Question about Veo Advanced Connect Webcam
Video is not coming across on either system...
Installed Veo on my PC with no problem! I get sound thru computer speakers both directions but NO picture. Other user has a MAC and is utilizing AOL. I've opened up a screen name; which brings the vocal thru...what can be done to get the visual on both sides?
    President:
  • 8,637 Answers
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 12, 2009
I plugged in my Altec AP3 Speakers to my computer running windows 7. It does not play. i get sound directly from my PC (it had sound prior to plugging in speakers) however the Altec speakers have no sound
Hello
You haven't specified from which computer source you connects this device with. If it is from the audio out socket of the PC, your PC's audio card [or onboard audio] dirive hasn't been installed yet. Unlike WinXP, Win-7 haven't all driver software in its driver cab when it is installed. If onboard sound should energize, the mother board CD should be loaded. There is audio and video drive [normally NVIDIA] drive should be installed. Anyway, you have to install the dirve. Now it disabled. Go to the hardware confujuration of your system, and look whether onboard audio is disabled. If it is disabled, inable it. If there is no driver installed to it, the system will ask CD. Then insert the CD into the CD tray, and follow the instructions. If your Win-7 is registered, you can get diretly into Microsoft site, and can download the driver needed. OK.
Jun 03, 2011 | Altec Lansing ATP 3W Computer Speakers
I have a new PC with Vista installed. BA 745 do not work.
check to make sure you have the speaker icon in the bottom right hand corner. If you do, see if you can move the sound bar up and down. This will verify that you definitely have the right sound drivers installed and they got installed properly.
Make sure you have the speakers connected properly. Here is a setup poster to show you how. Follow this just to be sure
http://supcontent.gateway.com/support.gateway.com/s/SOUND/speakers/7003709/700370935.jpg
Once you verify this and the sound still doesn't work then it could be a problem with the speakers or the sound card or sound chipset (if you have integrated sound on the motherboard).
To verify whether its the sound card or sound chipset on the motherboard or whether it could be the speakers. Put the speakers on another machine that you know has the sound drivers installed and turn up the sound bard in the operating system thru the speaker icon. If you get sound then its a problem with your other computer. If you still dont' get sound then the sound speaker system is bad and would need to be replaced.
Jan 14, 2010 | Boston Acoustics BA745 Computer Speakers
No audio from pc connected using hdmi
Are you not getting audio to the television speakers and the onkyo reciever speakers when connected HDMI thru the reciever or just the television. If it is just thru the television then it is because the reciever is grabbing the HDMI audio signal and converting it so it does not reach the TV. If it is both then try changing the HDMI signal output from PCM to DOLBY DIGITAL on the computer. Your reciever may not be able to process the PCM signal of the computer. Does the reciever show a PCM or DOBLY DIGITAL display when HDMI is hooked up to it?
Oct 03, 2009 | Onkyo TX-SR606 Receiver
No sound from speakers
Ok newer monitors come with a HDMI connector and would need a compatable HDMI video card that has the ability for sound. The older monitors have a 3mm plug like a head phone jack you can plug this directly into the GREEN portion of the sound card that is installed in your system!
Thanks please rate
May 02, 2009 | HP Compaq W17q Monitor
Speakers connected to the flat panel won't work
Don't Connect them to the Monitor Directly.
It will Be easier for you to Connect them TO THE SOUND CARD (back of computer).
Apr 20, 2009 | Dell ADA745 Computer Speakers
Just installed VEO - Error Meesage
Have you set cam up to with skype
Audio Settings
Jan 18, 2009 | Veo Advanced Connect Webcam
I have a veo web cam installed and have an account with AIM instant messanger. I am having trouble getting my veo to show video during IM chatting.
Normal 0 AIM (AOL) Messenger
  1. On the VIM sign-in window click on Edit.
  2. Then click on Settings Enhanced IM.
  3. Next click on Enhanced IM.
  4. Then click on Audio Video.
  5. The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone Speaker
Camera The audio and camera should function now.
Additional info to use with VIM settings.
Adjust Your Audio and Video Settings: In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
Notes:
  • The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
  • images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Jan 01, 2009 | Veo Connect Webcam
Sound
A. Skype Setup:
B. Yahoo Setup:
Dec 24, 2008 | Veo Connect Webcam
I have no sound
Download The Driver from this link and save the file into the desktop :
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R94481&SystemID=DIM_CEL_3000&servicetag=&os=WW1&osl=en&deviceid=2430&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=1&libid=3&fileid=122481
After Download, double Click on the the file and just follow the on screen prompts to install the Driver than restart the computer. If still there is no sound coming out of the speakers. The problem should be on the physical connection of the speakers to the system. Check the speaker connection and make sure the cable is plugged in to the right audio port at the back. If you are not sure where to plug the speaker cable, play a music and try each port. (Make sure that the speaker has power as well - Applicable for speakers with power adapters).
Oct 28, 2008 | Dell Dimension 3000 PC Desktop
Veo Advanced Connect Webcam Logo
Top Veo Computers & Internet Experts
micky dee
Lyle Siemens
Lyle Siemens
Are you a Veo Computer and Internet Expert? Answer questions, earn points and help others
