Question about Xerox Phaser 6130 Printer
Print quality my printer is brand new and it is printing steaks and also some pages that I printer is clonked on the paper.
The problem is that the printer is set to print on default paper.
When you use photo or other specialty paper, especially when the thickness is greater than inexpensive copy paper, the print heads need to match the paper.
Go to the control panel on the printer, and enter the type of paper you're using. Your problem of streaking will disappear.
Posted on Jan 22, 2009
Why do I get bleed through of print on pages I print out at bottom of page or shadow print on some?
Paper is too thin (use higher "pound" paper).
-or-
Toner is not of good quality (use HP Brand if possible)
-or-
Printer is set to dark or heavy in your page setup (change to normal or even light)
You can also make sure you are using an HP print driver instead of a generic print driver. Go to HP.com and search print driver for you model, download and install (if you don't already have an HP printer driver loaded on your PC).
Jul 29, 2014 | HP LaserJet 3050 All-In-One Printer
My printer will not accept photo quality paper
The printer should accpet every paper only requires adjusting the feeder area fo every new brand paper that is inserted on device. Inspect the devices feeder compartment for appropiate size requested of the paper. Also, the printing paper has size adjustment details required to fit into the printer. Once observed, the feeder compartment would require manually adjusting to fit new paper size to achieve printerbility. Also, power on the computer to test print the new adjustments. The printer commnads too allows to sleect the appropiate shapes requested considerign the type of pape inserted in feeder comparments. Circumspectively, perform printer feeder compartment adjustments and test print a page to ascertain the most possible condition ot the new settings.
Feb 04, 2011 | HP PSC 1410 All-In-One InkJet Printer
I NEED TO PRINT DOUBLE-SIDED ON AN hp3150 LASERJET. hOW DO i DO THAT?
Follow these steps to change print settings, and then print in Mac OS X 10.6. Step one: Select your product
  1. In the program from which you want to print, click File , and then click Print . Figure 11: Click File, and then click Printc02458420.jpg
  2. Select your product from the Printer: drop-down list.
Step two: Change print settings
  1. Type the number of copies to print in the Copies text box.
  2. If you want to print multiple copies, select the Collated check box to print the pages of each copy in order.
  3. Select the pages of the print job that you want to print. To print all pages, select All. To print a specific range of pages only, type the page number that begins the page range in the From text box. Then, type the page number that ends the page range in the To text box.
  4. Select the size and type of paper loaded in the product from the Paper Size drop-down list.
  5. Select the orientation for your print job. To print in portrait orientation, click the icon on the left. To print in landscape orientation, click the icon on the right.
Step three: Change the paper type and quality settings
  1. After the Orientation section, click the drop-down, and then select Paper Type/Quality . NOTE: This drop-down usually defaults to the program specific drop-down. In this example, the drop-down is the TextEdit drop-down. Figure 12: Select Paper Type/Qualityc02458421.jpg
  2. Adjust the Paper Type setting to match the paper loaded in the product.
  3. Adjust the Quality setting to change the print quality of the printed page.
  4. Select Print Borderless to print photos without a white border.
  5. To change the color profile or to turn on Photo Fix, click the arrow next to Color Options to display the Color Options menu. Figure 13: Color Options menuc02458422.jpg 1 - Paper Type/Quality menu options 2 - Color Options menu (only available if you click Color Options)
Step five: Print the print job After all the settings match the needs of the print job, click Print on the Print window to print the document or print job.
Dec 26, 2010 | HP Photosmart C3150 Printer
Printer full of ink, but will pring pages either blank of with smeared ink.
Follow these steps to check the print settings for your print job.
  1. In the software program you are trying to print from, click File and then click Print . The Print dialog box opens.
  2. Select your product, and then click Properties . The printer Properties dialog box opens.
  3. Click the Printing shortcuts tab.
  4. Under Printing shortcuts , click the type of job you are trying to print.
  5. Review the following options, and then make any necessary changes.
    • Paper size : Make sure that the selected option matches your paper size.
    • Paper type : If one of the options matches your paper type exactly, select that option.
    • Print quality : If you are not satisfied with your printed page quality, or want more densely printed prints, increase the print quality. To print more quickly, or for lighter prints, decrease the print quality.
  6. Click the Features tab.
  7. Check the Print in Grayscale setting
    • If you are trying to print in color, select Color Options , and then make sure that Print in Grayscale is not selected.
    • If you are printing a black and white image, select Print in Grayscale to fix streaking in black areas.
  8. Click OK , and then click OK again to start the print job.
Make sure the printer is loaded with unused white paper.
Open HP Solution Center , then click Settings , then Printer Toolbox .
Select the Services tab.
Click Print PQ (print quality) Diagnostic Page .
Select the Services tab, then click A- Click Align Printheads or
B- Click Clean Printheads .
C- Click Calibrate Linefeed .
