I have a Whirlpool bottom mount freezer that is about 15 years old,the refrigrator stopped working (not blowing cold air) but the freezer is still working.I was wondering what kind of problems might cause this and if this thing is worth fixing.Thanks
Morning, This seems quite a easy problem to fix.! Check to see if the f/.freezer has to compressors (motors)? If so the you find that is more than likely to be that the fridge thermostat has broken. A very easy way of checking if you electrially minded is to remove the thermostat from the housing a connect the live and common wires together and switch on, It then should switch on if there is no other problems, Then just replace the stat.
Good luck......
