Question about Mobile Rack - 3.5 Inch Hot-swappable Serial ATA Drive Case (MRHOTSATA) Drive Case
What 2nd "Slave" hard drive should I buy to match my "Master"?
I have a 4 year old 40 GB Maxtor 3.5 Series Diamondmax Plus 8 ATA/133 - and want to install a second larger drive. What will be compatable?
  • 69 Answers
Any size hard drive should be compatible, but you should get the same connection type and bus speen if possible (ATA/133). If you get one from a different manufacturer, you'll have to install the bios update that comes with it and set the jumper to slave per the instructions that invariably come with any "add-on" hard drive.
Posted on Dec 29, 2008
  • Peter Sturniolo
    Peter Sturniolo Dec 29, 2008
    fyi, "speen" should be "speed"
Hi my drive will only format as fat, i need it to load xp on it, am i doing something wrong?
No, your not doing anything wrong. The FAT32 file system is for smaller drives while the NTFS is for drives in excess of 100GB.
Oct 16, 2010 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
I have a quantum fireball lct20 40gb hard drive that I am attempting to install as a slave drive in a Dell Dimension 2400 desktop, and while it works in other computers, I keep getting the BIOS detection...
Maxtor CrystalMax 1080
Maxtor Fireball 531DX Ultra ATA 100
Maxtor DiamondMax 16
Maxtor DiamondMax 1750 Ultra ATA 33
Maxtor DiamondMax 1750A Ultra ATA
Maxtor DiamondMax 17 VL Ultra ATA 66
Maxtor DiamondMax 20 VL Ultra ATA 66
Maxtor DiamondMax 2160 Ultra ATA
Maxtor DiamondMax 2880 Ultra ATA
Maxtor DiamondMax 30 VL Ultra ATA 100
Maxtor DiamondMax 30 VL Ultra ATA 66
Maxtor DiamondMax 3400 Ultra ATA
Maxtor DiamondMax 36 ATA 66
Maxtor DiamondMax 40 ATA 66
Maxtor DiamondMax 40 VL Ultra ATA 100
Maxtor DiamondMax 4320 Ultra ATA
Maxtor DiamondMax 536DX
Maxtor DiamondMax 60 ATA 100
Maxtor DiamondMax 60 ATA 66
Maxtor DiamondMax 6800 Ultra ATA
Maxtor DiamondMax 80 ATA 100
Maxtor DiamondMax D540X-4D
Maxtor DiamondMax D540X-4G
Maxtor DiamondMax Plus 2500 Ultra ATA
Maxtor DiamondMax Plus 40 Ultra ATA 100
Maxtor DiamondMax Plus 40 Ultra ATA 66
Maxtor DiamondMax Plus 45 Ultra ATA 100
Maxtor DiamondMax Plus 5120 Ultra ATA 33
Maxtor DiamondMax Plus 5120 Ultra ATA 66
Maxtor DiamondMax Plus 60 Ultra ATA 100
Maxtor DiamondMax Plus 6800 Ultra ATA 66
Maxtor DiamondMax Ultra ATA
Maxtor DiamondMax D540X_4K
Maxtor DiamondMax D540X_4L
Maxtor DiamondMax D740X
Maxtor Fireball 541DX
Maxtor Fireball LCT20
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball LCT08
Quantum Fireball LCT10
Quantum Fireball LCT15
Quantum Fireball Plus KA
Quantum Fireball Plus KX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
Maxtor DiamondMax Plus 9
Maxtor DiamondMax 10
Maxtor DiamondMax 11
Feb 22, 2010 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
Maxtor DiamondMax Plus 9 80GB 6Y080L YAR41BW0 Hard Drive ATA/133 HDD Internal HD not reconizing in any computer .think it is not getting any power to HD so the PCB Board i think might be gone.any help be...
Power comes from the power supply. Check yellow and black and red and black. You need both 5v and 12v. Are you sure you have the jumper set correctly for the application? Master or single - master with slave present or some computers require CS (cable select)
Dec 05, 2009 | Maxtor Hard Drive
PC will not see Maxtor 80GB DiamondMax Plus 9 as seconary slave.
Two thing,
First, never use a Maxtor HDD as a slave to a CDROM/DVD, doesn't work and tends to cause stability issues. So try swapping the jumper on the CD/DVD to slave and setting the Maxtor to Master, this should get it working.
Second, if it is showing up as 33GB, you have the Jumpers set to limit capacity(designed to avoid troubles on older systems. If this is the case, you likely have a single jumper in the center row of pins between the power and data cables. If it only works as master at the moment, then you likely have the neter row(limit size pins) and the one closest to the data cable(Master Pin) both plugged in.
Change your DVD/CD to slave, remove the limiting jumper and ensure the Master jumper is installed on the Maxtor, then be sure the end connector on the ATA(likely marked master) is plugged into the Maxtor and the middle connector(Slave) is plugged into the DVD/CD, this should have you all fixed up.
Hope this helps FixYa,
Chris
May 19, 2009 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
Hard drive spins up but windows does not see it
Depending on your PC make model and BIOS it may not auto recognize the second drive, check those settings. and or it might not support the drive size, in which case look for a BIOS update for your system. You also might want to use "cable select" on the switches even though you set it to slave it may not like that.
Apr 24, 2009 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
Dead Maxtor drive
the soec of the drive will have to match up in order to get the no pcb to wrok so the heads ,sectors,cylndrs and so forth
Apr 23, 2009 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
What new HDD will match my Maxtor DiamondMax Plus 8?
Mark,
You can use any size HDD in your computer as a slave and it does not have to be an exact match for the maxtor. You will however need the make sure that the connections on the new drive match. For example SATA drives will not attache to an IDE cable and vice versa. The drive that you mentioned is an IDE style drive so unless your MOBO has SATA connectors on it you will need to buy an IDE/EIDE drive.
Dec 29, 2008 | HP Compaq d530 PC Desktop
How can I detect maxtor 3200 ide as slave
Somewhere on the harddisk, you should be able to see a label indicating jumper settings. Check that the jumbers are set to slave sattings.
Dec 17, 2008 | Maxtor DiamondMax D540X 100 GB ATA-133...
Maxtor Diamondmax 80GB ATA 133 help!
there are several programs you can use to get your data off.
You will have to slave your new drive on to the IDE cable that your old one is on, you can then use symantec ghost to clone the old drive to the new,
Acronis true image is the other program you can use, put acronis true image on the new drive and the slave the old drive and take and image of it then recover it to the new drive.
Hope this helps
Dec 06, 2007 | Maxtor (L01P080) 80 GB Hard Drive
Mobile Rack - 3.5 Inch Hot-swappable Serial ATA Drive Case (MRHOTSATA) Drive Case Logo
124 people viewed this question
Top Mobile Rack Computers & Internet Experts
David Payne
David Payne
Are you a Mobile Rack Computer and Internet Expert? Answer questions, earn points and help others
