Question about Encore ENLTV-FM (EN-LTVFM)
Fail to initialize hardware!ErrorCode#E0601
I can not run the program always display an error mentioned above.
  • Anonymous Mar 27, 2009
    Esta placa é uma porcaria , nunca mais compro.
    Fail to Initialize Hardware #E0601001
Esse erro leia o manual la ta escrito o porque deste problema por isso o brasil nao via pra frente
Posted on Nov 27, 2009
Beep codes
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions 1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed Award BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary. Beep Code Description 1 long, 2 short Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beep(s) RAM problem. If any other correctable hardware issues is found the BIOS displays a message. No Power, Loose Card, or Short.1 Short BeepNormal POST, computer is ok.2 Short BeepPOST error, review screen for error code.Continuous BeepNo Power, Loose Card, or Short.Repeating Short BeepNo Power, Loose Card, or Short.One Long and one Short BeepMotherboard issue.One Long and Two Short BeepsVideo (Mono/CGA Display Circuitry) issue.One Long and Three Short Beeps.Video (EGA) Display Circuitry.Three Long BeepsKeyboard or Keyboard card error.One Beep, Blank or Incorrect DisplayVideo Display Circuitry. Phoenix BIOS Q3.07 OR 4.X Beep Code Description and what to check 1-1-1-3 Verify Real Mode. 1-1-2-1 Get CPU Type. 1-1-2-3 Initialize system hardware. 1-1-3-1 Initialize chipset registers with initial POST values. 1-1-3-2 Set in POST flag. 1-1-3-3 Initialize CPU registers. 1-1-4-1 Initialize cache to initial POST values. 1-1-4-3 Initialize I/O. 1-2-1-1 Initialize Power Management. 1-2-1-2 Load alternate registers with initial POST values. 1-2-1-3 Jump to UserPatch0. 1-2-2-1 Initialize keyboard controller. 1-2-2-3 BIOS ROM checksum. 1-2-3-1 8254 timer initialization. 1-2-3-3 8237 DMA controller initialization. 1-2-4-1 Reset Programmable Interrupt Controller. 1-3-1-1 Test DRAM refresh. 1-3-1-3 Test 8742 Keyboard Controller. 1-3-2-1 Set ES segment to register to 4 GB. 1-3-3-1 28 Autosize DRAM. 1-3-3-3 Clear 512K base RAM. 1-3-4-1 Test 512 base address lines. 1-3-4-3 Test 512K base memory. 1-4-1-3 Test CPU bus-clock frequency. 1-4-2-4 Reinitialize the chipset. 1-4-3-1 Shadow system BIOS ROM. 1-4-3-2 Reinitialize the cache. 1-4-3-3 Autosize cache. 1-4-4-1 Configure advanced chipset registers. 1-4-4-2 Load alternate registers with CMOS values. 2-1-1-1 Set Initial CPU speed. 2-1-1-3 Initialize interrupt vectors. 2-1-2-1 Initialize BIOS interrupts. 2-1-2-3 Check ROM copyright notice. 2-1-2-4 Initialize manager for PCI Options ROMs. 2-1-3-1 Check video configuration against CMOS. 2-1-3-2 Initialize PCI bus and devices. 2-1-3-3 Initialize all video adapters in system. 2-1-4-1 Shadow video BIOS ROM. 2-1-4-3 Display copyright notice. 2-2-1-1 Display CPU Type and speed. 2-2-1-3 Test keyboard. 2-2-2-1 Set key click if enabled. 2-2-2-3 56 Enable keyboard. 2-2-3-1 Test for unexpected interrupts. 2-2-3-3 Display prompt Press F2 to enter SETUP. 2-2-4-1 Test RAM between 512 and 640k. 2-3-1-1 Test expanded memory. 2-3-1-3 Test extended memory address lines. 2-3-2-1 Jump to UserPatch1. 2-3-2-3 Configure advanced cache registers. 2-3-3-1 Enable external and CPU caches. 2-3-3-3 Display external cache size. 2-3-4-1 Display shadow message. 2-3-4-3 Display non-disposable segments. 2-4-1-1 Display error messages. 2-4-1-3 Check for configuration errors. 2-4-2-1 Test real-time clock. 2-4-2-3 Check for keyboard errors 2-4-4-1 Set up hardware interrupts vectors. 2-4-4-3 Test coprocessor if present. 3-1-1-1 Disable onboard I/O ports. 