Speakers produce a very faint sound and once the volume is increased a crackling noise is created instead of desired sound
SOURCE: Noise when changing the volume and connecting speaker to anything.
firstly check the cable, some times it may in loose contact
otherwise any radiation equipment is located near by the amplifier,
sol. replace the location of the amp. and check cable loose contact
other wise
it is due to its amplifier IC problem, it is weak due to over load signal, or temperature of IC make leakage
sol.replace IC
SOURCE: My logitech x-210 speakers make a buzzing sound
Sounds like the speakers are not plugged in to the computer, or are plugged in to the wrong socket.
The speaker socket on a PC is usually green, a 3.5mm stereo socket.
SOURCE: my logitech s-120 speakers crackle
hi there,
The problem is actually from the speakers themselves. If it's not a year old you might want to bring it back to the store where you purchased it for a warranty repair or replacement.
Sadly the problem is inside the speaker and it could be a loose connection inside. If you're comfortable enough you can try to open the speakers and check inside for any loose wires which cause unstability of sound or for any loosed fittings from the magnet.
Hope this helps!
SOURCE: Have Logitech small speakers for
click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
you might need to select stereo speakers
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also if you have the right ones selected
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
