Question about Kenmore 16919 Built-in Dishwasher
Foggy stains I have tried every solution to wash my dishes and clearing agents. But I still have a lot of water fog stains. I am not sure if it is the water or the dishwasher! Help
  • jack_z Feb 01, 2009
    Same problem and more.....stains on stainless silverware. Tried all of the soaps available. Pot lids at have water held on them before drying - stained as they dry. Could it be possible the drying cycle is too hot?
    President:
  • 2,692 Answers
It is/was the detergent that was used to wash the dishes with.
Posted on Dec 29, 2008
My Maytag quiet series 200 is not cleaning and despite many attempts it is also leaving terrible residue on dishes.
I found this on ehow I believe it will help. How to Troubleshoot Dishwasher Residue By Dale Yalanovsky eHow Contributor
5Found This HelpfulGeorge Doyle/Stockbyte/Getty images
Dishwater residue is a fairly common occurrence, and several things can cause it. Even the newest dishwashers may leave residue, and it might have nothing to do with the actual dishwasher function itself. However, there are things you can do to prevent, limit or completely remove dishwasher residue during every washing cycle.
Other People Are Reading
  1. Detergent Residue
    • Modern phosphate-free detergents are the main culprits when it comes to detergent residue. After every wash, many leave a slight whitish residue behind. After several washings, the residue becomes caked on and leaves a noticeable white tint to your dishes. Some dishwasher detergent brands are better than others, and either minimize residue or do not leave any. Once residue is present, however, the only way to remove it is by hand scrubbing or scraping.
    Hard-Water Residue
    • Hard-water residue comes from non-softened water from your hot water tank. Non-softened water leaves a white tint on dishes, but no amount of scrubbing will remove it. Only by wiping a small patch of the dish with vinegar or lemon juice will you be able to ascertain whether the white residue left is hard water or detergent. The slight acidic action of the vinegar or lemon juice removes hard-water stains, but they have no effect on detergent residue.
    Greasy Residue
    • If the dishes feel greasy when they come out of the dishwasher freshly washed, you are dealing with a greasy residue. There are two main reasons for this: either the detergent is not an effective grease remover, or the hot water inside of the dishwasher, either from the hot water tank or the dishwasher's heating elements, is not hot enough. Boosting the hot water temperature on the water tank may solve the problem, and a second wash cycle may be needed for the dishes. A preventive measure of running the dishwasher empty with a full load of detergent also removes the residue inside of the dishwasher.
    Streaking and Spotting Residue
    • If you have spotting or streaking on your dishes, that may be a sign you need a rinse agent. Many modern dishwashers recommend a rinse agent to prevent spotting or streaking, and without one, your dishes will never be crystal clear or streak-free. The next time you do a dishwasher load, add a rinse agent. If the dishes come out spot- and streak-free, the problem is solved.
Read more : http://www.ehow.com/info_12285021_troubleshoot-dishwasher-residue.html
May 19, 2015 | Maytag Dishwashers
Foggy headlight assembley
If the fog is on the outside, it is damage from dirt and rocks from the road. You can try sanding and buffing them (they sell kits for this purpose), but it's not that easy.
If the fog is on the inside, it may be that moisture has gotten into the assembly through a crack or loose seam. Remove the protective backing from the assembly and let the water evaporate. Find the crack or loose seam and seal it with clear caulk of some kind.
The only other choice is to replace the assembly.
Best wishes!
Jul 23, 2010 | 2001 Hyundai XG300
Grit on the dishes. Foggy glasses. Blue type stain on the stainless flatware and the stainless inside of the dishwasher is very cloudy and streaked. Many areas inside the dishwasher feel gritty.
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
May 03, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishes not coming out clean
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Apr 02, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
My dishwasher leaves the dishes opaque, and foggy. i tried many different kinds of soaps but the dishes are just not clear.
try changing your rins aid or turn the settin down. better still try the 3 in 1 tabs, buy a recomemded brand.
Jan 16, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Washing machine candy grand'o 1400 has stuck, vanish stain light
Ok, turn the washing machine off and unplud. Open the flap at the bottom left of the machine. Put a bucket underneath it. Unscrew the cap. Water will pour out - lots of it and very quickly - so make sure you have a bucket underneath it and lots of towels round that.
Once the water has drained out, check there are no blockages in there. You may find that some coins or buttons flush out with the water. That will be your problem.
Once clear, screw the plug back in and turn on machine.
Dec 23, 2009 | Candy Washing Machines
Wash cycle OK, but the drying cycle is faulty. The dishes are wet after 12 hours. Will not dry contents of washer! #SHU680SUC/U06
your heating coil has gone bad it`s that rod looking thing in the bottom of your unit under your spray washing spinner depending on the age of your unit your probley better off buying a new dishwasher
Oct 02, 2009 | Bosch Dishwashers
After running a full cycle dishes are covered in detergent residu
www.dishwasherfilter.com has a great product specifically for this problem. it filters the water going into your dishwasher removing the hard minerals that cause this problem. after the first load my dishes looked amazing. it is very affordable and fits right under your sink.
Apr 01, 2009 | Asko D3251HDSS Stainless Steel Built-in...
Dishwasher leaving a film on dishes
usual cause is rinse agent not being taken. check that level of rinse agent lowers over time
Apr 20, 2007 | GE 24 in. GSD3400G Built-in Dishwasher
Open Questions:
See all Kenmore 16919 Built-in Dishwasher Questions
Kenmore 16919 Built-in Dishwasher Logo
113 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
