Question about Canon NP 6650II Copier
Shaky image at particular are in canon 6650 photocopier
Shaky image front of the page (one inche below) on every copy
    Novelist:
  • 148 Answers
The scan lam assembly is dragging when you hit
print
If you can get access to the scan rails( remove the glass platen put small amount of silicone on the rails and if it moves manually(do not force )
If this does not work there may be a clutch or electrmagnetic drive that is slipping
either way it needs o be removed and cleaned
Posted on Dec 30, 2008
MY canon iR3035 ccd scanner position is faulty..
Re: canon ir 3035 copy not lined up 1/4 inch higher it scans but configuration page i
service mode > copier > adjust > adjust xy > adjust Y input the value from the label on the front cover
This is all I could find. Try adjusting by 1/4 inch. Thank you Santosh
Jun 25, 2016 | Canon imageRUNNER 3035 Black and White...
Turn the main power on e806-0000 ifproblem persists contact dealer or service rep
CANON 6050, 6650, 8070, 8570 E801 thermistor, fusing unit, power supply, main board CANON 6050, 6650, 8070, 8570 E802 power supply or main board error
Jun 18, 2013 | Canon ImageClass MF4412 Toner Black Repl -...
I'm trying to photocopy a book on a canon imagerunner 5075 without copying one page at a time and flipping the book around. Is there a way where the copier scans the right page and then scans the left page...
Hi Kim,
there are a couple of easy ways to tackle this problem. you have a book that when the spline is opened exposes 2 pages to the glass for the possibility of copying. What YOU need to determine is whether or not you want page 1 to ouput seperately from page 2, or , would you like page one to be on one side and page 2 to be on the second side. In other words auto duplex. That decision determines which feature you will use. I will walk you thru both. I realize you want the copier to scan the first page and then scan the second without you having to move the book around. I'm thinking you would be happy if the copier did that very thing and you wound up with a 2 sided copy with page 1 on the front and page 2 on the back. Here we go. Fom the main copy display locate the 2 sided button and select it. Select "book 2 sided" and follow the prompts. You could actually copy the entire book this way and when you are thru press "done" and here comes the avalanche!
If you want the images 1 sided on seperate sheets (not sure why) you can select "special features" from the display in the lower right corner and select "2 page seperation". same drill.
Apr 25, 2011 | Canon imageRUNNER 5000 Copier
How we make photocopy in a x1190
You can photocopy on this printer by following these steps:
Note: You can make a quick color or black and white copy.
Press Color Copy or Black Copy on the control panel.
To make black and white, gray, or color copies:
1 Open the top cover of the All-In-One.
2 Place the item you want to copy face down on the glass. Make sure
the upper left corner of the front of the item aligns with the arrow.
3 Close the top cover.
4 Open the Lexmark All-In-One Center (see page 3).
The All-In-One Main Page displays.
5 Click See More Copy Settings to review and change the copy
settings.
6 Select your copy settings.
Note: You may want to reduce or enlarge the image.
7 Click Copy Now.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Feb 22, 2011 | Lexmark X1190 All-In-One InkJet Printer
Canon NP 6650 photocopier. Begins to pick up paper, stops and gives message about jammed. Checked path and see no paper or parts of paper. Need service manual.
1)jammed issue.
2)can u try to make copies by using stack bypass or other paper deck see whether u hav the same fault.
3)or flip over your paper and put it in the paper deck again .Fan the paper ,it could be high moisture and static on the paper.
4)clean the paper dust from the pick up unit with damm cloth.
Sep 04, 2009 | Canon Office Equipment & Supplies
Photocopy has black band at end of the page
well ithink tou are using the ADF to copy something...you will have to clean the scanner glass(not the scan bed but when you lift the ADF cover you will see a scanner glass about inch wide)...it should resove your concern...
Mar 27, 2009 | HP Photosmart C7280 Printer
Copy result is blur and I see the acceleration of paper too fast
When you say Blur? Is it a scattering of toner or is the whole image blurred or out of focus? You may have a problem with the lens HP or a problem with the scanning mirrors. Do you get a error code? Is the blur like toner strikes down the page? Check you corona wires and look for any small pieces of paper that maybe lodged in or around the drum unit. You may want to give a little more info. on the exact problem, to narrow down the cause
Dec 27, 2008 | Canon NP 6050 Copier
Canon NP 6650II Copier Logo
81 people viewed this question
old marine
old marine
