SW wire to any grounded metal and the Kenwood will think the parking brake is always set - for as long as it is tied to ground. You can check it with a simple voltmeter to be sure. Set the meter to 12 volts or more, touch black lead to ground & the red lead to the PRK SW wire. Kenwood should only work when at 0 volts (brake set). Release the brake - meter shows 12 volts & the Kenwood shuts off.
I hope this helps & Good luck!
Apr 09, 2014 | Kenwood DNX570HD
Garmin nuvi 745
Yes, a Cellphone, Google Maps and a Power Block will give you about 5 days use!
You could also carry a small 12 volt lithium battery of the type used in alarms in a back pack, connected to a cigar lighter like this unit.
12VOLT RECHARGEABLE PORTABLE BATTERY POWER PACK 12V DC CHARGER LIGHTER...
Or this
Lightweight 12 volt portable battery station Lithium ion 8 8 Amp Hours...
Or you buy a GPS Sat Nave unit specially made for cycles.
Cycling GPS Units Amazon co uk
Garmin Edge 1030
Garmin Edge 1030 GPS black 2018 handheld colour gps
Nov 18, 2017 | GPS
Need to know how to connect the 12 v dc power to the unit as I lost my power cable for radar 1000
As you look at the back of the display unit, the power plug has 7 connection posts.
Top left is pin 1 Bottom Right is pin 7
Pin 1 ..... + 12v
Pin 2 ..... - 12v
Pin 7 ..... Boat Ground
Rob
Oct 14, 2010 | JRC 1000 MKII Radar GPS Receiver
My nuvi 670 froze nothing work impossible to reset
Can you connect it to your computer? Does it come up when you do? If so, and if it behaves normally then the issue is with the power cord/ 12 volt adapter cord you use in your car.
Replace the power cord.
Aug 03, 2010 | Garmin nuvi 670 GPS Receiver
How to hook up without connectors
car colors
yellow 12v switched
orange 12v con
green rf-
lite green rf+
grey lf- paired with tan
tan lf+
blue rr+
lite blue rr-
yellow lr- Paired with brown
brown lr+
pink pwr antenna
brown alone illumination
grey alone illumination dimmer
black ground
radio wires
purples rr
green lr
grey rf
white lf
red switched
yellow 12 con
bluewhite stripe ..amp turn on
blue power ant
black ground
hope it helps
Jun 07, 2010 | JVC AM FM CD DET FACE CAR STEREO
POWER SWITCH DOES NOT ILLUMINATE GPS SCREEN WITH 12VOLT PWR.
bjw122266 Have you tried holding the power button down for about 10 seconds or so?
Dec 29, 2008 | Navigon 2100 Portable GPS Receiver
Power supply
Three years ago I performed a temporary repair to the power cord on my motorcycle. Someone unfamiliar with the connection pulled the cord instead of sliding it. The hard plastic flange pulled away from the molded rubber plug. I glued the lower flange back to the plug with superglue. It's still working.
Dec 18, 2008 | Garmin StreetPilot 2610 GPS Receiver
Whistler 35R just quit. fuse and pwer cord is fine.
Orginal whistler power cords do not have LEDs lights in them and there is no electronics in the plug - 12 volts in, 12 volts out. Sounds like you have a bad cord or a cord that is meant for a GPS unit or other 5 volt device.
Sep 02, 2008 | SRT-35R Radar Detector
Navigon 2100 Portable GPS Receiver Logo
53 people viewed this question
Top Navigon GPS Experts
Will Halftowaite
Are you a Navigon GPS Expert? Answer questions, earn points and help others
