Question about Pentair MINIMAX NT TSI IGNITER
Gas will not stay ignited
I HAVE A PENTAIR MINI MAX NT 400K POOL HEATER. THE FAN COMES ON AND THE GAS VALVE CLICKS ON BUT DOES NOT IGNITE. SOME TIMES I SMELL GAS AND OCCASIONALLY IT WILL IGNITE BUT ONLY STAYS LIT ABOUT 2 SECONDS. AFTER 4-5 TIMES I GET A F5 FAULT INDICATOR LIGHT. THE IGNITOR IS GLOWING BUT NOW ITS NOT IGNITING AT ALL.
    Problem Solver:
  • 7 Answers
Could be dirty heater you have to clean the runners and the smole nozzles that are in the manifold below the gas valve it's like a 9/16 size you pull them off and check make sure they are clear through, sometimes little spiderwebs build up inside them. if it's all clean, then it could be you flame rectifier/ aka: flame sensing rod, that tells the htr that there is fire so it keeps running. Let me know what happened.
John
Posted on Jan 06, 2009
E04 minimax error code
check to see if you have adequate gas pressure sounds like it running out of gas pressure
Aug 04, 2014 | Pentair Minimax NT Heater
When I turn my mini max plus 400 heater on it clicks then nothing happens, what's up with that
If it is clicking it is trying to fire (calling for heat). This indicates that the internal safety loop Tstat, and IID are working. It is either a bad gas valve, your ignition wire, or lack of gas. If the gas line had been open for servicing for any length of time it can take a while for all the air to get out. Best call out a tech to do the repair, you are literally playing with fire.
May 15, 2012 | Pentair Minimax NT Heater
I have a pentair minimax 400dv ,my heater burner comes on for a minute and then,the burner cuts off. The fan keeps running, the burner will ignite again. This will do this several times. Eventually the...
Cleaning the Thermal couple can work at times, however most times you will need to replace it. You may also be having an issue with the ignition control. You are in pretty deep now and it would seem like you are determined to save this heater, I would change them both.
http://www.parts4heating.com/Pool-Heaters-Pentair-MiniMax-NT-400-s/696.htm
Jun 30, 2017 | Pentair Minimax Ch 400,000 Btu Propane...
Heater will not ignite.
Try replacing the ignitor.
May 15, 2010 | Pentair Minimax NT Heater
Fails to ignite - fan blows for 15 seconds, then 2
i had the same problem it turned out to be an old regulator valve on the gas meter wasnt allowing enough gas to reach the heater. i had to have the gas comapny come out. they changed it for free.
Jul 03, 2009 | Hayward H Series Pool & Spa Heater 400k...
NT mini max not heating at all - won't fire
wow t pool service is just guessing i guess . weel let see do u have a pilot if yes do u hear a click if yes clean t burners if not check 24v at t brown wir e for t gas valve if v replace gas valve if not replace ignition control . do u have any code on t back or t front this help a little.
Jun 14, 2009 | Pentair Minimax NT Heater
I have a Pentair MiniMax NT 250,000 btu pool heater that fails to
Two reasons.
1. There is air in the gas line. Power down the heater and allow it to try igniting until lockout. If it locks out, repeat the process. Most lines will clear within 4-5 attempts to ignite.
2. A plugged burner orifice. Run a small pipe cleaner in the brass fittings on the burner tray. They may have small webs in them restricting gas flow.
If the unit is a Standard (STD on the plate inside) it has a flame sensor that may also be bad. That sensor is on the end of the single wire that is cloase to the ignitor wire near the burners. Also check for a losse ground wire on the heater.
Nov 24, 2008 | Pool & Spa
Pentair MINIMAX NT TSI IGNITER Logo
819 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
