Question about Motorola Mobility RAZR V3
Trying to pair omnitech 2.0 bluetooth headset without manual
I lost the manual for my new omnitech 2.0 bluetooth headset. I am trying to pair it with my lg chocolate phone. I went to menu on my phone, then settings, then bluetooth menu.
I clicked add new device. it then says place device you are connecting to in discoverable mode. i hit ok, it searches and says no device found.
How do I set the bluetooth headset to discoverable mode, as i assume this is the problem?
I also just bought a Parrot minikit slim and paired it in the same way with no problem.
  • 1 more comment
  • Anonymous Jan 02, 2009
    i have kind of the same problem but i lost the manual and i need the passcode for it
  • Anonymous Mar 14, 2014
    Trying to pair Nuvelli Stereo Bluetooth Headset with my iphone
Before attempting to pair your headset with another device, be sure that the bluetooth headset is in the off position
  • press and hold MFB until indicator light flashes blue and red. The headset will also beep twice
  • to pair your device to the bluetooth headset use the bluetooth pairing instructions from you device's instrucition manual.
  • input ID code 0000 when requested by the device
  • the headset and device are paired correctly when the blue and red indicator light flashes blue only.
Any questions email: shyrosi@yahoo.com Subject: omnitech bluetooth
Posted on Mar 09, 2009
If you hold the button (front top) for several seconds until the LED flashes blue then red it will be visible to pair...
Posted on Jan 05, 2009
I used 0000 it connected and I'm trying it out.
Posted on Feb 02, 2009
How do I get music to stream through my Omnitech bluetooth hands free device
You will have to pair the Bluetooth device.
Turn the media device on, then see the manual to set your Omnitech to pairing mode. This mostly is pressing 2 buttons for several seconds.
If the verslons of Bluetooth are too far apart of the both devices it might not work.
Hope this will help you.
Good luck,
A.Misset
Jan 03, 2015 | Radio Communications
I am trying to connect my H500 to my new
Enter '0000' (four zeros) when your phone requests a passkey whilst pairing with your headset.
Hope it works for you.
Cheers! Carlos
May 17, 2010 | Motorola Mobility Universal Bluetooth...
Ive lost my instructions for my headset device i need to know how to turn my phone to headset pairing mode
Hello my friend,do these steps
Pairing with another Bluetooth device
By pairing your KU990 and another device,
you can set up a passcode protected
connection. This means your pairing is
more secure.
1 Check your Bluetooth is On and Visible.
You can change your visibility in the
Settings menu.
2 Touch Paired Devices then New.
3 Your KU990 will search for devices.
When the search is completed Refresh
and Add will appear on screen.
4 Choose the device you want to pair with
and enter the passcode then touch OK.
5 Your phone will then connect to the other
device, on which you should enter the
same passcode.
6 You passcode protected Bluetooth
connection is now ready.
Using a Bluetooth headset
2 Follow the instructions that came with your
headset to place your headset in pairing
mode and pair your devices.
3 Touch Yes to Connect now. Your KU990
will automatically switch to Headset profile.
If you have any questions you can try reading the manual here
http://www.in.lge.com/Product/Manual/KU990.pdf
Jan 11, 2010 | LG KU990 Viewty
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 | Cell Phones
Im trying to pair my verizon cell phone to my motoral headset
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’.
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | Motorola Mobility Bluetooth Hands Free...
Troubleshooting?lost manual
Begin with headset turned off.
1. Press call control button for
6 seconds. Release button when
red. Headset is ready to pair with
Bluetooth device.
NOTE The headset can pair to
multiple Bluetooth devices, but
will only connect to one device
at a time. The headset will automatically
connect to the last
device to which it was connected.
2. While the headset is flashing red
and blue, use the phone menu
and select “3XXPlantronics”.
3. When prompted for passkey enter
0000. Headset will flash blue when
paired successfully.
Apr 15, 2008 | Plantronics Explorer 330 Headset
LG Bluetooth HBM -500 Passcode for pairing
I HAVE LOST MY Bluetooth H500 Manual, can you assist with passcode.
Dec 11, 2007 | Motorola Mobility HS850 Consumer Headset
Samsung 200 bluetooth
I had the same problem. To fix this, you need to keep hold of the button when you are turning it on until the light stays on - this is pairing mode. When the light is on, search for it on your phone and pair them up.
Dec 01, 2007 | Eforcity Samsung Bluetooth Headset WEP200...
What is the default passcode for the Logitech F-0228A Mobile Freedom headset?
Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Pair Your Headset
Before using, you must pair your headset.
1. Turn phone on.
2. With Headset off, push Talk/Volume up button for 10 seconds. Blue LED will flash rapidly.
3. Follow pairing instructions in phone-setup or connect menu. Your phone should find “Logitech
HS04VXX”Headset and prompt you for a passkey pin.
4. Enter “0000”.
5. Press OK on phone.
6. From Headset device list press “Logitech HS04VXX” Headset.
7. Select connect.
When your Headset is successfully paired, the blue LED will flash slowly.
Nov 11, 2007 | Logitech Mobile Freedom Wireless Headset
Headset setup
http://www.plantronics.com/north_america/en_US/products/cat1150057/cat1150057/prod5560012?prodfind=true&mftr=MOTOROLA Go to this website, and scroll down to Interactive Bluetooth Pairing Guide. (Plantronics 330 - V555 doesn't show 320 and instructions will be similiar). Click on Interactive Bluetooth Pairing Guide and a tutorial will walk you through the steps. Have headset and phone together when you do this and both must be charged. Hope this was helpful. Pam
Jun 11, 2007 | Plantronics Explorer 320 Wireless Headset
Motorola Mobility RAZR V3 Logo
1,822 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
