Question about Goodman GDS80904BNA Open Flame Heater
GDS80904BXBC WILL FIRE FOR A FEW SECONDS AND THEN FUSE BLOWS
This furnance turns on when powered on but after a second the fuse will blow out. The amps on the fuse are correct.
    Problem Solver:
  • 6 Answers
If it is the fuse on the furnace board,disconnect all low voltage wires to r-g-w-y-c.make sure you label where they go.jump out red to white if unit comes on and runs,chances are you have a bad t-stat wire or tstat.
Posted on Dec 31, 2008
98 Dodge Caravan keeps blowing the wiper fuse. Works for a few seconds then blows.
check for bare wires grounding out , wiper motor failure or wiper shafts seizing up and overloading the motor
using a bigger fuse will only result in the wiring harness burning out and possible fire in the car
May 21, 2017 | Dodge Cars & Trucks
50A IGN Starter SW/ Starter fuse blows every time I start the vehicle
Run a jumper from the fuse connection to the starter
Nov 13, 2015 | 1998 Dodge Durango
Works a few seconds then the fuse blows. model#JES13845F
Fuse holders sometimes become weak due to heating. If the fuse is not held very tightly by the holder, the fuse will blow because it gets hot, not because the current exceeds the fuse's rating. If this is the case, replacing the fuse holder would be in order. This is not to be confused with the situation where the fuse blows when the door is opened or closed. In that case it's a door switch sequencing issue, or a bad switch.
May 04, 2014 | Microwave Ovens
Awz8812 blows fuse
what 13 amp external fuse are you speaking about? if this is a power line fuse feeding the dryer then its way too small normally you use 2 30 amp fuses or a 30 amp tandem pole breaker to power the receptacle where the dryer plug plugs in
May 05, 2012 | Whirlpool GEW9250 Electric Dryer
What makes a fuse blow after being on for about 15 seconds
Hi Bill,
Either a short or too small a fuse.
Many fuses are what they call, 'Slo-Blo'. they are designed to take high current for a few seconds before blowing. This prevents normal power surges from blowing the fuses.
If this is happing every time you replace the fuse, something is wrong internally that requires attention.
Remember, the fuse blows to protect the equipment. The next step is to find out what is making the fuse blow.
If it's under warranty, don't open it up. just exchange it.
As for the reason it's blowing, you would need to post all the symptoms.
Best regards
Mike
Dec 26, 2009 | JVC KD-LX30 CD Player
When i turn on the A/C the fuse blows. I tried a
A bigger fuse can burn things, be careful.
You have an amp draw bigger than the fuse can take, that's why it blows, and the clutch on the compressor for the A/C may be your culprit. If you can unplug the wiring to the compressor, replace the fuse with the correct one, and see if it fails then.
Jul 10, 2009 | 1999 Mitsubishi Mirage
Buzzes when starting then blows the fuse
there is an electrical problem.
my suggestion is that you will have to dispose that microwave and get a new one.
you dont want to chance a fire. andwave c yes mircroan cause fires.
Apr 26, 2009 | Microwave Ovens
Wont turn on
If it blows the fuse as soon as you hit the START button, it's almost certainly a shorted high-voltage capacitor.
If it blows a few seconds after you hit the START button, it's probably the high-voltage transformer. You'll possibly also smell a faint electrical burning smell from the rear vent after you shut if off.
If it blows the fuse as soon as it's plugged in, you probably have a shorted door switch, a shorted varistor, or an internally exposed wire shorting to the chassis, etc.
Nov 11, 2007 | Frigidaire GLMB209D Microwave Oven
Whirlpool Microwave Model MH6130EQ0
If the fuse blows as soon as you hit START, then it's likely that you have a shorted high-voltage capacitor. If the fuse blows a few seconds after you hit START, then it's likely that you have an overheating / shorting high-voltage transformer. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Sep 04, 2007 | Microwave Ovens
Heating & Cooling Logo
85 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
