Question about IBM X236 Server
In IBM x236 server, one swap drive amber led is blinking
And how can I replace it. Please suggest me.
Srinu
  • Anonymous Feb 18, 2009
    display driver for x236 IBM server in linux
  • Teis Thomsen
    Teis Thomsen May 11, 2010
    do u have installed raid5 or mirror?
    can u hot swap?
    /Teis
  • 30 Answers
Please check how the disks are configured?
If mirrored and second mirror is avaliable you can
replace the disk. (It is the same if the raid5 configured.)
You can download the Hardware Maintenance manual from ibm to
help you in the disk replacement process:
ftp://ftp.software.ibm.com/systems/support/system_x_pdf/25k8114.pdf
Posted on Jan 04, 2009
I tried installing windows server 2008 on my Ibm x236. after the installation completes when the system reboots I'm getting error msg. file: \windows\system 32\drivers\wdf01000.sys
that is a Western Digital driver file......for your hard drives likely.
If you are using RAID, then make sure that the RAID is the correct one, and if not, then make sure in the BIOS, you have NOT selected a RAID option.
If those do not seem to be at issue, then attempt to boot in Safe Mode with Networking. That error has been known to have other driver(s) unrelated to the WD driver.
Nov 04, 2014 | IBM X236 Server
One of RAID drives has failed and needs to be replaced for x236 server
I agree with paulo2, depends on what is your disk configuration.
Jul 30, 2012 | IBM X236 Server
Yellow light shows in hdd of server
This means that HDD is faulty . You can confirm it by re fixing the hard drive .
Shutdown computer > Remove HDD > wait 1 min and Insert it > Start computer .
If you get any of the below status
Steady Amber (Orange Led) = Drive is Faulty
Amber Blinking = Hdd rebuilding
If orange led blinks , it means hdd is in rebuilding state. Wait for sometime and check if it come online . On the other hand (Steady Amber) its time to replace HDD
Good Luck
Apr 26, 2012 | IBM x3400 Server
My server ibm x236 do not accept dvd i have try lg dvd patallelata e nec dvd pparallelata the system read only cd.
Silly question, have you ensured that it is a DVD drive on this unit, I believe it is only a CD drive, this can be replace with a standard IDE DVD/CD Unit
May 11, 2011 | IBM X236 Server
X3650- 7979 hot-swap SATA HDDs are not working.
Welcome to fixya
Please refix the HDD if RAID is cofigured on server. Check if it blinks . If it starts blink then its rebuilding. If it gives steadyOrange amber then it shows hdd is bad and you will have to replace.
Before that please login to the raid controller ( Press the key it says soon after controller booting )
From controller we can confirm whether a hdd is faulty or not .
Thanks.
Apr 21, 2011 | IBM x3650 Server
Exclamatory mark led glowing in amber on the front panel It is IBM server 3400
Welcome to fixya
Amber led glows when server met with hardware issue. You will have to run the IBM DSA tool inorder to find the hardware that has issue.
Thanks
Nov 16, 2010 | IBM x3400 Server
IBM X236 server will not power on, the AC light on the back of the server is Dim, the DC light most of the time is off though now and again it will go on and then off 2 or 3 times a second apart from each...
We just ran into this same problem with our x236 this past weekend. After some research we replaced the power cage, but same problem. It appears to be a problem with the PSUs. We moved one of the PSUs to another x236 that only had one PSU in it. Both AC and DC lights lit up, but when we pulled the first PSU, the suspect one could not keep the server running. After opening up both PSUs, I believe it is a problem with the 3 - 1800uf/16v capacitors. I have replacement caps on order, and will know for sure after they are replaced.
Oct 26, 2010 | IBM X236 Server
Firsty my ibm x 236 server is showing 162: configuration error than Re-=booting due to unexpected NMI at F000:FF54
XSERISE 235 TYPE 8671J
1,NO VIDEO,NO BEEP
2,PCI-X SLOT5 POWER LED ON BUT IT HAVE NOT BEEN ABSENT
Jan 20, 2010 | IBM X236 Server
Its not booting and the Leds VRM and NMI are with amber color
VRM and NMI lights lit usually indicate an issue with CPU #2's VRM which can be replaced. Also check 5 lights on back middle of system. If VRM light is lit here remove CPU 2 and VRM and reboot system. If system boots, this was the issue...
Apr 25, 2009 | IBM eServer xSeries 346 8840 (884022U)
IBM X236 Server Logo
944 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
