posted by john john on Apr 27, 2007
i am new to djing.,.,,,,,i have two amps a crossover(2)way...a dual cd player....along with numerrous spekers and subs.......how do i hook up the crossover?????...the amp///// and cd player
Best Solution
posted on May 10, 2007
SEnd all the high notes to the small speakers and the bass to the sub.
Ran.
Ran.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Apr 09, 2008
John John,
Here's the scoop! I presume you have a rack case for all of your gear. If so, Mount the amps (Heaviest stuff) in the bottom, if you have spaces available leave some for ventilation. The player outputs will go into the line inputs of the mixer. Depending on which mixer you have, it will probably be line 1 and line 2. Your crossfader assignments will determine what goes where.
The output of the mixer goes into the crossover. Low out goes to the amp driving the subs and hi output goes to the amp driving the top boxes. If both amps are the same it doesent matter, but if one has more output , use it for the subs(low-end). Check the specs for the speakers but if the tops have 10" woofers, set the crossover to 200-250 HZ (cycles) if 12" use 150 HZ and if 15" use 125hz. You will most likely need 4 speaker cables, 2 for the tops and two for the bottoms. If you make your own, please double check the polarity of each cable (White or red to Positive and black or clear to negative) so the speakers both work together instead of fighting each other (out of phase).
Suggest a new solution for this problem
Post a New problem for Gem Sound GemSound PA-585 2-Channel
Email this problem
Email this problem
Can you Help with these Amplifiers and Preamps problems?
remote codes for sansui audio...
I have an older sansui stereo... Answer This...
Repair Service
Find Amplifier and Pre. Repairman Near You:
