I was also occuring from same problem. Do the following steps:-
1. Right click on my computer icon and open manage.
2. Then open disk management.
3. There u see ur pen drive.
4. Right click on ur pen drive and click on format.
5. After successful formating restart ur computer.
6. Ur pen drive wil work again.
other method pen Command Prompt, click Start, click Run, type cmd, and then click OK
Well a computer user
mostly afraid and suffers from virus attacks. Virus is the unwanted program
that destroys your data and some times also damage the computer. One of the most
common ways of virus attacks is by connecting USB to your computer. So today I will tell
you some tips which can avoid or minimise the chances of virus attacks. Always keep in mind
the following points before connecting a pen drive to your computer. 1. Always use a good
antivirus in your system. 2. Never open the pen
drive directly. 3. before opening the
pen drive, scan the pen drives for finding the possible viruses in the pen
drive. To scan the pen drive go to My
Computer->Right Click on the Pen drive->Click on Scan option(Remember Scan
option will only be there if there is any antivirus installed on your system) 4. if any virus found
and the antivirus is not able to delete the virus, just safely remove the pen
drive from your computer. 5. If no virus is
found, do not double click on the pen drive to open. Always open the pen drive by
Right clicking on the pen drive and then clicking the explore i.e.: My
Computer->Right click on pen drive->Click on Explore 6. Always beware of
copying the unwanted files on your computer. Just copy the file which you want.
Never do a select all, copy all thing. Just copy the item you wanted, and paste
into your computer. While pasting the
data you should never paste it on C drive (Drive that contains your operating
system). Always copy data in a separate drive then C drive. So these are some
small steps which can be very useful to avoid virus attacks... Regards, polysandy
Hi
First u attach your pendrive with pc after that u do a right click on pen drive folder ,then u click on scan option then the scan folder will apper and u select the pen drive folder by adding ,then click on next opyion and wait untill the scan is over .After scan over's then u can format your pendrive....
hmmm....hello friends...your pen drive is corrupted...its better to change this pen drive because kingston pen drive is in 5 yr warrenty period... so dont wrry and change it.....or you can try this pen drive to any other computer ...if behaviour is same then i would request to you , change pendrive as soon as possible
c if u have virus in ur pen drive u will get the information like this... 'A' drive is incorrect r whatever which will show windows cannot support this file... so u plse try to format ur pen drive....
have a 2gb transcend pen drive.till now it was working properly but now wen i try it says insert an drive into I.the light is glowing and it is getting detected.But i am not able to read the data.anyone can please help me.
Your pendrive is affected virus and do the format both pen drives and first cheak with your usb port also once and when you are pushing the pen drive in the pc should be smoth dont press just push some times light is appear but data cabe is not connected to pc
dont open the drive after u putting into the system right click on the pen drive and scan the pen drive with your antivirus otherwise put in another system and check
I presume you are trying to open the document using the Recently Opened file list in Excel's "File" menu. If so, use the "Open" entry in the "File" menu instead and navigate to the pen drive from there - it may be that the drive letter has changed. Another possibility: use Windows Explorer (which can be accessed by double clicking on My Computer) to copy the file from the pen drive to the desktop and open it from there by double clicking on it. If that still doesn't work (but the copy worked OK) then right click on the file, click on "Properties" and see if the Read Only box is checked. If so, uncheck it.
And yet another possibility: after closing the file, did you pull the pen drive from the PC without telling Windows to eject it first? If you just remove the drive too quickly, without ejecting it first, the file can easily be corrupted.
i problame with my pen drive . when i tried to format it results "this disk is write protected
