Question about Intel Motherboard
Wiring connections I have and intel rg82845e motherboard and need to know all wiring connections for power switch etc I had to switch cases and and do not have wiring diagrams that are that indepth
  • bear696 Dec 29, 2008
    thank you but did not find anything I hadnt seen still nothing
    President:
  • 2,692 Answers
Here is the website to find and download a manual which will have the wireing contacts on the board identified.
http://downloadcenter.intel.com/NotFound.aspx?NoMatch=rg82845e〈=eng#
Posted on Dec 29, 2008
Installed mother to new tower case and pwr sw | hd led | reset | power led connecting to my board is the Intel dq67sw 155 matx motherboard need accurate dir to connect these please help
info found at http://downloadmirror.intel.com/19707/eng/DQ67SW_ProductGuide01_English.pdf
Front Panel Header Pin info for DQ67SW. They should be color coded too. 1 Hard disk LED + orange
2 Power LED+ green
3 Hard disk LED - orange
4 Power LED- green 5 Reset Switch - blue
6 Power switch + red
7 Reset switch + blue 8 Power switch - red
9 Power Out (do not use)
10 No pin
NOTE When connecting individual wires from your chassis front panel to the front panel header, be sure to observe the connection polarity. Positive wires are usually solid color and negative wires are usually white or striped.
There is also an alternative pin header if you have a power wire that uses a 3 pin connector instead of a 2 pin connector. It is the 3 pins just past pin 9, and it should be missing the pin in the middle of the 3 pin block. The pin closest to pin 9 is the power led + and the furthest from pin 9 is the power led -.
if you need clarification, check out page 50 of the manual posted above at intel.com
Aug 23, 2011 | Computers & Internet
How to connect led wires like HDD Led,POWER Led,POWERSW, RESETSW...........................etc
Your cases installation manual will have a pinout diagram for you to use when connecting these pins from the case to the motherboard.
This diagram is very important as the connections differ based on the model of the case itself in many cases.
If you can't find it, search the model number of your case on google and see if you can find the installation manual on the manufacturer's website.
Dec 20, 2010 | Intel Motherboard
Unable to find the power switch to connect to
If you no longer have the manual for you're Intel D815EEA motherboard, open the link provided and download it; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=17793&ProdId=385&lang=eng
You will also need Adobe reader installed to view the manual; http://www.adobe.com/products/reader/
Read over pages 65 to 68.
Once completed turn to page 68 Figure 23. Front Panel connectors. Figure 23 shows two views.
View - (left figure), shows J9C1 as you look down at the front panel pins. The right figure will not be needed. Connect each jumper or each pair as shown.
Wire colors are important and do vary from case to case. The common color of each pair will most likely be used for negative. Wire colors such as blue, light blue, green, light green, red and light red are commonly used as positive.
Pin 1 will be positive and pin 3 will be negative. This is letter - C. Hard drive activity LED.
Pin 2 is positive and pin 4 is negative. Case power LED, and so forth.
As mentioned on page 65, the case front panel pins use 5 volts DC. If you make a mistake and place a jumper backwards (No LED light), just power off the switch on the back of the power supply and correct the jumper by turning it 180 deg. If you’re case’s LEDs do not light up than you will need to connect letter G and letter H. The electronic circuits under the motherboard should supply all 16 motherboard pins with the 5 volt DC and ground needed.
Cheers'
Mike
Feb 28, 2010 | Zerus Intel Desktop Board D815EEA...
Get no power with intel d875pbz in rosewill tu155 case
You don't have the power switch connected where it belongs. There's one set of pins where all the front panel connections go. This information is from the manual for this board, available from Intel here.
Hope it helps. Thanks for using Fixya!
Feb 12, 2010 | Intel D875PBZ Motherboard
I have a d845gvfn intel motherboard. wires at bottom beneith the battery were pulled out...wich one goes where?
I'll help you with this issue but it is advised you download the manual for the Intel D845GVFN MB. The manual is in pdf format. You'll need Adobe reader to view the manual. Adobe reader is free. Open the link for Adobe, download and install it; http://www.adobe.com/products/reader/
Provided next is the manual link from Intel; http://downloadmirror.intel.com/15211/eng/D845GVFN_ProductGuide_English.pdf
See page 11, Item O. See page 12 for description. (Auxiliary front panel power LED connector). If you setup the Front Panel Header as shown on page 31 item C. You shouldn't need to connect item D, Alternate power LED. If you're board does not power up than do connect item D.
Pin one should be positive and pin two should be negative. The wire colors define + and -. Wire colors do vary from case to case. Normally colors as red, blue and green are found to be positive. The color white and black are common for ground -. Check item C. You'll find a common color for each connection. This common color is ground.
