Question about NetGear RangeMax NEXT WNR834B Wireless Router
Ethernet connection works but wireless does not
I had a recent, brief power outage and even though the router is connected to a surge protector, ever since I have not been able to connect wirelessly thru either my laptop or desktop. A search for wireless networks shows an unsecure "Netgear" network, but not the home network I had previously set up. And when I try to set up security for this "Netgear" network, it does not take. I would hate to have to re-install everything, as I had problems getting the router to work in the first place. Any help would be greatly appreciated!
  • 170 Answers
When you lost power it probably reset all your settings back to default. Looks like you have to do the nasty and start over. Sorry
Posted on Dec 29, 2008
    President:
  • 1,314 Answers
Unfortunately what sounds like is the "brief" power outage caused the router to malfunction. Hooking up to a surge protector does not help because it was not a surge, but an interruption. With electronics, you must allow adequate time once they are turned off before they are turned on again or risk the possibility of failure. The brief blip in the outage caused the router to malfunction.
I have a Netgear WNR2000 v4 router. We recently had a power outage.Power came back on in 5 seconds.The cable modem is fine,however the router ONLY shows me a solid green light for power, nothing else.
I would just do the reset, this should allow you to access at factory defaults. (I hold button in for 10 sec).
A solid green (power?) light is good
LAN ports should only light if connected
WiFi port should light if set to active
Mar 02, 2015 | NetGear Computers & Internet
PS3 Power Surge.
Get a surge protector for your most loved systems, that way the worst case scenario is you will need a cord replacement. Unplugging it when it's not in use may also cool it down.
Jul 24, 2013 | Sony Playstation 3 (PS3) Console
Recently my computer indicated "network
Yes, the router is probably faulty.
It pays to connect all your computer equipment to a surge protector board.
Jun 15, 2011 | Computers & Internet
The circuit breaker went off the other day, and when the power came back, the router no longer had wireless. The symptoms seem similar to most problems on here, with the power light on dim, and Ethernet 1...
You must have had a serious surge. Sounds like it's fried.
Use it as a door stop and buy a new one.
Sorry...
For future, while you're shopping for router, get a powerstrip surge protector and plug PC, monitor and router through it.
Jan 09, 2011 | Linksys WRT300N Wireless Router
Wirelessrouterstepbystep learn howto setup
Choose your equipment wisely. There are many types of wireless routers, and they are not all created equal. Some of the lower end wireless routers are very basic, and will limit your home network to speed of 56 megabits per second (Mbps.) This is really not a very fast speed. If your access points will be very far apart, consider getting a router with ultra-range abilities, or a dual-band router. Also, while you're at the store, be sure to pick up one wireless access point for each computer you intend to connect to your network.
Remove your DSL or cable modem from the power supply.
Remove the Ethernet cable which connects your DSL or cable modem to your computer from the computer, but leave it plugged into the back of your modem. This cable looks something like a phone cord on the ends, but with much larger connectors and a larger, round cable. Do not remove the phone cord from the modem which is plugged into the telephone jack on your wall.
Connect the loose end of the Ethernet cable to the internet port on the back of your router. This port should be clearly marked, and will probably be a different color than the other ports.
5
Reconnect your modem to the power source. To protect it, plug it into the same surge protector which guards your computer.
6
Plug the Ethernet cable which came with your router into the Ethernet connector on the network card on the back of your computer. Then plug the other end into one of the Ethernet network ports on the back of the router.
7
Plug the router's power cord into the power supply. This device should also be protected by a surge protector. If you run out of plugs, it is well worth ten or twenty dollars to invest in a second surge protector.
8
Check the lights on the front or top of your router. The power light should be on, as well as the internet light, the wireless light, the security light, and a light for one of your Ethernet network connections. Check to see if any lights are off, flashing, or red or amber in color. This will indicate that the router is having a problem. If any lights are not on as they should be, check your cable connections to ensure that they are securely connected. Repeat the setup steps if necessary.
9
Install the software provided by your wireless router's manufacturer.
This is it you are done
Thanks .
Oct 07, 2010 | Computers & Internet
WE HADA A POWER OUTAGE AND NOW THE WIRELESS IS NOT WORKING AND THE LIGHT ON ROUNTER DOES NOT COME ON
Is the router plugged into the same power source (surge protector or power strip) as your computer? Try plugging it into a different outlet -- one that you know works -- and if the router doesn't turn on there then either your router is fried or the AC adapter that powers it is fried.
May 30, 2010 | D-Link DI-634M Wireless Router (DI634M)
Lost connectivity after power outage
If this is a printer WITHOUT WiFi or bluetooth - and you have it connected to another computer (Print Server) via a USB cable - you need to make sure you can see that computer from the other computer you are printing from. Use the network explorer - if you can see the computer and the printer you should be able to print to it.
Sometimes, it may be secured with a password. I found if I can map a shared drive from my laptop to my print server then I can print again. So see if you can see the printer and printer server computer from the other computer. If so you may need to add that printer again to you printer list.
May 01, 2017 | Zonet ZPS3611 Print Server
I have a Dell XPS 1330 laptop and a DI-524 wireless router.
Unsure what your problem is exactly but here is something to try. Power off all computers, modem and router. Power up the modem first, and wait until it is completely up before proceeding. Next power up the router and wait until it is completely up, the only light that probably wont be lit is the LAN light. Then power up each computer, they can all be powered on at the same time, that part really doesnt matter. See if that fixes the problem.
Aug 11, 2009 | D-Link AirPlus DI-524 Wireless Router
Pc link
try bypassing the surge protector after turning everything OFF and then power on modem then router, without being connected to computer.
Jul 03, 2008 | Buffalo Technology (WLI-TX4-G54HP)...
TV won't turn on after power outage
LOT OF TIME WHEN YOU LEAVE IT OFF FOR THE NIGHT DISCONNECT POWER CORD DEFECTIVE SURGE PROTECTOR IS NOT GOOD FORE EVER PLUG TV IN THE WALL WITOUT THE SURGE PROTECTOR IF IT GOOD CHANGE THE SURGE PROTECTOR FOR NEW ONE CHEERS
Jan 17, 2008 | Hitachi 60UX54B/55K 60" Rear Projection...
NetGear RangeMax  NEXT WNR834B Wireless Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
