Question about GE Energy Star WCVH6260F Front Load Washer
GE Front loader is vibrating wildly during spin cycle, even low.
The washer seems like it will explode while spinning, even at the low setting.  Also I noticed that the round rubber housing at the opening is not exactly lined up with the arrow on the white metal.  As a result there is a 'crinckle' in the rubber housing.  I cannot remove the rubber housing and it came from the factory that way.  Will that affect the drainage of water from the housing?
  • protzel Dec 29, 2008
    GE front loader washer, vibrates wildly suring the spin cycle. Please advise.
  • Jenna Hughes May 17, 2009
    I have the same problem with a new GE front load model wcvh6400j1ww--when spins it sounds like it's going to blow up! I haven't checked the shipping bolts cause I can't move the thing; it was installed by a supposed professional...
Did you remove shipping bolts in back? Should be 4 .
Posted on Jan 05, 2009
My front loader shakes.. when in the wash and spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 13, 2010 | GE WSXH208A Front Load Washer
Banging noise during spin cycle
weight not distabuted in washer move cloths around so its even
Feb 10, 2010 | Washing Machines
Clothes washer vibration during spin cycles
the vibration and noise is most likely from the drum bearings wearing out to test the bearings try this out,,,
open the door, hold the top of the drum and lift it up, if it has any free lift in it the bearings are going, now spin the drum by hand and you should here the rumble off the bearings
Dec 29, 2009 | GE WPXH214A Front Load Washer
Vibrates during spin cycle
front loaders are made to sit on concrete they probably didnt tell you when you purchased it if its on wood floor not much you can do
Jul 05, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer vibrates during spin cycle
Front loaders have to be situated on solid flooring such as a basement or they will vibrate.
http://tclaundryrepair.com/
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Vibration during spin cycle
Dec 13, 2008 | LG WM2688HWM TROMM SteamWasher
Shuts off in middle of cycle
I am having the same problem w/ our brand new front loader washer, it pauses constantly, and even when I can get the load to finish, I have to drain and spin atleast 3 x before I can even attempt to put in dryer, at this point it is taking me hours to do one load of laundry!!
Ugh-- Service man is coming tomorrow, so I will share what I learn...
Apr 19, 2008 | GE WBVH6240F Front Load Washer
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
456 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
