My e-machine will not work.The only thing that does is the POST beep. After the beep it will stay black screen.
  • leprechaun4u May 11, 2010
    How many beeps??
  • giggins May 11, 2010
    Does it deep more then once?
  • 30 Answers
It might be your monitor, if it beeps only once like you indicated, it wouldnt be your CPU or anything else in the tower.
You might need to buy a new monitor or replace the bulb.
Posted on Dec 31, 2008
Toshiba will not boot
It needs those things to start up. If you reinstalled them in the machine and it won't start up you need to check some things:
Does the screen flicker when you power it on or does it stay completely black? If it stays completely black, then the connection from the screen to the computer itself is lost. Normally it is caused by a broken cable.
If the screen flickers and then goes black, then check the following:
Does it beep at you? If it does, then the amount of beeps is important. It will state in the users manual what that numbers mean.
If it doesn't beep, then my best guess would be that there is something wrong with the power distribution in the machine.
Sep 07, 2014 | Computers & Internet
My HP DV4000 beeps when I press the power button and the screen will stay black.
This POST error code maybe -
one long, two short beeps
  • System board failure
  • Video adapter problem
  • LCD assembly failure
Dec 04, 2012 | HP Pavilion dv4000 Notebook
VA1703wb... Monitor beeps when I turn on the pc then goes black
Please read below and look at the pictures of failed VIEWSONIC nd othe monitor before try to DIY repair.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 06, 2010 | ViewSonic VA1703wb Monitor
The only thing works on my 600 series is fan-nothing to screen
You can try reseating the memory and video card. You just pull them out and put them back in. Disconnect the power cord before. Also, the machine should beep. Those beep codes have diagnostic meanings. Listen to the beep, and google it: like 2 short 1 long or 4 short.
If the machine doesn't beep, the motherboard is bad.
Apr 22, 2010 | Sony VAIO PCV-W600G PC Desktop
When I go to turn on my polariod i733 digital camera the screen stays black and beeps three times. It never turns on. What could be wrong and how do I fix it??
i don't have a solution for you, but i am definately bookmarking this page in the hopes that someone will post one...i dropped mine tonight and it is doing this exact same thing!!!
Apr 05, 2010 | Polaroid i733LP Digital Camera
Pc used to work fine but now won't boot, post or beep. No sounds at all, just a black screen and monitor lamp stays on orange!
Check the mains power supply cable. Try to Connect with another cable. Or, the SMPS power supply unit may be at fault.
Jun 24, 2009 | Biostar P4VMA-M Motherboard
Dell Latitude CPt screen is black at startup and stays.
It sounds like your PC isn't completing its POST. (pre operating system test)
This is usually caused by faulty hardware. Your best bet is to first remove anything you have recently installed. If that doesn't apply/work, try removing various hardware devices (CD/DVD drives, memory, USB devices) until you get the machine to boot up.
If even after removing every piece of hardware possible the machine still exhibits the same behavior, it is likely a problem with the motherboard (or other "permanent" hardware).
Mar 18, 2009 | Dell Computers & Internet
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
HP DV2175 START UP PROBLEM
The beeps are part of the POST (Power On Self Test). For whatever reason, HP does not do a great job telling us exactly what their POST beep codes mean. The only thing I could find was that the 1 long, 2 short beeps on the AWARD BIOS systems means a failed video adapter. I think there is a good chance this is your problem. You will most likely have to contact HP to get it repaired.
Dec 28, 2007 | HP Compaq nx5000 Notebook
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
