Question about TallyGenicom 2280 Matrix Printer
Tally 2280+. While printing, goes offline and displays paperjam.
While printing, the printer goes offline and displays paperjam. There is no paperjam, you just press online and then it continues printing. this happens with almost every page that it prints, sometimes it will print 4-5 pages then display the error, other times it happens after evry page.
I have confirmed that the printer's settings are correct.
Any Ideas?
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 30, 2009
My printer doesnt works, its always offline, nad the isplay shows paperjam, but the paperjam is not there,
Printer offline solution:
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
Paper Jam solution:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 14, 2010 | HP DeskJet D1460 InkJet Printer
Hai , i have tally 2280 sprintpro it
problem with aga gear open the printer & check the white gears situated left upper of aga motor .......
may be aga flag missing or misalinged
Jun 29, 2010 | Tally Matrix T2280 Printer
Our tally 2280 Dot matrix has an alarm code 025609413032 What causes this to be displayed on the 2280 screen.?
check out this FAQ page for the hardware alarm codes:
Mar 19, 2010 | TallyGenicom 2280 Matrix Printer
Tally Genicom Slow Printing in Foxpro Dos Program
change the connecting cable serial or parallel what you have it may help you.
Jun 15, 2009 | TallyGenicom 2280 Matrix Printer
Tally 2280+ printing in small font
The 2280+ can be reset to factory default settings by;
Start with the printer Powered OFF
Hold down the 4 buttons under the LCD display
Power the printer ON, keep the 4 buttons held down whilst the printer initializes, release the buttons when the printer shows 'Loading Defaults'
Prior to resetting factory defaults I would recommend printing a menu print on the 2280+ so you know how the printer is currently set up just in case there are any problems.
Mar 20, 2009 | TallyGenicom 2280 Matrix Printer
Tally 2280 printer givesw printhead hot error
Is it a + version, with an Ethernet board included? These were known to cause such errors, seamingly not related at all. Try replacing the Ethernet board, or at least pull t out and disable to try.
Feb 14, 2009 | TallyGenicom 2280 Matrix Printer
Hello, I have characters printing trouble, so that I would like to restore the factory default settings for my printer Tally 2280. But I do not know the procedure to do so. I need Helps, very...
You can reset the menu on the 2280 to factory default settings, but I would strongly recomend first printing a menu print to ensure you know how the menu is currently set up.
The menu can be printed in the follwoing way;
Switch the printer power on.
Press the Setup key to enter the menu settings.
Press the key under "Menu",
Then press the key under "Print" and your current configuration will be printed.
If the menu is locked power the printer on holding down the setup button, this will unlock the menu.
To restore the factory defaults within the printer,
switch the printer off.
Press all four keys beneath the printer display and switch on the printer.
Keep the keys pressed until "Initializing" is seen in the printer display.
Your printer is now set to the factory default configuration.
Jan 27, 2009 | TallyGenicom 2280 Matrix Printer
"check ribbon " error is comming on my tally 2280+ serialprinter
The ribbon I had installed (code 061627) which says it is the correct one is in fact not. the drive pin on the printer slips while feeding the ribbon.
I have fitted a (code 062471) and now it is printing fine again.
a google search reports both these codes as compatible but they are quite clearly, not.
Jan 24, 2009 | TallyGenicom 2280 Matrix Printer
Paper width error on tally genicom 2280+ printer
Power ON printer holding down ONLINE button, release it after TESTMENU is on display. Press NEXT few times, enter APM or somthing like that (or APW? cant remember), switch it to OFF. Press ONLINE. Thats it! Greetings.
ps. this is procedure direct from polish division of tallygenicom servicedesk. it works for me perfectly!!
Mar 12, 2008 | TallyGenicom 2280 Matrix Printer
Print stops after 2 pages !
Hi my tally printer 6218 giving Ribbon motion fault, what could be done to remedy this error message ?
Jan 19, 2008 | Tally T6218 Matrix Printer
TallyGenicom 2280 Matrix Printer Logo
306 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
