Question about Palm Tungsten E2 Handheld
Palm ungsten E/E2 digitizer - fragile?
Digitizer on my Tung/E skewed so bad had to touch an "a" to get a "z", only effected lower L /upper R, opposite corners where the unit calibrates were fine. replaced with a new Tung /E2, started doing the same in 3 months then digitizer failed completely during a calibrate sequence - all other atributes function. is the digitizer a weakness in this series that makes it risky to buy the part and replace it myself? if not, do you recommend digitizer/LCD combo or just replacing the digitizer? is there any after market SW to upgrade the digitizer formating to calibrate all corner points like my antique Palm had years ago? thx
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
Your gonna find that with the exception of the battery, all else should be left to the factory if nothing else but for factory warrantees. Your probably putting static electricity into the unit and they don't like that.
Posted on Dec 30, 2008
Tip
Formatting SD card for E2
1. Click on time in upper left corner
2. Select info
3. On device drop down select sd card
4. Lower right corner select MORE
5. Click on card info tab
6. Select Format
If it doesn't come up, the card is toast for this unit
on Jan 02, 2009 | Palm Tungsten E2 Handheld
Tungsten e2 is always looping on the stylus calibration screen
actually ur Digitizer is faulty u can replace it urself cost around 25 $ or so do u want to proceed let me know , unless u change the touch panel digitizer u will be stuck at align screen thing
let me know if i can help more
RATE ME WELL !
Jun 02, 2009 | Palm Tungsten E2 (Multilingual) Handheld
I have a moving target on screen and can't access anything else?
pls try to hard reset like this if it helps see the link
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?New,kb=PalmSupportKB,t=ooccase,case=obj(15574)
if problem persists then yes u are gettin screen alignment problem bcoz of digitizer fault it is faulty u have to get it replaced but i dont think it is worth if warranty is out if u really want to do it then go to below link
http://cgi.ebay.com/Palm-Zire-71%2F72-Tungsten-E%2FE2%2FT--Touch-Screen-Digitizer_W0QQitemZ220375121035QQcmdZViewItemQQimsxZ20090310?IMSfp=TL090310122012r31943
http://www.bizrate.com/pdaaccessories/products__keyword--palm+e2+digitizer.html
I Recommend the Following Tools for this Repair
  • Case Opener Tool - Part Number: XX1521
  • Torx Driver - T5 & T6 Driver Set: XX1127
  • This is a complete screen for the Palm Tungsten E2 unit. This includes the LCD and Digitizer.
  • This is a refurbished screen and comes with a 30day warranty.
  • This screen will only work with the Tungsten E2 units and NO other models. All sales are final. No exchange refund or return. There is a 30day warranty with this item directly from PDAparts.com.
    FREE INSTALL DIRECTIONS
  • see the Video here
  • http://www.youtube.com/watch?v=ECCXp2dnuW4&eurl=http%3A%2F%2Fwww.gethightech.com%2FMerchant2%2Fmerchant.mvc%3FScreen%3DPROD%26Product_Code%3DPA1995%26Affiliate%3Dfroogle&feature=player_embedded
  • PLS RATE ME FIXYA FOR THE HELP
    Mar 20, 2009 | Palm Tungsten E2 Handheld
    A problem with Visat and my Palm Tung E2. When I
    You may try to uninstall all previous installations and install latest version of Palm Desktop from http://kb.palm.com/wps/portal/kb/common/article/33529_en.html after installation connect the cradle USB to different USB port and try again
    Mar 08, 2009 | Palm Tungsten E2 Handheld
    Tungstun e2 touch screen not working
    Perform hard reset. Press on and reset at same time. If this was helpful, please post as such. If it fixed it.....fixya. TY
    Jan 19, 2009 | Palm Tungsten E2 Handheld
    Palm Tungsten E/E2 digitizer - fragile?
    Palm one is in trouble because of problems like this. They don't work on it but you can buy parts to try it yourself. I never had the problem myself but similar conditions. I do windows based units now.
    Dec 30, 2008 | Palm Tungsten E2 Handheld
    Can I sync an Ipod touch with my Palm Desktop for windows?
    I don't believe that the Palm desktop manager is compatible with Ipod. Unless you have your contacts associated with Microsoft Outlook, that should work.
    Dec 27, 2008 | Palm Tungsten E2 Handheld
    Palm Tungsten e2 and duracell 1 gb memory card
    Thall shalt format card for E2
    1. Click on time in upper left hand corner
    2. Select info
    3. On device drop menu select sd card
    4. Lower right corner select more
    5. Upper right select card
    6. Select FORMAT CARD
    If you can't format...the card is toast
    Dec 13, 2008 | LG Shine KE970 Cellular Phone
    Palm Tungsten E2
    The top digitizer is defective and needs to be replaced.
    You can find digitizer parts in ebay or other on-line companies, at reasonable prices.
    Regarding the labor cost, depending of the repair shop you choose, it may be cheap or expensive.
    Also, if you have minimum experience and skills in fixing electronics, you can try it. really is not so difficult, and minimum set of tools are needed for it
    Best regards,
    Sep 26, 2008 | Palm Tungsten E2 Handheld
    Palm Tungsten E2 Handheld Logo
    129 people viewed this question
    Top Palm Computers & Internet Experts
    Michael Vincent Cruz
    Don Eagan
     steve
    steve
    Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
