Question about Navigon 2100 Portable GPS Receiver
POWER SWITCH DOES NOT ILLUMINATE GPS SCREEN WITH 12VOLT PWR.
Have Navigon 2100 GPS purchased about 3 months ago. When unit is plugged into 12volt power the units power lamp lights on the GPS and 12volt cord but the LCD screen remains unlit when the power button on top is depressed. It appears as no power is getting to the GPS to illuminate the GPS Screen. Experienced misdirections prior to unit powering down. Unit had difficulty finding my location prior to power switch not powering unit up with 12volt connection.
  • Butterball20 Dec 30, 2008
    I have the exact same problem. I keep on charging it over and over but it just wont turn on.
  • denny9526 Feb 16, 2009
    I have a similar problem the LED power light light up however the power button does not seem to power up the unit I get nothing on the screen?
Bjw122266 Have you tried holding the power button down for about 10 seconds or so?
Posted on Dec 31, 2008
Fs201
I would suggest going here and reading about your unit.
http://reviews.cnet.com/car-gps-navigation/navigon-2100/4505-3430_7-32744602.html#reviewPage1
Go through the 2 pages.
Good luck
Apr 10, 2012 | Navigon 2100 Portable GPS Receiver
My Navigon 2100 GPS lights like it's charging, but it won't turn on
I HAVE A 2100 NAVIGON GPS SCREEN WONT COME ON TRYED CHARGEING IT THE ORANGE LITE COMES ON /WONT CHANGE TO GREEN ALSO TRYED TO RESET NOTHING DO YOU HAVE ANY IDEAS WHAT ISHOULD DO NEXT .
Jun 30, 2011 | Navigon 2100 Max Portable GPS System
My navigon 2100 doesnt work after the update. help
I own a navigon 2100 as well. Very nice device and you can install the 5100 software and the 7100 maps and points of interest. gpspassions.com is the best resource for 2100 help.
Try this:
Hard Reset Procedure - if the PNA is on, press the Power button until the unit goes off. Press again and hold the button down - the screen will come on and after a few seconds go off again. Press the Power button again and the screen will come back. If you get the opening "music", you know the Hard reset was successful.
If you leave the memory card out and keep the unit powered on, you will after a few 10's of seconds go into the Demo mode. When you reinsert the SD card a soft reset will occur (equivalent to pressing the recessed button on the left hand side) and the unit will initialize into whatever the SD card tells it to (see below).
source:
http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=101685
Apr 13, 2011 | Navigon 2100 Portable GPS Receiver
Navigon 2100 car charger unscrewed. Found a few
[PDF] NAVIGON 2100/2120 User's Guide Your NAVIGON 2100/2120 comes with the following accessories. .... With the NAVIGON 2100/2120, you can also use an external GPS antenna (not pro- ...
support.navigonusa THEIRS A SITE FOR YOU YOUR FUSE IS A 6V 1 A RADIO SHACK SHOULD HAVE ONE OR PACK OF 5 6 BUCK OR SO
May 08, 2010 | Navigon 2100 Portable GPS Receiver
I purchased a Wii console about 5 months ago. I never played the thing because I dident have any games. I just recently got a game, went to turn it on and there was no lights and it wouldn't turn on. I...
First, Check your wii adaptor, In normal conditions the wii adapter provides the output 12volt. You can test the output using multimeter or a 12volt lamp.
then
plug it into the outlet, If the light is still off/flashing, disconnect the AC Adapter unplug from the wall outlet, wait 2 minutes and plug it back into the outlet. Turn the console power ON.
hopefully this help..
Mar 05, 2010 | Nintendo Wii Console
Navigon 2100 freezes when plugged in
sounds like you have the wrong charger did you buy a non gen one? you can charge it from the pc with mini usb lead, but will show the same screen
Dec 06, 2009 | GPS
Navigon 2100 displays the computer symbol when connected to charg
Wiring diagram pinout for Navigon GPS charge and concurrent use Pin Pin
Name Description 1 +5V 5 Volts Direct Current 2 Data floating/Not connected 3 Data floating/Not connected X Ident Conneted to Pin 4 (GND) as pure short, no resistor 4 Ground Ground, shorted to pin "X" Use of standard mini-b will place unit in Data Exchange/Synchronization mode. Use of mini-b with a 4-x pure short will allow use of Navigation software and concurrent charging. USB power source must be 1000 ma or above.
Sep 13, 2009 | Navigon 2100 Portable GPS Receiver
Need users manual for navigon 2100
we purchased a used navigon 2100 it did not have a user manual with it and we would like to have one
Feb 20, 2009 | Navigon 2100 Portable GPS Receiver
Plug in car charger and it shows navigon connected to computer
The problem lies with the fact that a standard mini usb pin-out has + voltage on pin 1 and ground on pin 5. The navigon is programmed to recognize this as a computer. The navigon charger however has + voltage on pin 4 and ground on pin 5. The reason for navigon doing this as opposed to following the standard pin-out is due to the unit requiring a stronger power supply to charge the battery. USB current output on a computer does not have the capacity to do this. As a consequence, you will have to find a charger that has the right pin-out for this device ( + on pin 4 and - on pin 5 ). The tough thing is, there is no way to tell one from the other, they look identical. However, I have found that chargers with a capacity of 1000 ma or greater are pinned-out like above ( + on pin 4 and - on pin 5 ). Other than using a multimeter to verify the pins, the only thing to do, would be to plug it in and see if it works. Hope this helps.
Dec 28, 2008 | Navigon 2100 Portable GPS Receiver
Navigon 2100 text to speech not working
the same happened to my 2100 3.5 inch. any remediatons?
Nov 14, 2008 | Navigon 2100 Max Portable GPS System
Navigon 2100 Portable GPS Receiver Logo
216 people viewed this question
Top Navigon GPS Experts
roedene
Level 1 Expert
Will Halftowaite
Are you a Navigon GPS Expert? Answer questions, earn points and help others