3-1-1-3 Detect and install external RS232 ports. 3-1-2-1 Detect and install external parallel ports. 3-1-2-3 Re-initialize onboard I/O ports. 3-1-3-1 Initialize BIOS Data Area. 3-1-3-3 Initialize Extended BIOS Data Area. 3-1-4-1 Initialize floppy controller. 3-2-1-1 Initialize hard disk controller. 3-2-1-2 Initialize local bus hard disk controller. 3-2-1-3 Jump to UserPatch2. 3-2-2-1 Disable A20 address line. 3-2-2-3 Clear huge ES segment register. 3-2-3-1 Search for option ROMs. 3-2-3-3 Shadow option ROMs. 3-2-4-1 Set up Power Management. 3-2-4-3 Enable hardware interrupts. 3-3-1-1 Set time of day. 3-3-1-3 Check key lock. 3-3-3-1 Erase F2 prompt. 3-3-3-3 Scan for F2 key stroke. 3-3-4-1 Enter SETUP. 3-3-4-3 Clear in POST flag. 3-4-1-1 Check for errors 3-4-1-3 POST done - prepare to boot operating system. 3-4-2-1 One beep. 3-4-2-3 Check password (optional). 3-4-3-1 Clear global descriptor table. 3-4-4-1 Clear parity checkers. 3-4-4-3 Clear screen (optional). 3-4-4-4 Check virus and backup reminders. 4-1-1-1 Try to boot with INT 19. 4-2-1-1 Interrupt handler error. 4-2-1-3 Unknown interrupt error. 4-2-2-1 Pending interrupt error. 4-2-2-3 Initialize option ROM error. 4-2-3-1 Shutdown error. 4-2-3-3 Extended Block Move. 4-2-4-1 Shutdown 10 error. 4-3-1-3 Initialize the chipset. 4-3-1-4 Initialize refresh counter. 4-3-2-1 Check for Forced Flash. 4-3-2-2 Check HW status of ROM. 4-3-2-3 BIOS ROM is OK. 4-3-2-4 Do a complete RAM test. 4-3-3-1 Do OEM initialization. 4-3-3-2 Initialize interrupt controller. 4-3-3-3 Read in bootstrap code. 4-3-3-4 Initialize all vectors. 4-3-4-1 Boot the Flash program. 4-3-4-2 Initialize the boot device. 4-3-4-3 Boot code was read OK.
Jul 09, 2014 | EliteGroup GeForce6100PM-M2 Motherboard
The application failed to initialize properly (0xc0000135). Click on OK to terminate the application. how to fix
This error is down to a NET. Framework v1.1 error first of all check which versions you have installed HERE with the correct SP1
run the checker and then if it is missing download the dotnet redist v.1.1 package HERE and then apply SP1 from above.
If it is corrupt then use the removal tool from the NET. Framework Tools aboive and then reinstall as before.
Then restart your PC and check to see if the error has gone.
Sep 23, 2009 | Dell Inspiron 9300 Notebook
Frontech tv tuner, windows vista, hardware initialize failure!!!
Is the driver you are using specific to Vista? Have you verified on frontech's website that there are no newer drivers available?
Jun 24, 2009 | Computers & Internet
No display lights
Run the PSA Diagnostics and Obtain the PSA Error Code
To run the PSA diagnostics and obtain the PSA error code, perform the following steps:
Shutdown the computer.
Press and hold the <Fn> key, then press and release the power button.
Release the <Fn> key when the lock lights above the keyboard begin to flash or Diagnostic boot selected is displayed in the upper right corner of the screen.
Release the <Fn> key.
The PSA diagnostics sequence begins.
After approximately 2 minutes the system produces a number of alert tones.
After the alert tones, the system produces either a series of low beeps or error codes.
PSA diagnostics will prompt for input during some tests. The resulting error message does not necessarily indicate hardware failure.
For example, input is required during the color bar test. Failure to input a response will eventually result in a timeout error: 1000-0333 Graphics test timed out waiting for keyboard response. This does not indicate a graphics failure has occurred.
Note the sequence of beeps or error codes.
