Question about Cardinal Airlife Brand Misty Max 10 Disposable Nebulizer W/aerosol Mask 7" Tubing
How to set date and time on a sports cardinal watch
Could you help me with setup of my watch. It is a woman's sports watch Model 1153 with 2 bottons on the right side and one on the left.
  • kaytee_W Jan 04, 2009
    I have the identical problem.
  • bacio_53 Mar 06, 2009
    I have the same problem
Hold the mode button down for about 3 seconds or until the alarm time starts flashing. Use start/stop button to select what number on the display to change. Use reset button to change the number. Push mode button again to return to normal operation.
To change the time, hold the mode button down for about 3 seconds until the numbers flash. Then release mode button and then press it once again. The time programming screen should be showing. Use start/stop to select the numbers on the display to change. Use reset button to change the number. Use mode button to exit programming.
Posted on Apr 07, 2009
  • caper_girl Mar 18, 2011
    Thank you :)
  • Stephanie Jackson
    Stephanie Jackson Aug 29, 2014
    This did not work my watch has 4 buttons 1.light 2.mode 3. set/reset 4. start/stop and 3 windows. when I hold mode SP appears where the mounth usually is so I have to press mode again for the alarm to appear. I can change it to the correct time but when I hit mode to keep what I set TR appears where alarm did and then I press mode again a different time appears with the mounth??? Do you know how to fix my watch? Thanks ~S
CARDINAL CAPRICE INSTRUCTION MANUAL
CARE OF YOUR WATCH
1. This watch contains precise electronic components. Never attempt to open the case or remove the back cover.
2. Do not operate push buttons below the surface of the water when swimming or diving.
3. Should water-condensation appear in the watch, immediately have the watch checked. Water can corrode electronic parts inside the case.
4. Avoid severe impact: The watch is designed to withstand impact under normal use, it is inadvisable to subject it to severe impact of rough usage or drop onto hard surface.
5. Avoid exposing the watch to temperature extremes.
6. Clean the watch with a soft cloth and clean water only. Avoid using chemicals, especially soap.
7. Keep your watch away from the conditions of strong electric field and static electricity.
FEATURES AND SPECIFICATIONS
1. Accuracy at normal temperature: not more than 30 seconds a month.
2. Time keeping mode: hours, minutes, seconds, month, date, day of week. "M" (only available in 12 hour format )
3. Alarm Mode: daily alarm.
4. Stop watch Mode: Measuring unit: 1/100 of second measuring capacity 23.59'59"
5. Normal operating temperature range: 10C-40C.
6. Battery type: CR1220.
HOW TO USE THE CHRONOGRAPH
From the normal time display, press S3 once to enter chronograph function.
Simple usage:
Press S1 to start counting Press S1 again to stop counting Press S2 to reset to zero
Press S3 to return to normal display (this can be done at any time with the chronograph still running) Advanced usage (LAP function) Press S1 to start counting
Press S2 first time split T1 (0 to T1) shows. The numbers stop flashing, but chronograph is still counting in fact.
Press S2 again to continue counting
Further press S2, the second split time T2 (0 to T2) shows. This operation can, be repeated and the splits time can be read: 0 to T3, 0 to T4 etc.
Press S1 to stop the time counting of the chronograph.
Press S2, the last split time Tn (0 to Tn) shows.
Press S2 again, the chronograph is reset to zero. Press S3 to return to normal display.
How to set date and time on a sports cardinal watc - inbox?number=3426045416&part=1.2.2
HOW TO SET ALARM TIME
You can set alarm with hours and minutes. When the alarm is on the alarm(BI BI) sounds for 20 seconds at the preset time. Press S2 to stop the alarm after it starts sounding.
From the normal time display, press S3 and hold for 3 seconds alarm time shows
Now hours will flash Press S2 to advance
Press S1 - minutes will flash, Press S2 to advance
While advancing holding S2 will hasten the process. Press S3 to return to normal time display.
ALARM & CHIME ON/OFF
From the normal time display, hold S2 and then press SQ to activate or turn off the alarm and/or chime. When chime is on, the chime
signal appears and there is one beep every hour. When alarm is on, the alarm signal appears and It will sound for 20 seconds at the preset time.
