Question about Dishwashers
The metal seal is loose
My Ariston dishwasher has a loose inner seal. The seal is not on the door but on the unit itself. The rubber seal is enclosed in a metal rim that is seems to be glued in place. The whole rubber and metal seal has come loose and I cannot use the dishwasher.
Can you please advise me of how this can be fixed as the dishwasher repair people cannot seem to help me once I have described the problem.
I live in Calamvale, Brisbane, Queensland, Australia
regards
Robyn
0407 130 928
robyn_dunlop@bigpond.com
    Scholar:
  • 86 Answers
Hi robyn, Well i am sorry to hear your problem as i cant think of anyone that likes washing up... I am under he impression that the inner seal that is attached to the dishwasher cabinet inside the disheasher is the one you are talking about? If so then you are going to have to replace the inner wash tub,as this seal housing ( the metal piece ) is spot weilded in. So you will need to strip everything out and from underneath the dishwasher too. Not sure on the price of the part but the job itself is very time consuming and costly..
Good luck
Posted on Dec 29, 2008
Dishwasher leaking at lower door seal
Possible that the door seal has failed and there is leak when the pressure spraying takes place. Please check the seal and replace, click for tips to replace: door seal
Jan 02, 2013 | Dishwashers
Kitchenaide dishwasher inner rubber seal nsticks to door when opening
clean seal and mating surface on door. then put a little cooking oil on seal. this may help.
Aug 07, 2012 | KitchenAid Dishwashers
Frigidaire dishwasher ffbd2409ls door leaks
First open the door, and pull the racks out of the unit. Place a small level in the inside of the cabinet, NOT on the door itself. Make sure the unit is level. 90% of leaks come from incorrect installation. If the unit is level per the installation instructions for your specific unit, then check the door gasket/seal. Check for any damages or gaps. Then go to check the sprayer arms. One might be loose or disconnected forcing water to shoot straight down on the door itself.
Aug 01, 2012 | Frigidaire FFBD2409LS Builtin Dishwasher
I have a Neff built-in dishwasher and sometimes there is a heavy leakage of water from the front right-hand side. The unit is 3-years old and there is a build up of scale around the rubber seals. The long...
Check the rubber seal in the bottom of the door has not perished or split,also check the bottom spray arm has not split on the ends as this will direct the spray directly onto the door,causing it to leak.
Hope this helps
Sep 19, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
The rubber seal around the door came loose...i need another one
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
May 12, 2010 | Dishwashers
My clients unit is leaking substaintial water in
Check the drainage hose to see if its connected properly. it is located under the unit. it may be loose or, not connected correctly. if the drainage hose is connected properly, this will be a faulty water valve. replace if found to be faulty.
Jun 16, 2009 | Dishwashers
BF1620 leaking dishwasher leaking help.
hi,Check your spray arm that nothing got stuck in its holes. make sure the spray arm is turning all the time when using the machine :
put the spray arm in 90 degree position, turn the unit on , open the door after few min check that the spray arm move...
make sure your seal of the door is clean and nothing prevent it to close evenly the door...
good luck 911servicetoday . com
I hope you find this Very Helpful and best regards!
Aug 06, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Frigidaire Dishwasher Leaking
I just found a service release number for my Frigidaire dishwasher that says it applies to Serial numbers TH632 through serial number TH737 made in 2007 for a replacement kit for the door seal at the bottom of the door. The bottom door seal has been changed, adding side seals that restrict the water surge from the center spray arm. The part number for the new seal is p/n 154588201. This seal can be replaced without removing the dishwasher or either of the door panels.
The seal is located on the bottom of the inner door panel and appears as a cream colored flexible
rubber blade bonded to a milky white colored plastic strip. To remove and properly install
replacement follow the instructions carefully.
1. Replacing this seal can be accomplished without disconnecting power from the unit.
Always use extra care when electrical power is present while serving an appliance.
2. Open door all the way down and remove lower rack. Set rack aside to a safe location.
3. Locate the seal on the bottom of inner door panel. Facing front of unit, the right side of the
seal can be pulled down slightly to facilitate removal.
4. Pull seal straight into the tub from right side.
5. With seal removed, and before installing replacement seal, locate the channel in inner door
panel that the seal mounts into. Locating this channel before installing the replacement can
make this procedure easier.
SERVICE FLASH
DW071
6. Place the new seal on a flat surface and measure from the bottom of the seal, (See Figure
1 to determine bottom of seal), up 3/8 "of an inch and place a mark with a pen or marker on
both ends (See Figure 2). If needed, scribe a straight line between these two marks this
will give you a guide when installing seal into the inner door panel.
7. The seal can only be installed one way. The end that holds this seal into the inner door
panel has a ½ inch notch cut in the right side. This notch allows the seal to be installed
around the end of the inner door channel that holds the seal.
8. Line up the seal along the bottom of the inner door panel and start from the right side, push
the seal into the door channel to the line marked in step #6.
9. With seal in place close the door, the tub will align the seal as needed.
10. Reinstall lower rack and operate unit to check for leaks.
If leaks continue to occur at the bottom corners, order Splash shield kit 154701001 for
dishwasher.
Before installing the kit remove and reinstall the lower door seal. To install the lower seal make
sure you measure up from the bottom of the seal 3/8 of an inch and mark the seal, do this on
both ends. This locates how far down the seal needs to be before closing the door. Do not
install this seal without measuring it first. After the lower door seal has been re-installed then
install the splash shields according to the instructions accompanying with the kit.
Sep 18, 2007 | Dishwashers
Rubber door seal problems
Try gorilla glue ,it needs to be wet with water to be its strongest.Please rate this .Thanx!
Apr 25, 2007 | Indesit 24 in. D63 Free-standing...
Ariston dishwasher LL64
usual place for a leak is thro the door main seal but it is possible to get a leak thro the dispensor. only way to check is split door, put it to work and see if it leaks in dispensor area
Mar 31, 2007 | Ariston Technologies LI640S Dishwasher
Dishwashers Logo
Top Dishwashers Experts