Initialize LCD BIST Diagnostics
You can initialize the LCD Built-in Self Test (BIST) in two ways, depending on the revision of Pre-boot System Assessment (PSA) diagnostics:
PSA versions 3019 and greater run LCD BIST immediately after failing the color bar test, via user input of <N> or waiting for it to time out prior to generating the 3-3-3 or 3-3-4 error. PSA version 3019 became available in November 2005 on various Dell laptops. The PSA version is upgraded with the BIOS.
With older versions of PSA diagnostics prior to November 2005, LCD BIST runs after responding with a <Y> after receiving a 3-3-3 or 3-3-4 error code.
To initiate the LCD BIST on PSA versions 3019 and greater:
Boot to the PSA Diagnostics.
Watch the screen and listen for the color bar test prompt tones emitted by the PSA Diagnostics. If the screen is visible, one will see the PSA diagnostics draw a series of multi-colored bars across the screen. When completed, a prompt asking if the pattern was seen appears, accompanied by a brief series of tones.
Press <N> or wait approximately 30 seconds to fail the color bar test.
Watch for the LCD BIST color generation and listen for the beeps every 2 seconds that indicate LCD BIST is running.
LCD BIST runs for approximately 20 seconds, then stops. The 3-3-3 or 3-3-4 error code is then displayed when the LCD BIST is complete. If LCD BIST does not initialize, then the system may not have been upgraded to PSA version 3019.
To initiate LCD BIST on systems with PSA versions prior to 3019:
The system emits a 3-3-3 or 3-3-4 PSA error after failing the color bar test. Wait for two iterations of the failure code and then press <Y>.
On a working LCD, the PSA diagnostics shows the following message:
Error Detected, continue testing? Yes or No or Retry.
Watch for the BIST color generation and listen for the single beeps that indicate LCD BIST is running.
Patterns of flashing color should appear on the screen. With every color change, an audible beep is heard. If the patterns of color do not appear, and the beeps are audible, an LCD failure may be the issue. If the patterns of color appear, a video card or motherboard failure may be the issue.
Thanks and Goood luck! =)
Jan 03, 2009 | Dell Inspiron 9100 Notebook
I'm am trying to play age of mythology and after the movie ends, error appears and states "initialization failed".
Initialization failed
This means that the game is attempting to initialize hardware such as the video card but has failed
This can be caused by a number of factors.
1. Your hardware does not meet the games hardware requirements
2. Your hardware requires farther configuration to run the game properly
if you are certan that the game supports your hardware you may need to perform
some extra steps to get your game working
"Failed to initialize" is an incomplete error message because it does not tell you what exactly failed
a more complete error message would read "Failed to initialize the video subsystem" and then it would give an error code such as Error Code xxx telling you exactly what error code to look up
to determine what exactly failed.
Most of the time when a game says ( failed to initialize ) that means a video issue
this may mean missing files or wrong versions of files or incompatable hardware.
Sep 15, 2008 | Computers & Internet
Computer crashed
that is a memory dump, try to remember what hardware or software did you install or uninstalled recently, if you can log-in on windows try uninstalling or reinstalling the hardware or the software. if it fails, run the windows recovery on the cd and repair the windows installation.
Feb 18, 2008 | Dell Inspiron 6000 Notebook
Acer 5100 will not logon
Try it in SAFE MODE... this will fix errors... then restart the computer.
Jan 30, 2008 | Acer Aspire 5100 Notebook
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at if you need further assistance.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
ENLTV- Failed to initialize Hardware. followed steps. STILL PROBLEM!!!!!
Look at the FAQ in "When you see "Failed to Initialize Hardware" message, please be sure Video Card driver and Sound Card driver are properly installed by checking Device Manager under Computer Management. If the above conditions are met and you are still experiencing problem, it is necessary to perform a hardware reset procedure on the card. Here's how: power down the computer, unplug the TV Tuner Card from the motherboard, remove the jumper on the card (pin 2 and 3) and then put it back. Power back up the computer and then try to run the software again." It seems that the card have some kind of issue that "hangs" its hardware, you should try also another TV Program like K-TV. Mine did exactly that "Failed to initalize Hardware" but the free K-TV program worked! :)
Nov 30, 2006 | Encore ENLTV-FM-HA (CTETVC)
3,032 people viewed this question
Top Encore Televison & Video Experts
Are you an Encore Televison and Video Expert? Answer questions, earn points and help others