HOW TO SET NORMAL TIME /CALENDAR
From the normal time display, press S3 and hold for 3 seconds, the alarm time shows. Press S3 again to set normal time and calendar
First - seconds will flash. Press S2 to reset to 00
(if seconds in the range of 30 to 59, minutes will add 1; if seconds in the range of 00 to 29, minutes will not be changed.)
1st Press S1 - minutes will flash-advance by pressing S2
2nd Press S1 - hours will flash-advance by pressing S2
3rd Press S1 - date will flash-advance by pressing S2
4th Press S1 - month will flash advance by pressing S2
5th Press S1 - day will flash-advance by pressing S2
While advancing, holding S2 will hasten the process. Press S3 at any stage to return to normal display.
HOW TO DISPLAY MONTH AND DATE
From the normal time display, hold S1 to read the data. Hod S1 and then Press S2, the mode of the display will change
between month/date and date/month format.
HOW TO CHANGE 12/24 HOUR FORMAT
From the normal time display, hold S2 or S1 and then press S3 to select 12 or 24 hour format.
402N293R
Posted on Nov 07, 2011
  • iamsonotobse
    iamsonotobse Mar 06, 2012
    great.. now which button is s1, s2 and sq?
  • 74 Answers
This link will allow you to request assistance..or a
users manual...I hope this helps.
http://www2.chammas.ca:7884/contact.html
Posted on Jan 07, 2009
I cannot set the time on a wr165
here's a simple instructions of setting your watch
Watch setup instructions
for the Armitron Instalite All-Sport :
Mode B / \ C Date
Light A \ / D Alarm
_____________________________________
Set time time / date
Press and hold B (Mode) untill alarm hours flash
Press D (Alarm) to advance these
Press B (Mode) again, seconds will flash,
press D (Alarm) to advance these
Press C (Date), minutes flash, press D to advance these
Press C again, hours flash, press D to advance these
Press C again, month flashes, press D to advance these
Press C again, Date flashes, press D to advance these
Press C again, Date flashes, press D to advance...... [suggestion from Chikita]]
Activating/Deactivating Hourly Chime
1. From "Normal Time Mode", press and hold "D" (Alarm) and
at the same time press "C" (Date) once. Hourly chime symbol,
( a house shape) appears in "chime" windows to indicate
the hourly chime will beep every hour.
Activatin/Deactivating Alarm
2. With "D" (Alarm) still pressed, press "C" (Date) again. Alarm symbol
( a clock shape with waves above it) appears in the
upper right to indicate the 24 hour alarm is now activated.
[I assume this "toggles" between off and on states,
so performing it again should turn off the alarm]
i hope this will help you.
Jul 22, 2011 | Armitron All Sport Digital watch
Unable to set day/date/year &time
Follow this link and download instructions for your watch:
http://www.armitron.com/watch_instructions.asp
Do not forget to rate, please.
Mar 11, 2009 | JCPenney Armitron Sport Watch
JC Penny's women Armitron pro sport model 44/1001 instructions
I'm trying to fix the time on my watch which is the Armitron Pro Sport 44=1001 Womans.
I am looking forward to your solution.
Mar 09, 2009 | JCPenney Armitron Sport Link Bracelet...
Ladies Cardinal Digital Watch
There is a "Contact Us' page on their website. Perhaps you can ask them directly:
http://www.cardinalwatch.com/
choose english, then 'Contact us' tab. Make sure you state the model of your watch so they can help you better.
May 27, 2008 | LogoArt St. Louis Cardinals Wrist Watch
Can't set time on a 2 button armitron watch
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Armitron says if the model is not listed on their site call them 718-784-0700. I did and they promptly e-mailed me PDF.file instructions for my M516 watch. - David
Mar 10, 2008 | Watches
Cardinal Airlife Brand Misty Max 10 Disposable Nebulizer W/aerosol Mask 7" Tubing Logo
13,340 people viewed this question
Top Cardinal Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Cardinal Health and Beauty Expert? Answer questions, earn points and help others
