Question about Brother HL-2070N Laser Printer
Can't reinstall my brother hl-2070n
Every so often my hl-2070n goes off the reservation so to speak. It just stops printing. In the beginning it was an easy fix with a driver reinstall from the disc. However the last two times it has become increasingly difficult to reinstall it. It accepts the installation and shows up as a printer on my list but it won't print. Last time I had to change the port, which is something I never had to do before. This time none of the ports seem to work.
I am on windows XP home and I have the printer installed to a network hub via an ethernet cable. I also have two computers on vista. None of them will print to the printer.
I can't seem to find anything in the user manual about what the exact steps are that I want to take to set up the printer via network ethernet. I believe I've used every combination option from the install disc. Now I'm fresh out of ideas. Maybe I'm missing something from the install disc, some magic combination.
I'm not sure what other information you may need to help me fix this problem, but I would really appreciate and help you can offer.
  • 2 more comments
  • Cait_Lin Jan 05, 2009
    my 2070N does the same thing. i've had to spend more then three hours on the phone with brother tech support.
  • the4freds Jan 08, 2009
    I have the same issue. So far a complete uninstall and re-install will solve the problem. Major nuisance. I have the printer connected to a Linksys switch and my pc is running Vista Business SP1 32bit.
  • tyger427 Jan 08, 2009
    I too have the same problem. I can get it to work if conected directly to the computer. But if i try to install it as a network printer to the router it won't print. But it will show up. Somebody must have a bright idea.
  • the4freds May 11, 2010
    Hello Bud. since I have done this several times it is a bandaid for the problem but not a fix. The problem will be back. Could this possibly be tied to buffering of print jobs? The reason I ask is the stoppage seems to happen more frequently when trying to print large files like powerpoint presentations. Any thoughts? the4freds
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
Brother HL-2070N Laser Printer Will Not Print
First of all, I checked the answers given here, but nothing worked; everytime I turned on the unit, the red light flashed that the printer was out of paper.
From the Brother's HL-2070 manual, in the troubleshooting section: take out the toner cartridge from the front of the machine (be careful, any black toner powder that come off may be very difficult to clean up). I took the toner cartridge to the sink.
There is a blue slide along the top of the unit that will clean the corona wire if you slide it back and forth, from one end to the other (toner/dust can become caked on the wire over time; sliding the slider back and forth simply knocks the caked off 'stuff' off of the wire).
Replace the toner cartridge; it worked fine for me. I was immediately able to print.
Mar 11, 2010 | Brother HL-2070N Laser Printer
Brother hl 2025 tn will not stop printing. went to :control panel>printer> properties>cancel all documents. then replaced paper tray hit start button & printer starts printing again. Pull out...
You have the wrong drivers or corrupt drivers on your system.Disconnect your printer and restart.uninstall your printer and download new drivers and reinstall.all should be fine
Jun 25, 2009 | Brother HL-2070N Laser Printer
Printer knocks, won't print
Try to reinstall the software and should be fine.
May 15, 2009 | Brother HL-2070N Printer
Brother laser printer HL-2070N prints same doc over and over.
Hi Jeffery,
Can you give a little more info, you say the same doc keeps printing, do you know how many times you haved tryed to print this doc.
If you can get inside the print q and delete the print job.
then try a new print job it sounds like the same job is stuck in the Q
Jan 27, 2009 | Brother HL-2070N Laser Printer
Brother HL2070N printed 1 page fine,then nothing but light streak
turn off printer, remove cartridge and drum and clean internally.
reinstall drum and cartridge and do a test print, hopefully all will be better.
Jan 18, 2009 | Brother HL-2070N Laser Printer
Brother HL-2070N Will Not Print
Hi tom8972
try to reinstall the driver of it.
hope this helpful for you,
thanks,
Hamedo
Sep 13, 2008 | Brother HL-2070N Laser Printer
Brother HL-2070N
make sure the protocall is enabled for your specific printing preferences.
if not sounds more a computer issue.
May 16, 2008 | Brother HL-2070N Laser Printer
Brother hl-2070n
The printer is ready to print. Pressing control panel button wakes up the printer to Ready mode
Mar 28, 2008 | Brother HL-2070N Laser Printer
Printer prints crooked (8.5 x 11 from paper tray)
check that the paper guides on paper cassette are hard up against paper edges
Oct 27, 2007 | Brother HL-2070N Laser Printer
Brother HL-2070N Laser Printer Logo
186 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