On the odds if after you connect item D fails you can switch off the PS and switch the connectors. Item D and C use 5volt DC. A few seconds in the wrong position will not damage the motherboard.
Good luck
Mike
Jan 09, 2010 | Intel Computers & Internet
On/off switch
Usually the power on button only has two wires. Then you have HDD led leads, reset leads, power led leads etc. These are all separate wires that fit onto separate pins in the Jpanel1 (front panel header).
Could be that the really old emachines grouped all these wires and made them into a plug to fit their own style motherboards.
If this is the case then that connector would not be on your newer motherboard, and it would have that Jpanel1 instead.
Hope this helps as I'm not very familiar with the old emachines.
Hank
Jul 08, 2009 | Intel Desktop Board D815EFV (BOXD815EFVLU)...
Need help wiring Intel Desktop Board D915PGN motherboard
Here you go. Address this manual for your system board from Intel's site, checking and double checking your connections.
http://download.intel.com/support/motherboards/desktop/sb/c6413602_en.pdf
Most commonly it is a disconnected CPU Fan or Chassis fan.
Let us know if you need more assistance, we shall continue to help you troubleshoot.
Apr 17, 2009 | Intel Desktop Board D915PGN - Motherboard...
Connecting front panel wiring to INTEL 845GRG Motherboard
Hello davideiker1, the Intel D845GRG MB manual is shared with another Intel board. (D845GBV MB). Go to this Intel site & download the D845GRG manual; http://support.intel.com/support/motherboards/desktop/d845grg/sb/cs-008873.htm You'll need Adobe reader to view the manual. Download Adobe from this link; http://www.adobe.com/products/reader/
See page 9 for motherboard layout.
The front panel connectors are shown on page 68, see item C.
On page 69 is, Table 31 shows the pin assignments for the front panel header. Front Panel Header (J9G1).
Pin 1 is power for the hard disk drive led, pin-3 is negative for the hard disk drive. Wire colors coming from the case are important. Look at all of the front case wires. The common color for each 2-pin connector will be ground. In most cases the ground wire is white, except for the internal speaker. Ground for the speaker is normally black. (This motherboards speaker is built into the MB, no hook up is needed).
Pin number 2 is positive for the case power led which lights up as green. Pin 4 is negative for the power led.
The reset switch is a bit different. Pin 5 is negative & pin 9 is positive, however if your case uses a two pin connector than connect pin 7 as ground & pin 9 for positive. The On/Off switch, pin 6 is positive & pin 8 is negative.
If this manual is not what you see on the MB, please advise.
Good luck davideiker1!
Need more information/questions post here.
Thank you for using FixYa.
Input, comments are welcomed.
Mike
Jan 22, 2009 | EliteGroup P6SET-ML Motherboard
Compaq pc intel core 2 duo
So you put your old hardware into a new case? If it worked before it should work now unless you added some hardware. The first thing I would do is check all connections, cables. cords etc. Make sure everything is secure and connected properly. Make sure all PCI, AGP etc cards are seated tightly in their slots. Also double check that the wires from the face plate to the motherboard are connected properly. In other words go back and check everything you touched when doing the switch between cases. Hopefully you will find something loose or not connected properly that is causing this problem. Also did you change power supplies using the one that may have come with case. Check that too. Once I connected the power button to the re-set pins on the motherboard. Every time I pressed the power button it wanted to restart. So it could be something that simple.
Jan 06, 2009 | Compaq Presario 5000 PC Desktop
How to connect front pannel
How about a picture? Pg. 46 in your manual.
Need manual, download from Intel. (Click on link).
http://www.intel.com/support/motherboards/desktop/RC440BX/sb/CS-013608.htm
Intel RC440BX Specification
Pg. 46
Basic rules case wiring. The color black is considered ground -. Power wires + can be any other color including stripped wires. (This is standard but case Mfg change to their own specification).
Pin 1 is + power for LED Hard drive green LED, Pin 2 is -/ground for Hard drive LED.
(Pin 3 is + power for LED Hard drive yellow LED, Pin 4 is -/ground for Hard drive LED).(See more options on pg. 47).
Pin 5 is + power for case On/off button, Pin 6 is -/ground On/off button.
Pin 7 is + power for Reset Switch, Pin 8 is -/ground for Reset Switch.
Once positive & negative pins has been located each connector follows in suit.
The Intel RC440BX front case connector is in an odd location.
The user will find it hard to connect front case LED connectors while the board in installed into the case.
Good Luck!
Mike
Apr 25, 2008 | Intel Desktop Board RC440BX...
Intel Motherboard Logo
132 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
