Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Screen went black and never ressurected
In the middle of the game, the TV hummed for 2 seconds and went black.
I unplugged the TV for 1 minute and plugged it in again - no power/black screen.
The cable is on, and working, and the power outlet is fine, because my DVD player works fine.
The rear of the TV says Model:32S22
Serial #: 8118902
Also, It says April 1998.
Is this repairable?
Any advice?
Cheers
  • 962 Answers
It is repairable.Open the TV and check the fuse and then the flyback transformer for any loose soldering. check for obvious burnt transisters, resistors, capacitors etc. the flyback is the component that has a wire to the picture screen on the inside of the TV. Be careful. Capacitors and picture tubes retain high current. If you don't know what your doing take it for repair.
Posted on Dec 29, 2008
My Nintendo 64 when I was in the middle of a game it froze and the screen went all black and then it went to the tv screen saying no signal then.
Well one time I had this problem with my Nintendo 64 console when I was in the middle of playing perfect dark the screen had froze went black and then it went to saying no signal on the tv screen. The console did not over heat to cause this problem. I thought that it had died on me but I had tried a new expansion pack and it was fine after that. SOmetimes the expansion packs can blank out in the middle of a game play they can die without a warning then. Or it can say expansion pack needed or it will give the white flash that it is turning on but nothing happens after that then.
Mar 22, 2016 | Nintendo 64 Console
My black ops was working fine until i downloaded and installed ressurection zombie maps. then everytime i go to to start the game it comes up with the 3d support and then turns blank screen, then a co
this is a really often problem, lat year i just brought black ops from the game store and installed it with ressurection zombie map. and in the install note it syas that the maps doesnt work for this time. maybe you can find the solution on activision support center.
Dec 18, 2014 | Video Game Consoles & Games
Was playing Super Smash Brothers, played 1 5 stock 1v1v1v1 against 3 computers, then went and started a second round. It lasted for about a minute or 2 and then it locked up... i hit the reset button, and...
Well I think that the expansion pack has died I had a problem while I was in the middle of perfect dark it would freeze and then 2 seconds later the screen went black and than it went to the tv screen saying no signal. the expansion packs make it look like it died but it didn't.
Nov 01, 2010 | Nintendo 64 Console
Sony ke42m1 plasma 1-1/2 black line down the middle vertically of the screen pic is otherwise clear started as a thin green line down the middle which would go away after a minute or so than the black...
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jul 31, 2010 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
I have a Mitsubishi WT-42311. Last week the
where you saw blue it sounds like your blue crt is shorting out could be just the video amp so
i would suggest you have a tech look at it for and estimate
Nov 24, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Problem with Poloroid LCD 32 in. TV
stiv0's Support Profile at FixYa will give you detailed instructions for repairing your set
Jan 15, 2009 | Polaroid FLM-3732 Television
Intermittant white line with subsequent shut down
You have a vert ic problem very common tv problem.
POSSIABLE SOLUTIONS
1 COLD SOLDER JOINTS ON IC REPAIR COST IS 95.00
2 REPLACEMENT IC 120.00
CALL LOCAL TV SHOP AND ASK FOR PRICES ON A VERTICALE IC REPLACEMT. THANKS DOCTOR VIDEO
May 17, 2008 | Hitachi 36UX59B 36" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
67 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
