Question about Technics SL-BD22 Turntable
Low volume and unbalanced deck
My dad has an older slbd22 turntable and it has some playing issues.
Since it hasn't been touched in years, something has happend to the the actual turntable so when you have a record playing, part of the lower deck disk (not sure what its called) rubs up against the machine.  This causes the player to not keep the record playing at a constant speed (and consistent pitch).
Second, when we plug it into our new Sherwood 200w stereo head, we have to turn the amp's volume up to max to hear the record (which isnt much louder).  Its odd because the FM radio and other inputed devices are MUCH louder
  • saboughner89 Jan 30, 2009
    Thanks for the preamp idea and yes we have it in the AUX input.
    If anyone else can help me with the unbalanced turntable (the part that you actually place the records, even though im not sure what its called) that wobbles and rubs up against the machine and give me some idea as to fixing it, i would greatly appreciate it!
    President:
  • 948 Answers
Turntables require amplification, they have very low output on their own. If your Sherwood has an Aux input try using that, older receivers often had a built-in pre-amp on the aux jack. You can obtain a stand alone pre-amp for less than $50, I use one from mcm, #40-630.
Posted on Dec 30, 2008
The volume on technics SL-BD22 turntable will not turn up and stays at one volume
Since the turntable itself doesn't have a volume control the problem is with the amp it is connected to. It should be connected to an amp with a dedicated phono socket. It's no use connecting it to a tape or aux or CD socket. These sockets do not have a built in pre-amp for the magnetic cartridge. If your amp doesn't have a dedicated phono socket then you can buy a Magnetic Cartridge Pre-amp that will plug into a tape socket etc on the amp and have the deck plugged into it. If plugged into a none dedicated socket though you can hear it, the volume will be very low compared to other sources. If you have got it plugged into a dedicated phono socket and the volume is still low, then the internal built pre-amp inside your amp for the deck has failed and will need to be repaired. The pre-amp failure will not effect any other functions of the amp.
Feb 24, 2015 | Technics SL-BD22 Turntable
Technics SL 1210 feedback/grounding problem.
Do you have these turntables on an anti-static mat, or some other non-conductive surface?
Jun 09, 2008 | Technics SL-1210 Turntable
Trying to hook up older technics stereo dont know
Turntable leads go to Phono.
Turntable ground lead (thin black wire) goes to screw terminal next to 'Phono'
CD phono cables go (unsurprisingly) to the CD
Cassette deck "Play Out" cables go to 'Tape Playback' sockets.
Cassette deck "Rec In" cables go to 'Tape Rec Out' sockets.
EQ Line Out cables go to amp's VCR/EQ Playback
EQ Line In cables go to amp's VCR/EQ Record Out
Aug 30, 2014 | Audio Players & Recorders
I have a JVC turntable and an old Sansui reciever. Last night I was playing a record, and it stopped playing out of one speaker, and makes a loud buzzing noise. However, when I push the Mono button
You should check the connections to the turntable, it sounds like it might be feedback hum, caused by a wire touching or something like that. Don't forget to check the connections to the cartridge too.
Feb 09, 2014 | Audio Players & Recorders
I have an Aiwa PX-E77U turntable I'm connecting to a Pioneer VSX-454 receiver. The turntable has no ground wire. It plays okay at low levels, but as soon as I bump up the volume a little, I'm getting a...
It could be a bad connection of the earth pins to the cartridge. One turntable I had hummed even with an earth connection. I found out that the cause was the connection of the earth wire in a 3 pin plug.
Aug 31, 2013 | Aiwa Audio Players & Recorders
Low volume recording on reel to reel tape deck
Problem could be in either the record or playback circuits of unit. Try playing back a tape in another machine to see what the volume is like. If also low then the issue is with the record amp circuits.
Fixing will not be cost effective, however.
Aug 21, 2017 | Audio Players & Recorders
ION turntable volume is low when plugged into a receiver.
Either the cartridge has failed, or an internal amp in the record deck has, or despite what you say the receiver has. I will clarify this for you. Magnetic cartridges need a pre-amp before it gets amplified by the pre-amp and power amp of your reciever. If that pre-amp fails you will still hear the low sound from the deck, but all others cd/tape would be normal as they don't go into the deck pre-amp.
All you need to is trace the circuit. Find the magnetic cartridge pre-amp and find where it joins with the pre-amp of the amp! If you stick a screwdriver at that point, you will get a buzz at normal volume on each channel. The cartridge pre-amp has gone if you do get a buzz!
You probably find it's a single IC that's gone, some are prone to static problems.
Jan 01, 2010 | ION Audio iTTUSB Turntable
1210 problem
Those are just standard phonograph player characteristics in my experience. You'll hear a tap on the deck because there's essentially a live mic ( the needle ) physically coupled with the record on the turntable and the rest of the phonograph player even though they try to dampen the coupling of the turntable as much as possible. The rumbling noise at high gain is because the turntables being driven by a motor via gears or a belt and creates some  vibration, wich is transmitted through the turntable and picked up by the transducer ( needle ), low frequency rumble, just like a recording studio on a busy street may pick up from road vibration/ noise.
Aug 06, 2008 | Technics SL-1210 Turntable
Low volume from Akai turntable attached to Pioneer Surround Sound Receiver
If you receiver doesn't have phono inputs,you will need to buy an inline phono amplifier.Phono inputs have a built in amplifier,all others don't.Try Crutchfield.com.If they don't carry them,they will tell you who does.
Mar 02, 2008 | Audio Players & Recorders
Technics SL-BD22 Turntable Logo
327 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
