KitchenAid KFC3100 Chef's Chopper 3 Cups Food Processor
Problem for KitchenAid KFC3100 Chef's Chopper 3 Cups Food Processor
On the KitchenAid 3 cup
By jjticzon on Dec 29, 2008
On the KitchenAid 3 cup Chef's Chopper, How do you lock the blade so I can turn on the chopper?
Same Problem
Mar 31, 2009
-   The blade will not drop to the bottom of the bowl in mine, so the motor will not activate. -   Guest
Best Solution
posted on Jul 08, 2009
Very Helpful)
QuietRiot
Rank: Guru  KitchenAid Expert
Rating: 93%, 85 votes
The Kitchenaid food choppers have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Comments:
Aug 08, 2009
- The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
The blade will simply mount onto the shaft. Turn it clockwise to seat it fully.
Aug 08, 2009
- If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for KitchenAid KFC3100 Chef's
Questions and Unsolved Problems for KitchenAid KFC3100 Chef's
Do you recommend KitchenAid KFC3100 Chef's Chopper 3 Cups Food Processor?
Answer
Answer
i need an instruction booklet for the kitchenaid food processor model number KFB500WH
Answer
It did not come with a manual. Does anyone know of a site that I can download a manual for it?
Answer
I can print the manual for KitchenAid chef's chopper
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For KitchenAid KFC3100 Chef's...:
Top Food Processor Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Food Processor Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