If, after repeated printhead cleaning, the Print Quality Diagnostic page shows white lines across the color blocks in Test Pattern 2 (but no white lines in the gray blocks in Test Pattern 3), one or both of the printheads will have to be replaced. The Print Quality Diagnostic page shows which printhead should be replaced.
Try using the HP Scan Diagnostic Utility in Windows - HP Customer Care (United States - English)
Nov 16, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
I am engaged in a colored printing project on my HP Deskjet 6940, and am having trouble with the quality. I am using 8.5" X 11" paper, (inkjet/laser brochure-flyer paper, 96bright, 45lb). The project...
This could be a problem with the paper your using. Try another brand of paper that is recommended only for the inkjet printer. Paper that is meant for Laser does not always work will with inkjet printers as it is made to handle toner and not ink.
Some paper I suggest is the HP Brochure paper C7020AC 48lbs which is recommended for your printer by Hewlett Packard. If not available try and see if you can get something similar that is only for inkjet printers. 8.5 x 11 in, 48 lb, 100 sheets C7020AC
Jun 04, 2010 | HP Deskjet 6940 InkJet Printer
Phaser 8560 magenta ink not transfering to paper
Hi jbasset285: Your printhead may be bad do to third party ink.
Try these steps first.
Diagnosing Print-Quality Problems
The Troubleshooting Print-Quality Page provides a good overview of the most
common print quality problems. To print the Troubleshooting Print-Quality Page,
follow these steps:
1. From the Control Panel, scroll to Troubleshooting, then press OK.
2. Scroll to Print Quality Problems, then press OK.
3. Scroll to Troubleshooting Print Quality Page, then press OK.
The Troubleshooting Print Quality Page includes instructions for printing the
Eliminate Light Stripes test print. These instructions are also provided on the next
page of this manual. The Eliminate Light Stripes test print indicates individual weak
or missing jets or an obstruction in the imaging path that affects a vertical band down
the entire page. Also, you may see color variation from jet to jet on the Eliminate
Light Stripes test print. Some variation is normal, occasionally occurs, and usually
self-corrects within a few printed pages. If a print-quality problem is not resolved
with the information provided in the Diagnosing Print-Quality
Nov 26, 2008 | Xerox Phaser 8560DN Laser Printer
Paper rolls up
You have a humidity issue with your paper. Buy or open a fresh **** (sealed) and try printing again. If your paper is stored in a cool place move it to a warmer area. Paper tends to pick up moister over time, especially when cold and will curl when printing. The paper is actually steaming when it hits the fusing (heating) section in the back of the printer. The curl is because one side of the page is drying faster than the other.
If you have a case of paper and open a fresh **** with similar results, buy a new **** and try again. When selecting your paper buy good reliable paper. I recommend "HP Office" branded or better. I say stay with HP Brand paper as it's manufactured to a tight quality standard than most and is a "known good" paper. STAY AWAY FROM STORE BRANDS as they go out on low-cost bids and the quality varies widely on whoever got the contract this time.
As a more positive note, If you use a good paper in your printer, your drum cartridge (expensive) and toner cartridge (not cheap) will actually last much longer. You'll save more (much more) in the long run.
Hope that helps you.
"A little free help from a tech fixing 10 to 15 printers a day for 13.5 years."
Aug 18, 2008 | Brother HL 5250DN Laser Printer
Self cleaning and print test sheet
To print a test page, from ready press the go button. There isn't a cleaning page or drum cleaning cycle on Brother printers.
Brothers are notorious for having bad toner and drum issues. They are very finicky about paper quality. What happens is when a lower quality paper is used the higher paper dust and talc gets caught up in the charging brushes of the drum. Brother has no waste sections in their cartridges or drums so the built up junk stays right in the charging brushes and causes the drums to fail. On the toner cartridge side it re-uses it's waste toner adding it back (with the paper dust and talc) into the fresh toner supply area. Eventually the cartridge contaminates itself to the point of causing imaging problems.
Best recommendation after over 13 years fixing printers to you is to use GOOD paper at all times with Brother printers. Brands tend to fluctuate wildly in quality but the most stable brand to look for is a HP (Hewlett Packard) brand paper. They tend to keep the tightest control over paper with their name on it than others I've seen. HP "Office" paper is relatively inexpensive and will save you much more in the long run than buying cheap paper. STAY AWAY FROM STORE BRAND PAPERS OR XEROX 4200.
Aug 11, 2008 | Brother HL 5250DN Laser Printer
Print quality problem
Hi there sound to me like the toner cartridge is either faulty or leaking. Is it or has it been refilled if so remove cartridge vacuum out the insides of loose toner install brand new toner cartridge then test again. It cannot be the fuser unit as it will have quality problems all the time so try above and I hope it works for you.
Thanks J
Jan 14, 2008 | HP LaserJet 2420 Printer
Xerox Phaser 6130 Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
