Question about Whirlpool 24 in. DU930PWP Built-in Dishwasher
Whirlpool pump not working. pump not making sound.
  • beng1canobee Dec 29, 2008
    it pumps water in and cleanes, just wont pump out.
    Master:
  • 426 Answers
Just to be sure make sure the pump is recieving power before replacing as the switch/circuit board that regulates all functions maybe the actual fault.
Posted on Dec 29, 2008
  • tony yeatman
    tony yeatman Dec 30, 2008
    you may want to check that no food remains have blocked up the outlet as it happened to our dish washer.Also check the outlet hose.Good luck and happy new year
    Sergeant:
    Champion:
  • 338 Answers
Replace the pump.
My whirlpool gold dishwasher is only 2 years old. It will fill with water but it just sits and makes a clicking noise when its supposed to be washing. It drains fine when I push the cancel button.
sounds like there is either a loose wire or bad switch on the water flow pump, not the drain pump What is the model number of the unit that your working on?
Aug 22, 2015 | Whirlpool Dishwashers
Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
Fills with waters starts making a buzzing sound
Check to see if there is something(sock) in the pump. If not, try spin washer with pump hanging down, but not with hoses off.
Jan 12, 2010 | Whirlpool Washing Machines
My top loader whirlpool finished agitating, drained, and started to spin...made a kaboomkachunk sound and then "ehhhhhhhhhhhhhh" sound. It's not unbalanced or overloaded or anything...help! Then in my...
You probably have something stuck in the drain pump.
Use this video link to access the pump.
http://www.youtube.com/watch?v=WLPGs2UMUJc&eurl=http%3A%2F%2Fappliancejunk.com%2Fforums%2Findex.php%3Ftopic%3D67.0&feature=player_embedded#t=15
Jan 05, 2010 | Whirlpool Washing Machines
Clogged suction line in bath whirlpool
It sounds like something got sucked into your pump impeller, you can try sucking it back out with a wet vac but my bet is that you'll have to open the pump to clean it out. If the marble skirt is the only acccess to the pump it will need to be removed but look for another way first, they can be difficult to reinstall and make look good. If your careful, the pumps can be opened and cleaned without much trouble, Use your wet vac to suction anything left out of the pump suction line and make sure the pump discharge and distribution lines are clean as well. Pump case should have an "O"Ring seal that should be replaced but may be cleaned, lubricated and reused if not dammaged
Good Luck, this is the kind of job the service tech's make there money on.
Oct 14, 2009 | Whirlpool ROYAL BRB909 Corner Tub, Jacuzzi...
Whirlpool bath has lower then normal jet pressure
This is usually caused by a reduction of RPMs of the pump. If the pump sounds slower than usual, the pump motor is worn out and needs replaced. If the pump sounds normal there could be a blockage in the impeller in the pump or a suction screen full of debris. The suction screen is at the bottom of the tub usually in the middle of one of the sides. It can usually be removed with a screwdriver and checked to make sure all the little holes are open. If none of these ideas work, call in a pro to have a proper diagnosis performed.
Sep 29, 2009 | Home
American Whirlpool Jupitor model cuts off and often will not start the process.
Sounds like the pump is overheating make sure pump motor is not obstructed by insulation I have seen people put insulation around pump motor to quiet it down but the pump needs air to keep cool
Jun 23, 2009 | Home
Whirlpool 8255e makes ''whirry'' sound when pumping - not spinning
there is probobly something small jammed into the pump
common for that sound would be a underwire for a bra.
is it still draining ok?
May 26, 2009 | Whirlpool Washing Machines
My whirlpool du1050xtps3 makes a grindin sound
Yes, this is common. Sounds like bearings in the motor. Will need to replace the pump and motor assembly. 14 6324 -->partimage.aspx?imgid=z3bqljbfahrfmduxntm1oc9mufcvc290b2hwdhjhcc8%3d
Enlarge Photo
Pump and motor assembly, complete - Original Whirlpool Part. Fits Whirlpool and KitchenAid dishwashers. This dishwasher pump and motor kit comes pre-assembled for easy installation.
Part Number: AP3778061 made by WHIRLPOOL $173.71 In Stock
Order now and it will ship Today
questionmark.gif This is the part with picture from http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5136316. Look in your owners manual because some models cover this part for 2 yrs. Hope this helps.
Nov 18, 2008 | Whirlpool 24 in. DU1100XTPS Built-in...
Whirlpool Sound During Drain
Yes, you can pull one of the pump's leads to find whether the noise comes from the pump. You should unplug machine's power cable first and be sure that the disconnected wire is isolated. Before replacing the pump look that it clean from any foreign object/ Good luck!
Aug 17, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU930PWP Built-in Dishwasher Logo
138 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
