Question about MicroBoards DX-1 Publisher Printer
DX1 does not print label from Sure Thing
This DX! prints test disks and allignment patterns but will not print label files from Sure Thing files. All drivers check out OK - printer is on line - it previously worked on a previous installation on a different HD that went bad - this is the first install and set up on this HD but everything checks out.
The DX1 drops the disk to the HD tray, and takes the disk into the HD (I am doing label printing only with the DX! - not data burning), the disk then comes out of the HD and drops on the belt - the belt moves back and forth a little, then moves up to the print position where the lazer light senses the leading edge - then it stops for a nano second, then speeds off into the output bin with no printing.
When I print a test disk using the Zulu2 Robitics Utilities option or print an allignment test grid it does everything just perfect but when I then tell the Robitic tab to do print only, then Browse to select the label from SureThing - the label name then comes up in the Print Only Print File Name window, I put in for 5 copies to be printed - it goes through all five with no printing on any of them.
One question - where does the DX1 printer get the data to print the test disks and the alignment grid lines? Are these files stored in the DX1 or do they come from the software in my computer? If these two files come from my computer then why not the print data fopr the labels - on the otherhand - if these two files are stored on the DX1 memory that would indicate a communication problem between the DX1 and my computer (I am running XP with SP2 installed)
Any help will be greatly appreciated!!
I'm Eric, WhoRU??
techwaredist
  • 30 Answers
SOURCE: only 1 copy at time
The previous poster is most likely correct. You have to use Microboards ink for the PF-2, PF-3 and PF-Pro printers. The part number you need is the PRF38ml. The PF-2 printer has a sensor for the barcode on the PRF38ml as well as a RFID chip for verification.
If this does not fix your issue, then the sensors that scan the barcode and the RFID chip may be broken, dirty or out of alignment. If so, you need to contact Microboards or an authorized Microboards repair center for repair services.
Posted on Jun 17, 2008
After repacing cartrideges --it constantly states to press enter to allign cartridegs--and the printer will not print
I have the same printer and it does the same thing... make sure you have paper in and click the ok button on the face of the printer. It will print out a pattern, put the pattern upside down facing back in the scanner and hit ok again. This will align your cartridges and allow you to print once again.
Oct 10, 2010 | HP PSC 2175 All-In-One InkJet Printer
Microboards DX1 input problems
Microboards' New DX-1 Disc Publisher to Ship Microboards’ New Print & Burn DVD/CD Duplicator Ships
Industrial quality of DX-2 and Print Factory in a Compact Package with the DX-1
Chanhassen, MN, August 17, 2004 —Microboards is shipping a new disc creation system (MSRP $2,995) with a high-speed DVD/CD recorder and industrial printing technology from HP to give users professional publishing in a petit package. Combined with custom label design and recording software, the system makes in-house disc creation easy and inexpensive.
You've got an expensive unit (see below for Press Release), with a built-in CD/DVD reader/writer.
Given that your unit could be six years old, it's possible that the reader/writer has "died".
It seems to be a "stand-alone" unit -- not something that requires either Mac OSx or Windows XP/Vista/7 to operate.
I'm guessing that _ANY_ IDE (not 'SATA') HP-brand reader/writer, provided that it has a "LightScribe" capability, could be purchased, and could be inserted to replace the "dead" reader/writer. For about $100, it's worthwhile to try this "substitution" to revive your unit.
____________________________
Chanhassen, MN, August 17, 2004 — Microboards is shipping a new disc creation system (MSRP $2,995) with a high-speed DVD/CD recorder and industrial printing technology from HP to give users professional publishing in a petit package. Combined with custom label design and recording software, the system makes in-house disc creation easy and inexpensive.
Jun 10, 2010 | MicroBoards DX-1 Publisher Printer
Z4m printer problem
You may have an element or two on the left side of the printhead that is worn out and not printing. The best way to see if elements are not working is to use the widest label you have and run the PAUSE test. Turn the printer off, press and hold the PAUSE key while you turn the printer on. Keep pressing for about 10 seconds and then you can let go. When the printer is finished starting up, a test pattern will print. Part of the pattern is a black box. Any elements that are not working will show as white vertical lines. The only way to correct is to replace the printhead.
Hope that helps !
Jun 09, 2010 | Zebra Z4Mplus Label Printer
Hi There How do you print a test page from the Zebra printer itself which shows print head condition etc We've used teh self test print but are lookign for somethign more detailed etc. many thanks
Printing the "PAUSE" test will print a nice black box that will show white lines or voids for any printhead elements that are not functioning. Turn the printer off, press and hold the PAUSE key while turning on the printer. After 5-6 seconds, let go of PAUSE and let the power up self test finish.
The test label will starting printing. To stop, press PAUSE. This is also usefull for seeing the "parallelism" of the printhead by looking at the lines that print at the begining of each label. Should be the same number of lines on the left as the on the right.
Easiest way to cancel the pattern is to cycle power.
Hope that helps !
May 04, 2010 | Zebra 140XiIII Plus Thermal Label Printer
Labels unexpectedly stop printing half way through a job
Located winder further away from printer. Set winder to lowest possible speed setting. Thoroughly cleaned printer to remove any trace of label residue near print head and label cutter (sticky labels with pre-cut patterns are being used). No more problems reported. Will continue to monitor.
Jun 02, 2009 | IBM Infoprint 6700 R40 Printer
Test Page
thats not the test page that is allignment page which is printing.
keep the the printed side of that page which comes out on the scanner glass.press the ---scan ---button.the on /off light will blink, wait till it stops blinking.and after that everything will be normal.
for any thing else let me know.
thanks.
Sep 17, 2008 | HP LaserJet 1200n Printer
Okidata - label printing alignment
The solution posted did not work for my problem. Thanks for trying.
Aug 08, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Print Disc Labels
that's in your print application..make certain that it's the identical template for your labels.even small variations translate to errors like this.
start with printer driver updates here
Feb 04, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Installation disks
Here is the link for the driver:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:435:0:0
Just select which operating system you have and then you should be able to download and install.
Nov 08, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Scanner bar jammed by cartridge allignment
Any fix for this I have the same issue?
Dec 11, 2006 | HP PSC 2110 Color Printer
160 people viewed this question
Top MicroBoards Office Equipment & Supplies Experts
Starnley Johnwells
Starnley Johnwells
isaac johny
isaac johny
Are you a MicroBoards Office Equipment and Supply Expert? Answer questions, earn points and help others
