I have lan with internet connection via switch... but only one machine is working.. remaining machines r not woriking... it shows locan are network cable unplugged.. switch is working properly....
  • Patrick Luhrs May 11, 2010
    What is the brand/model of the switch? Also, what operating systems are the computers running on?
  • 176 Answers
Check TCP/IP Properties and Advanced settings at each non-working PC ( obtain IP address automatically, DHCP is enabled, obtain DNS, etc) that the network cards are not disabled and also configured correctly. Also check "Internet Connection Sharing" options are correct. Check cables, link lights. Ping and that theres a reply to each address.
Posted on Dec 29, 2008
How do i connect to apples time machine?
You can manually configure the time machine to accept wireless signal from the router or extender. If you setup WEP on the router or extender, make sure you setup WEP on the time machine as well.
For instructions in setting up wireless settings of Time Capsule click on this link -->>
Hope this works for you.
Nov 10, 2011 | NetGear WNR2000 Wireless Router
How to use switch?? this is the topology INTERNET->MODEM->ROUTER AS AP ->...
Switch learns network MAC addresses And controls the network packets to reduce broadcast packet traffic on your network !
INTERNET V MODEM V Back of router ethernet port 1 V ROUTER AS AP Wi Fi Back of router ethernet port 2 V Switch Port V V
-> STATION Client/ /CLIENT ' Local/Lan
INTERNET V MODEM V Could Place Switch in Here instead Switch Port V V V ROUTER Station V AS AP Wi Fi client V V Client/ Local/Lan
May 03, 2017 | TP-LINK TL-SF 1008 P 8-port 10/100 PoE...
I am trying to install a Netgear router after my switch. I end up having no internet on some of the computers connected to the hub and none on the router. If I configure the router as a dhcp client...
You'll want to configure your router as a dhcp server. Connect the switch to your router's lan port. Connect the remaining devices to a port on the switch. Your wireless access point should have it's dhcp server disabled. You can only have one dhcp server per network. The wireless can get it's address from the router's dhcp and the wireless client devices will get their ip address from the router, as well. If your wireless access point is a router with a wan/broadband port and some switch ports you will want to make sure that you are connecting to your Asus switch via one of the switch ports.
Be sure that your client devices are configured to get their ip address via dhcp and you should be surfing the interweb in no time flat.
Oct 21, 2010 | ASUS GX1008B 10100Mbps Desktop Unmanaged...
Hp pavilion a330n Internet Explorer won't connect.
check your IP Adress settings are correct for this machine,
Go to start ,then click on run,Type CMD,Then type IPCONFIG/ will show you a list of all the devices connected to your machine and your local network,
Have you got LAN & WLAN adaptors on board?
this will explain your message,
you will have to set the ip settings on each adaptor
ie LAN and WLAN
This wiil help determine which adaptor is to be used when connecting to the network and the internet.
If your using wireless on computer to connect to the internet then run your wizard to help setup the connection
Same for the wired LAN ,use your wizard
The settings for your modem can be reset easily and your ISP will help get you connected to the net because you already have an account with them,
Apr 10, 2010 | HP Pavilion a330n (Refurbished)...
Internet no longer working, but internal network is fine.
i agree with all the above.. it's definately clear as mud how the network is designed and or funtioning. The machines connected to the wireless d-link router.. are they via cat5 inthe wired ports or wireless ? is the server the machine thats connecting to the switch and wiress router and modem? i'd say reset all switches modems routers and machines.. shut them all down.. then fire the cable modem, then the wireless router then the desktop switch then the server, the workstations and the one lonely wireless.. run "ipconfig /all" on all machines and if they aren't all sharing common ips and access, provide the results here for further investigation.
May 20, 2009 | Dell Dimension 2400 PC Desktop
D-link DI-524 wireless - lan network connection
Yep. Vista sucks :-)
In the vista machine, you have to turn on a whole bunch of options. Right click Network, hilghlight properties and left click and it opens up Network and Sharing Center. Down at the bottom, you have a list of options. Start by turning on the options you need: File Sharing, Public File sharing, Printer Sharing etc. I'm pretty sure it's already done in the XP machine, but if not, check there too.
It should start to show network files between machines.
Oct 19, 2008 | D-Link AirPlus DI-524 Wireless Router
Lan problem
Go to the e-machine's amin website and go to help and support. enter your system model and download the network adapter driver for that specific model. if it dosen't work let me know.
Jamiell S.Joseph
Please rate me. Thank You.
May 17, 2008 | E-Machines eMachines Desktop PC
Unable to connect via LAN with wireless router NETGEAR WPN824
I recently experienced this on laptop and desktop, using a lynksys wireless. I was able to go into each system to network connections, and tell it to connect. I haven't had a problem since........hope this helps you!
Dec 24, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
