Question about SanDisk 2GB microSD Memory Card
How do i format my scandisk - SanDisk 2GB microSD Memory Card
  • 2 more comments
  • Anonymous Feb 21, 2009
    im triing to format my memory card for my phone, so i can play my music.it has to be a wave format.
  • Anonymous Mar 20, 2009
    I CANT FORMAT MY CARD
  • sweetdreamz8 Apr 10, 2009
    I have a Blackberry 8310 phone and I bought a SanDisk 2GB memory card. I put it in and it it says "Media Card cannot be read. Verify that the memory card is formatted." So I went to options and selected Media Card, then I clicked the menu button and selected "Format Card." I waited for more than 10 minutes and nothing happened, my phone froze up...I couldnt scroll to select anything with the tracking ball. So I took out the battery and memory card, and put the battery back in to restart my phone, to get it to work again.
    What should I do to get my memory card formatted correctly and working?
  • Anonymous Apr 12, 2009
    I can't format my memory card
    President:
  • 949 Answers
If you are only using the card in a PC then when you plug the card into pc,it shows as a drive under my computer,you rt on the drive and pick format, fat.
If you are using a sd card for anything else such as a phone, you format the card with the phone,or whatever devise it is being used in, and you DO NOT format the card with the PC.
Posted on Apr 10, 2009
  • SanDisk Master
  • 6,487 Answers
If this memory card will be connected to a camera you can simply put the memory card to the camera and there you can format it using the camera's menu, you can also format this memory card using a card reader that will be connected to your computer, just put the memory to a card reader then connect it to the computer that way you can also format the memory card....
Posted on Dec 29, 2008
I can download free audiobooks to my macbook pro, how do i transfer them to my sandisk sana clip
Connect the supplied USB cable from your player to the USB port on your MAC. The MAC will detect this player and your can then copy the audiobooks from the MAC to the Scandisk.
If the Scandisk cannot play the audiobooks then they are in the wrong file format. Then they need to be converted to the file format that the Scandisk uses.
Nov 05, 2012 | SanDisk Sansa Clip MP3 Player
Formatted scandisk in casio camera
Unfortunately, yes. That is why we always advice to back up all data before proceeding with the format.
Jun 16, 2010 | SanDisk 1GB microSD Memory Card
Scandisk 4gb ultra car will not format in any of my cameras
put the card into a card reader and format it using your computer...
Jul 21, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
Scandisk for blackberry cruve
To delete all the data, go into Options / Security Options / General Settings, clik the wheel and then click Wipe Handheld.
This will remove all of the DATA, and not any of the applications.
Apr 04, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Garmin does not read scandisk 2 gb.
it might be due to the fact that you garmin cannot read AAC music format(the format itunes uses). try using windows media player to rip the CD then put the music on the card using windows media player. this should take care of your issue.
hope this helped.
please rate good.
Nov 12, 2008 | Computers & Internet
Error 30
The "E30" error code indicates reading/writing data on a SD card has failed. Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the SD card with your camera Try to format the SD card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card. Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
Aug 31, 2005 | Canon PowerShot SD300 / IXUS 40 Digital...
Error 30
Aug 31, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
Error 30
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
Error 30
Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
Error 30
Aug 29, 2005 | Canon PowerShot SD100 / IXUS II Digital...
SanDisk 2GB microSD Memory Card Logo
666 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
