Question about JVC AV-30W776 30" TV
Pressed button on remote and can't watch cable now.
I accidentally pressed a button on my tv remote and now i can't watch cable tv, i can still watch DVDs and play video games though.
Sounds like you make have change input to antennae tv, go to tv-cable setup and highite cable and enter that, if you have instrution book, it will help.
Posted on Dec 29, 2008
My tv remote is not working inasmuch as I am unable to change channels. Tv is on BBC 1 and that is all I can watch
You go buy a universal remote and test your patience by typing in each of several codes for you TV until you find one that works. Some TV sets or attached boxes allow cable changing manually. Others do not.
But before you do that, make sure you have pressed either CABLE or TV at the top of your remote. You possibly have accidently pressed a button to control the DVD or some accessory device, rendering the remote unable to control the TV.
I might try to "autotune" the TV, i. e. preset the setup menu that causes it to search for the channels which the TV can receive. Something possibly may have happened in that realm.
And, you might even call your cable provider and ask them to reset your cable connection. You see, the problem might not be in the TV or the remote.
Good luck.
Aug 08, 2017 | Televison & Video
I've had my Sony Bravia 52EX701 for over 3 years. We have two remote controls. The main one we use is through our older Bose Home Theater System to control the TV, etc. The Bravia remote is also activ
Maybe there has been a disconnect with the TV recognizing the code of the remotes? Or, maybe you pressed a button on the remote that will not allow it to change the channels. I've done this in the past where I accidentally pressed, say the TV or DVD button, and when I turned the TV on and tried to tune in channels, the TV would not respond. Pressing the cable button (but that is on my remote) returned the remote to its ability to change the channels. You will just have to do trial n' error.
Nov 30, 2014 | Sony Televison & Video
Restore Sony KDL32L5000 to factory defaults
• Check the input selection by pressing the INPUT button. You may be watching the wrong input.
• If you cannot hear sound from the TV, you may have accidentally pressed the MUTING button on your
remote control; press the MUTING button again or press VOL + to deactivate muting.
• If the remote control is not functioning properly, the batteries may be installed incorrectly or may be low or
an object or light may be interfering with the remote control.
• To reset the TV to factory default settings:
1 Turn on the TV.
2 Press and hold down the V button on the remote, press the POWER button on the TV set. (The TV
will turn itself off, then back on again.)
3 Release the V button when the TV is turn on.
WARNING: The factory reset will clear all of your customized settings including the Parental Lock setting.
When the Password is lost or cannot remember, enter the master password: 4357. This password clears your
previous password and allows you to enter a new password.
Jul 08, 2012 | Sony KDL32L5000 32 in. LCD HDTV
I accidentally pressed a wrong button when I was changing back to TV after watching a video. then the screen became snowy and I'm unable to get back to TV mode. I need help!
Hello rgas,
do you know if you have cable or satellite? Look on your remote and for a button called input or source and click on it. Remember what input it is set on first then try changing through each input. See if you get anything. If nothing still, go back to the original input it was on and change the channel to channel 3. If you have cable or satellite, turn it on. If nothing appears, go to input/source scroll through each input and hopefully you should get a picture. Good luck.
-Joe
Aug 30, 2011 | Televison & Video
When I turn on TV I get a message no video input. We never use video with this tv. Only have it for looking at satelite. The other main tv is working fine. I pressed all the buttons but nothing works.
Sounds like the input accidentally got changed. On the remote that came with the TV, push the INPUT button until you get your satellite picture again. If your SAT. remote is programmed to your TV, push the TV button, then the input button until you see your picture. If this doesn't work then the sat. cable is not securely attached or no longer works.
Aug 30, 2009 | Philips Magnavox 27MS343S 27" TV
Lost the controller for Pioneer rear projection TV
Try pressing the "Input" button the front of the set. That should allow you to change between the different inputs. The return button usually returns you to the previous channel you were watching - don't think it works for the input though. Also, depending on the model of the set you have, try downloading the PDF user or owners manual - it will tell you how to use the remote.
Jul 25, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Auxiliary button on tv remote (I believe) needs off and I can't get figure out how...
The remote should have TV, VCR, AUX and maybe CABLE buttons at the top, one of which will light up when any button is pressed. Since it is a universal remote, the button at top lights up to let you know what mode it is in. If the AUX button lights up when any button is pressed, it means the remote is currently set to the AUX mode. To set it back to TV, simply press the TV button at the top. This puts the remote back in the TV mode and the TV button should now light up when any button is pressed. If that works and you are using a cable box with that set, then make sure the TV is on channel 3 by pressing 3 ENTER.
Sep 21, 2006 | Zenith C27A24T 27" TV
JVC AV-30W776 30" TV Logo
83 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
