My Xerox machine is out of cartridge - Office Equipment & Supplies
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
You will have a xerox sticker on your machine and on it you will have a contact number there.
Posted on Dec 17, 2009
Toner control system failure
try a different toner cartridge. sounds defective cartridge'
Aug 04, 2015 | Xerox Office Equipment & Supplies
Can you reset toner level in Xerox DocuColor 260?
Usualy what i did i use toner chip (100%) fix it to toner cartridge then insert to machine, check the amount if 100% then pull out the toner cartridge and replace old chip insert back to the machine, check it will be 75%.
Sep 05, 2014 | Xerox DocuColor 242-252-260 PS
Xerox 7760 toner
Solutions for : How To Replace the Toner or Print Cartridge
This product can be configured to use a metered or non-metered Toner / Print Cartridge. A non-metered machine requires a non-metered cartridge be installed to operate, while a metered machine can accept both a metered or non-metered cartridge to operate.
Make sure the correct cartridge is used for the machine. If you are receiving metered print cartridges but the machine will not accept them, contact your reseller or supplier to ensure that your machine is properly set up as a metered machine, and that the metered PIN has been entered." In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Epson Printer Support Xerox Printer Support
Feb 26, 2014 | Office Equipment & Supplies
Xerox 4250 photoreceptor error
I have a Xerox 4250. After the ink cartridge ran out I replaced it with a new one and got the "replace photoreceptor cartridge" message. Reinserted the cartridge and it stayed. Called Xerox and they couldn't explain. I turned the machine off and on and the message changed to "replace photoreceptor cartridge" but an additional message of replace Smart Drum came up. I replaced the Smart Drum and it is working fine now. Note: I really don't think it was time to replace the Smart Drum. But the nearest authorized service provider was 3.5 hours away and this had to be cheaper than a service call from that distance.
Jun 25, 2012 | Xerox Office Equipment & Supplies
Xerox mfp 3200 problem is after riffling cartridge two times now machine showing install toner
on your toner cartridge there is a slot for a chip. Usualy the chip needs to be replaced on eache refil.
In your case you will need a chip for the toner cartridge so that your machine can continue to work.
Jun 06, 2011 | Xerox Phaser 3200MFP/N Laser Printer
How do you change the toner cartridge on the xerox workcentre pro 423?
You can always find your solution to a Xerox problem at the Xerox Knowledgebase. Here is the direct link to this solution with pictures! http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=467,E=0000000002703228701,K=8434,Sxi=4,Case=obj(862)
Solution : Replace the Drum / Toner (Dry Ink) Cartridge
CAUTION: Do not use warm water or cleaning solvents to remove Toner (Dry Ink) from your skin or clothing. This will set the Toner and make it difficult to remove. If any Toner gets on your skin or clothing, use a brush to remove the Toner, blow it off, or wash it off with cold water and mild soap. If not, launder your clothes with detergent and cold water. If the fabric label says to dry clean, inform a commercial dry cleaner that the spot is Toner so that they will not use a solvent that will set the stain.
NOTE: Make sure the Cartridge part number corresponds to the machine model. If an incorrect Cartridge is installed the message 'Check Drum / Toner (Dry Ink) Cartridge Message' will continue to appear on the machine display.
  1. While lifting the upper, right-hand cover release lever of the machine, pull the upper right hand cover towards the right until it stops.
  2. Open the Front Cover on the machine.
  3. Grasp the Cartridge by the handle on the front, and slide it toward you until the top handle is completely clear of the machine.
  4. Lift up on the top handle and slide the cartridge out of the machine.
  5. CAUTION: Do not shake the cartridge and this could cause the Toner to spill.
  6. Before you remove the new cartridge from the bag, shake it vigorously from side to side several times to loosen the contents.
  7. Holding the new cartridge by the top handle, begin sliding it into the machine as indicated in the picture above. Do not push on the handle on the front of the cartridge as the cartridge will jam.
  8. Hold the cartridge in place and pull the Toner seal tape until the cartridge is completely in place.
  9. Close the Front Cover.
  10. Close the upper right-hand cover.
  11. If necessary, press [C] on the Control Panel to clear any messages. The system will initiate a Copy Quality adjustment cycle after you press the [Start] button.
Mar 01, 2011 | Xerox WorkCentre Pro 423 Copier
Trying to clear the memory of a Xerox Faxcentre F116. Do you know the steps to accomplish this?
One needs to know what they are doing when resetting memory to the machine.
When resetting the machine, one needs to consider, the loss of memory data on the copy cartridge counter in the machine.
When resetting memory a copy toner cartridge needs to be in stock with a counter reset card.
Erasing memory will wipe out the old copy/toner cartridge odometer setting, resuling in "Replace toner/cartridge" error.
Please clarify which memory area is being erased.
Aug 05, 2010 | Xerox FaxCentre F116 Plain Paper Laser
Xerox XC820 Copy Machine
three lights are for paper jam, replace toner cartridge and replace dru, cartridge. If there is zigzag line it is paper jam if there are six small dots it is for toner cartridge and if it is one circle it is for copy cartdisge. You can contact me for mfurther support at jagpal_65@yahoo.com
Dec 25, 2008 | Xerox XDL-33D Black and White Copier
Our xerox M118 showing an error"replace drum cartridge'can any one help me?Plizzz
Hello, Your Xerox has two cartridges - one is the drum cartridge and the other is a toner cartridge. Please check the following I've researched from your user guide:
Replacing the Drum Cartridge
The drum cartridge is a customer replaceable unit. After approximately 55,000 copies/
prints, the machine will display a warning message before the drum reaches the end of
life. Order a replacement cartridge now to insure continuous operation.
Country Part Number for the drum cartridge replacement
All countries 13R589
Removing the Old Drum Cartridge
1. Pull the front cover towards you to open it.
2. Open Tray 5 (bypass tray) if necessary, and then open Cover A while lifting up
the release lever.
3. Lift up the colored lever, and slide the drum cartridge out until you can lift the
handle on top of the cartridge.
4. Hold the handle and remove the cartridge from the machine.
NOTE: When replacing the drum cartridge, make sure that the new cartridge is the
correct one specified for the machine.
Recycling the Drum Cartridge
The drum cartridge is designed to be re-manufactured. To recycle used drum
cartridges, return them to Xerox in the original packaging. Return labels are included
with each new cartridge.
Inserting the New Drum Cartridge
1. Remove the new drum cartridge from the box.
2. Undo the sealing tape and carefully pull out in the direction of the arrow to
remove the black protective sheet from the cartridge.
3. Place the cartridge in position and, using the handle, slide it into the
machine until it clicks.
4. Pull out the cartridge tape completely without breaking it.
5. Push the cartridge again so that it is correctly placed.
6. Close Cover A until it latches and then close Tray 5 (bypass tray).
7. Close the front cover.
Hope this helps. Good luck.
Dec 11, 2008 | Xerox WorkCentre M118 Black and White...
22 people viewed this question
k24674
jasbo
jasbo
