Question about Suunto D3 Free Dive Wristop Wrist Watch
Reseting suunto d3
My suunto d3 keeps on reseting and reverting to time mode as soon as i pass about 1 metre i managed to get it to work once by removing the battery but the problem has not been stopped?
2 Suggested Answers
  • 183 Answers
SOURCE: Suunto watch keeps resetting itself. Changed
You wouldnt think a whole lot could go wrong with a Suunto battery change. If they had trouble getting the coin access back off and unscrewed the case then the button contacts might be out of line causing your problem. You might also check to be sure that they put the right battery in and that there are no pry marks as sometimes there are problems getting the battery out. If any excessive pressure was placed on the circuit board and it cracked it will need to be replaced.
Posted on Sep 22, 2009
My suunto vector keeps going back in time?
Dear William,
there must be a problem with energy (not enought) or too thin battery (did you exchange it latelly) - loosing contact when you schock the watch.
Let me know when you check this...
David
Jul 16, 2012 | Suunto Vector Wrist Watch
I received my suunto t3d black watch yesterday and accidentally set the contrast too high and it saved. I've tried everything but can't seem to find the setting to fix it. I've even removed the...
To reset contrast on the sunnuto t3d hold down all 4 corner buttons at once, this will place the watch in sleep mode. Wait a few seconds and press any button to wake the watch back up. This will allow you to run through the inital set up just like when you got your watch, alot of your info will be saved so you can just quickly confirm them with the mode button. I also set my contrast too high, I have reset it to 3 and found it much easier to read in all lighting.
Aug 13, 2011 | Watches
I replaced the battery as I have many times imy 2005 suunto s6 watch, but this time the display remains blacked out...none of the buttons work or make any noise. The battery is a 2032 and is brand new.
Tough one but here goes. 1 New battery does not necessarily mean good battery 2 Determine the battery is inserted with the correct side up. 3 Is there a reset. Possibly a small hole that you poke a paper clip into. 4 Try holding all the buttons in at the same time for a couple seconds 5 Go see a watchmaker,
good luck
Mar 10, 2011 | Suunto S6 Wrist Watch
Cannot open the battery compartment on my suunto x6 without breaking it....any ideas?
  • Turn the Suunto over to view the backside. Insert the quarter in the coin slot located on the battery compartment cover. Turn the coin counterclockwise to the "Open" position marked on the back of the case.
  • Remove the battery compartment cover. Remove the old battery from the battery compartment. Make sure the o-ring and all surfaces are clean, dry and not damaged. Do not stretch the o-ring!
  • Place the new battery into the battery compartment (negative side down, positive side up). Make sure the o-ring is in its place, as to keep the Suunto waterproof. Place the battery compartment cover back onto the backside of the watch.
  • Insert the quarter back into the coin slot and turn the coin clockwise to the "Close" position marked on the back of the case.
  • If this doesnt work take to a jeweler who has tools.
    Jewel
    Aug 31, 2010 | Suunto X6 (black) Wrist Watch
    T6C failed after working OK for 1 day
    Try re-pairing the belt pod with the wrist-watch computer. Below text comes from page 37 of the T6c users manual.
    If you replace the belt battery or are having troubles with the signal reception, you need to re-pair your belt with your Suunto t6c.
    To re-pair the belt:
    1. Remove the belt battery
    2. Push the (new) battery into the compartment positive side down.
    3. In your Suunto t6c, enter the settings menu and enter GENERAL.
    4. Scroll to PAIR with [Lap +] and [Light -] and enter with [Mode].
    5. Scroll to HR BELT with [Lap +] and [Light -].
    6. Activate pairing with [Mode].
    7. Put the battery in with the positive side up and close the cover.
    Dec 13, 2009 | Suunto T6c Heart Rate Monitor and Fitness...
    I'm trying to reset the altimeter and sea pressure but the watch. I've followed the instructions but the watch more often that not reverts back to default settings or does not respond to the calibrations...
    http://www.suunto.com/en/Products/Outdoor_Sports_Instruments/Suunto-Vector/Suunto-Vector-black/#Manuals
    If you continue to have problems with your watch, and the instructions in the user manual don't resolve your problem, you may have to return the watch to Suunto.
    Your watch must be registered with them, you'll need the serial number of the watch, which is located on the back case. You'll have to get an RMA from Suunto in order to send it back to them.
    Here's their warranty info: http://www.suunto.com/en-us/Support/Warranty-information/
    Oct 11, 2009 | Suunto Vector Wristwatch
    Suunto watch keeps resetting itself. Changed battery a few weeks ago and now in the last week, it will reset itself. After you set it to the right time it could be fine for hours or minutes before it...
    Sep 22, 2009 | Suunto Vector Wristop Computer
    Suunto D3 Free Dive Wristop Wrist Watch Logo
    71 people viewed this question
    Top Suunto Watches Experts
    Ansel Alberto
    Ansel Alberto
    Andrew Taylor
    Andrew Taylor
    Are you a Suunto Watch Expert? Answer questions, earn points and help others
