Question about JVC LT-32X776 Television
JVC32X776 NO PICTURE
The circuit board for the LCD Display is fried. I need to purchase a new one but I don't know what the board itself is called. Does anyone know? Could it be a connector board or a regulator board??
    Genius:
  • 1,074 Answers
It is call an video module circuit you need to mention the part number of the module and the model of the tv good luck.
Posted on Apr 28, 2007
No display on right side of picture
This is an LCD television, you may find at the top of the LCD display a module referred to as a t-con module (timing control module).
There are usually two ribbon cables that make connection from the T-con to the display itself. Check these cables for corrosion or burn marks that might be preventing video passing from t-con the the display.
Apr 05, 2015 | Philips 50PF9731D/37 50 in. Plasma...
Where are the fuses in my microwave oven,?
Inside behind the display panel on a small circuit board.
Jan 01, 2013 | Magic Chef MCO160UB Microwave Oven
When turned on it has no picture but sound works
hello!
if your TV stays on, display glows, but there is no picture, most likely you have faulty t-con board and/or display itself. I've encountered the problem with both lately. I'd start with t-con(display adapter) board. it's not hard to replace and cost around $100 top. If that won't solve the problem, then it's a display panel itself. not an inverter, which is the part of power supply, but panel itself. Before replacing t-con, try to reach display's ribbon cable connectors, plugged into t-con board. disconnect first one and turn set on. If you see half of the picture, the display is bad.
If nothing changes, reconnect that cable and disconnect another one. If you see half of the picture, display is bad. If, still you don't get any picture, that's your lucky day! Display is good, t-con is bad. Replacing the display panel will void any reasonable repair option. Those crooks at "parts distribution' selling displays at the price of your TV, when you bought it: $1,500-2,000+. i don't understand why do they practice rip off. most likely to encourage customers to buy new junk and receive hefty bribes from "peoples republics" to stay in business. Anyway, it's a crazy globalism. that's why our country in default.
good luck with your project,
thanks,
Alex.
Jan 30, 2012 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
No picture Display when turned on lots of Colour lines, could this be the inverter board problem. the model is Sony TFT LCD Color Computer Display SDM-X72 Serial Number 4530624 Manufactured April...
This is not an inverter problem. The inverter only powers the fluorescent lamps in the back of the LCD panel.
It is probably a fault in the LCD data decoder circuit or a failing connector between the decoder circuit board and the glass LCD panel. If you took it in to a shop, they would probably charge you a full hour's labor minimum - compare that with the price of a new LCD monitor.
Dec 14, 2010 | Sony SDM-HS73P 17" LCD Monitor
Dropped cell phone in water. have removed battery and let dry out for 4 days. phone now works (can make calls, receive calls, keyboard lights up) except no display is available. any suggestions?
Probably need to disassemble to find the cable that runs to the screen, and it may need cleaned at the connection. If this doesn't work then chances are you fried the video portion of circuit board, or perhaps the screen itself. Hope this helps.
Oct 13, 2010 | LG Cell Phones
Fried Cable Box and TV not working
hi first call you cable company and let them that your cable box cought firer then call samsung cause you have a year if anything happens just know that you may have to pay for repairs
Jan 09, 2009 | Samsung LN52A550 LCD TV
Error P00 on display, no paper jam found
There may be a samll shred of paper stuck in the sensor, Search thoroughly.
S. Mohan
Dec 17, 2008 | Canon DR-7580
Sound proplem
its the audio amp, its fried and needs to be replaced. match the numbers up and purchase/replace boards, this will solve your problem.
Nov 28, 2008 | Dell W2600 26 in. LCD Television
Picture gets fuzzy or goes black with slight vibration.
it sounds like a loose connection with your signal but if the connection is tight i have seen loose connectors on the small signal board itself which may be resolveable by resoldering connector on signal board which would be far less expensive than replacing signal board itself
Aug 17, 2008 | Televison & Video
JVC LT-32X776 Television Logo
71 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
