Question about Emerson MBOX700 Portable Headrest Monitor with DVD Player Car Video Player
Help When you place the disk in the player, you can head a small sounds like a clicking, while it is loading, then it will come up bad disk
0 characters
1 Points
Why player won't recognise disc
Several things can cause a disk not to read. You could have a bad disc, the wrong type of disc, the disc might not be finalized, the laser pickup could be dirty Try cleaning with a disk cleaner Other problems include bad or weak lasers the spindle motor could be bad ,the disk in detect switch could be dirty. The disk may not be loading into the proper position.These are the more common problems
Aug 07, 2014 | Nesa Vision NSD-790T Car DVD Player
I got a Jensen VM9020TS Car DVD Player ,i have a problem with it , why i can't play dvd when i inserted it is said loading but nothing happen?
Please try to put in an ordinary audio CD track and see if this is detected. If yes the optical is working, if not there is no laser scanning and the possibility of the head being faulty is high.
Now certain cleaner disks are not read and so will not be tracked.Try to open and do a cleaning manually of the laser head eye with a cotton bud very softly and without any pressing of the lens eye.
make sure that the Cd is loading into the drive and sets into the head if not the loading mechanism has some errors and must be reset for proper loading into the slot. possible obstruction or dirt accumulation must be checked.
Dec 10, 2010 | Jensen VM9020TS Car DVD Player
My kvt617 will not accept the cd or dvd what is the problem and solution?
I have this head unit and found that the load tray is a little off,I use a second cd/dvd to assist in loading and it has worked everytime.put the disk in you want to use and as its loading give it a light bump with the second disk...Hope this helps
Aug 27, 2010 | Kenwood KVT-617DVD Car DVD Player
My Cd is stuck inside my DVD player and it wont come out, but it will playthe cd? What do i do?
you may have to take it to a professional to get it out if anything because there is a trick if you go to eject the disk and you see just a small piece of it where it comes out from try stick a flat hard object like a small flat head screw diver or the tip of a knife under or over the disk and push up or down and pry it lightly out but you risk scratching the disk and ruining the disk. if you know how to open it up without damaging the internal parts then you have to open it up and supply power to the deck then when you push the eject button try to help the disk out of the deck. I hope i have answered your question, if so please vote and leave high marks. Thank you very much.
Aug 03, 2010 | Phase Linear UDV9010 Car DVD Player
Put in disc also same same
Google manual and model number to download a manual.
It sounds like the DVD player itself is not working, maybe you can see if the laser unit moves if you hold down the "closed/open" switch, DO NOT LOOK directly into the laser, it will damage your eyes, tilt the unit so you look in from "the side".
If it does not move try to touch the slider to see if it just needs a little help, remember it is fragile, it is positioned and moved by small plastic finns (do not know if it is the right word).
May 02, 2009 | Dual XDVD270 Car DVD Player
Bad disk
Wow! That's a first. I used to sell both the Jensen AND Phase Linear versions and never a problem. It sounds like a bad unit. You say it plays NOTHING? No CD's OR DVD's that are the factor made?
The only thing I hav up my sleeve is to do a reset on the unit. If it has a button (I don't think it does frm what I remember) use it first, then with the unit ON, unplug the poer plug, wait a few, then plug back in and see.
Sorry I have no more tricks foir that,
Larry T
Winona Lake, IN
Jan 26, 2009 | Jensen VM9510 Car DVD Player
Jensen 9410 will not load or eject
i had my jensen three weeks everything was okay until all of sudden the unit wounld not load or eject CD's or DVD's
Mar 20, 2008 | Jensen VM9410 Car DVD Player
Chrysler voager radio install
you have the "special" infinity system the uses a data signal to turn on the amps.. no easy way to get around it. time to rewire the van.. sorry bro... hate being the bearer of bad news.
Feb 22, 2008 | Pioneer AVIC-N2 Car DVD Player
Pdm-2727 portable dvd player
Check out my other post here:
Dec 19, 2007 | Car Video Players
Emerson PDE-2725N DVD player
My PDE 2625n worked on the way to Mimi's and starting on the way home it displayed "Disk Loading..." then errord out with "Bad Disk". I dug through the internet and over 3 days found the answer.
Your laser is tired. Since the DVD player is cheap, replacing it is not worth the $$. Fix it! Remove the back cover (about 10 small phillips screws). It is important to know that their is a back plate AND a back panel; remove the PLATE which should have a model number sticker.
Now you should see a circut board with a set of polished rails which holds the read head. On the read head (by a ribbon cable ) are two very, very, very small flat blade POT screws. These control the amount of power sent to the laser. Turn the right most one CLOCKWISE about a 1/8 to 1/4 turn.
You can test your handy work by popping in a DVD while the cover is off and seeing if it loads. If all is ok, put it back together. If not turn it a little more. I used a car battery charger to run my test since it's about 25 degrees outside.
Be aware the more power sent to the laser, the faster it burns out (according to my research). By feeling is the DVD player is broke, so what? Am I going to break it? What the hell;) and I cranked away.
BTW I just got this fixed this morning. My kids are screaming with joy for DVD's in the car again! I'm thrilled that I don't have to spend $100 or more to replace this unit.
Nov 16, 2007 | Car Video Players
Car Video Players Logo
21 people viewed this question
Top Emerson Car Video Players Experts
xxxxxx xxx
Are you an Emerson Car Video Player Expert? Answer questions, earn points and help others
