Question about Dell 3300MP Multimedia Projector
No lit / projected image even with a new bulb!
When I power on my 3300MP, only the display on the unit lights, and states "warming up" and flashes "3300MP" for a few minutes. No light is projected. Eventually, orange light comes on and says "Lamp Failure." This also occurred after purchasing and replacing with a new 3300MP bulb. Any ideas? I have a feeling it is hardware and I might be out of luck, since warranty is expired. Unit only has about 100 hours of use. Thanks for your help and time!
  • Just Me Too Feb 04, 2008
    We replaced the new bulb with another bulb we knew to be working. Same issue. Based on another posting, I did take about the projector to look for loose circuit boards. No luck.
  • Stephen Foster Apr 07, 2008
    I also have the same problem - bulb replaced and still does not work - any further suggestios for a fix other than visit e-bay or buy a decent projector in the first place
  • 3 Answers
The voltage lamp board is bad
Posted on Apr 15, 2009
Let me add...
I had one 3300MP and removed/replaced the bulb to dust off as it was overheating. There is a small metal like switch that resets the bulb replacement (physical switch - take a good look) -- This helped to reset the first time I did this, but doesn't reset the hours on the chip.
However, since this bulb was problematic for me, I have done this a couple of times and since has stopped powering the bulb now. So, thinking it was the bulb, I replaced the bulb, -- No good... So, thinking it was the projector, I bought a new/refurbished one on ebay -- tested the NEW bulb - NO GOOD. now I have TWO PROJECTORS, THREE BULBS and NOTHING THAT WORKS...
WHAT AM I DOING WRONG?
Posted on Feb 20, 2008
Wish I knew! I have the same problem on a 3400mp.
Posted on Aug 02, 2008
Check engine light
93 ZJ 5.2L grand cherokee.
FSM real. USA.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
click emissions
see page 25-3 for flash codes.. its there. for your jeep
the Diagnostic is activated by fast ignition key cycles ,stated there.
in 5seconds.
next slide down to wiring. in the window. above.
page 8w-40-4
CEL lamp' schematic pin C2-6 blk/LG color
see the trip switch, this is the silly leaded fuel trip timimer
best i can tell this jeep has the CCD buss
the CLuster is stand alone processor. it communicates
from PCM to the Display VIC. the VIC glows the lamps.
Or has the GDM display, there are 2 options.
BASE graphics display module or VIC option.
ah page 8e-4 tells you the CEL is not hardwired lamp.
it uses the fancy back light display.
so do the key flash trick so see the display show CEL flash codes.
my guess, all this is in the log lost operators guide too.
Jan 02, 2014 | Jeep Cars & Trucks
Lamp error light new lamp
your new bulb may be bad use bulb replacements,com I got a bulb from hem fo r my60" toshiba $125 ups inc. and only had to tke out 6 screws but now im getting white dots
Nov 20, 2012 | Optoma Dmd Projection Display Dlp...
Hello.... Samsung HL-P5063W Lamp LED blinks approximately 35 times followed by 1 long standby/temp light blink After this all 3 lights remain lit and flash....lamp/standby and timer makes a loud humming...
Sound like ur tv have two problems.The "lamp"LED light flashes,mean ur tv need a new projection bulb.The loud refrigerator sound,mean the tv colors wheel is dead,it spinning off of it axes motor.Hire a tv repairman to do this the colors wheel is hard change,because require take out many machanicals parts even to get to the colors wheel to change.The bulb is easy replaced,but he there pay him to put new one in.
May 26, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
We have a Panasonic PT-50LC13, the buld died and the unit would no longer light up. We replaced the bulb as noted and the unit still won't light. Do we need to reset something so the unit recognizes a new...
hi I just read that this tv needs a few minutes to warm up i am going to .try it. iam having same problem. i had a tv tech install a bulb and it worked .
but i had a dispute with the tech about the cost of the fix and he took out his bulb and all though i purchased a new housing with bulb in it so that i didn,t have to touch the bulb, when i put it in i got nothing but green to flashing red to yellow. so if my bulb is good and the tech didn't
do something malicous than something has to be reset so that the tv will work because not even the sound of the tv worked.
if you get the ansewr to this please email to kjohnson838@aol.com
Oct 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Nothing displays on screen
the bulb maybe burnt out, I had a similar problem only no audio. The odd thing was that the lamp light was not lit indicating the bulb was burnt.
Dec 01, 2008 | Sony KP-51HW40 51" Rear Projection...
Dell 3300MP Projector
my advise is to get a new one or try ebay - i got my dell 3300mp NEW in box for under $400 - and have looked at other projectors there are very good deals on ebay but make sure you read the entire listing
Sep 13, 2007 | Dell 3300MP Multimedia Projector
Same problem as this poster
i had a similar problem and it ended up being the bulb. The indicator light never lit up but after i replaced th bulb I checked to see how many hours where on the bulb and it was over 8100. they state the bulbs are only good for 6000. when i replaced it ($140 on ebay) everything was fine.
Sep 09, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Dell 3300MP Multimedia Projector Logo
967 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
