The @ sign does not work on my hp keyboard
I am trying to set up a new hp laptop
  • lmitch Feb 22, 2009
    My acer keyboard has suddenly decided that the @ key does not work you just get ". @ is now at shift 2. The hash key is also playing up. Help.
  • Anonymous Mar 20, 2009
    slimlink mini keyboard as2366 will not allow me to have @ sign
  • 56 Answers
When you press the @ sign do you get " if so @ sign is got by pressing shift & 2 if you get different symbol look through your keyboard for that one
Posted on Dec 29, 2008
Use the alt key, i dont know why, but it works
Posted on Sep 06, 2009
  • wendy Aug 14, 2013
    no... still doesnt work!
How to make at sign work on asus laptop?
If your @ sign is not working it is probably a regional setting in your control panel. Your Keyboard is probably set to the the wrong layout
This will be slightly different for Windows 7 vs Windows 8 so check the control panel for Regional settings, input, keyboard settings. you will need to change your keyboard layout. If the @ sign is ontop of the number "2" then select US otherwise select UK. That should help.
Aug 31, 2014 | ASUS Eee Computers & Internet
About keybord
check the keyboard settings are correct. eg a US keyboard setting will give the @ symbol where the " symbol is. look in control panel/ keyboard/language settings for your options
Dec 23, 2013 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
Cannot use shift key + number for numbers 1 through 4 and 7 through nine.Cant make any symbols(at sign,exclamation sign).I tried reinstalling keyboard driver,choosing different language,so on and so...
You might have a hardware issue with your laptop keyboard. You have at least 2 options:
1) connect a "normal" USB keyboard to your laptop and use it, instead
2) run the On-Screen Keyboard (osk.exe) and access the characters/keys you want from there
Good Luck!
Oct 18, 2013 | HP Pavilion dv9000z Notebook
I can no longer sign into my laptop, my keyboard does not work but keystrokes happen at sign in they are 333333333333333333333333 which types itself so canot sign into anything. Can you help? Do you...
It could possibly (but rather unlikely) be a virus. However, it sounds more like the keyboard is jammed / broken. You can get replacements online, but fitting them could be an issue, i'd suggest taking it to a tech repair shop and getting them to swap the old keyboard out for a new one. This should fix the problem.
You could try plugging in an external keyboard via USB and seeing if this makes a difference.
Thanks
Moza805
Aug 31, 2011 | Compaq Presario CQ60-220US PC Laptop
B and n keys not working on HP Probook 4520. Can't sign on to computer because need b for part of password.
Until you can get the keyboard of the laptop replaced, you can buy a USB to AT keyboard adapter and hook a desktop keyboard to your system. Also a USB keyboard would work just fine directly plugged-in to one of the USB ports.
Most likely the fix will be to replace the keyboard, which is usually very easy to remove on laptops, but until you can get it fixed, you'll be able to use the system with the regular AT keyboard.
If you want to try to replace the keyboard yourself, I believe I've found it on the HP web site (you will need to confirm that it is the correct keyboard by contacting HP)
Dec 28, 2010 | HEWLETT-PACKARD ProBook 4520s
Im using vista as my os. and my laptop is hp pavilion, both my control keys are not working. what should i do?
You might have changed settings of stickey keys
Check the setting in start- control panel- ease of access center- make keyboard easier to use.
Go to sticky keys -uncheck the box.
Also check the other settings in it.
It will resolve your issue.
If yes.. if not..you might need to remove the keyboard driver from device manager.
regards,
Dreamkam
May 16, 2010 | HP Pavilion dv6000z Notebook
Why does my Compaq laptop keyboard free up and not work? My laptop keyboard will not work, but the mouse will. i have to use an external keyboard.
You may try to update the driver software to see if works. Please take it to the repair shop to check if it is defective. If you need a new HP Compaq Presario R3000 keyboard?¼Œ you may go to http://www.newlaptopkeyboard.com to order a new one.
Feb 17, 2010 | HP Laptop Keyboard for HP Compaq Presario...
Keyboard problems
Is the keyboard flexible cable the same pin as the original keyboard? If yes and you are sure the new keyboard is okay, then you can change the language to the preferred language e.g US English, change its position to the first and make it referred. Its should work. You can also check online if there is any keyboard or input driver which when installed can be of help.
Apr 12, 2017 | HP OmniBook Vt6200 Notebook
English language support on laptop with German Keyboard
The easiest solution will be to locate a replacement laptop keyboard for that model. they arent hard to replace and usually cost between $40 and $80. I would web search HP Spare parts Third party is usually cheaper. Keyboards are pretty common replacements on laptops due to wear an tear. Most are replaced using a small phillips screwdriver. Its likley you can find removal instructions on the web as well (if they dont come packaged with the keyboard.
Dec 24, 2008 | HP OmniBook Vt6200 Notebook
Samsung Mobel NP-P500Y
What sign is it that it gives you? your keyboard may be set up for the wrong region. are all the signs like that? or just the @ one? In Windows XP to change the keyboard layout: Control Panel -> Regional and Language -> Languages Tab -> Details and the keyboard language should be English US.
for more details visit this website: http://www.starr.net/is/type/kbh.html
Hope that helps!
Caleb Scansen
Technician/Manager
Rimrock Computer Co.
2320 Zoo Dr. Ste D
Billings MT 59101
Feb 28, 2008 | Samsung V25 XVC 2800 Notebook
Computers & Internet Logo
4,908 people viewed this question
David Payne
David Payne
