Question about Akai LCT3201AD 32 in. LCD Television
Power Supply I have the MLT169A power supply that has the 3 caps in the upper middle of the board. All 3 are raised on the top with a hint of brown stuff on them. Do you repair these? Thanks, Dean mobil1@fidmail.com
  • 3 Answers
I fixed my Akai LCT3201AD in about 30mins. using 3 small parts from Radio Shack. Once I got the back off, I found the power supply board (PSB), mine was part# MLT-169B rev1.2. I looked at the capacitors (caps.) first, because they are usually easy to diagnose. I noticed the caps. bubbled out on the top of the board (where all the cables connect to it). There is 3 of them in a row, positioned between the two large heatsinks. My guess is that the heatsinks are generating a LOT of heat over time, because of bad ventilation, and causing the caps. to fail.
I went to Radio Shack and found 3 caps. (only had 3 in stock). The original ones were 16V-1000uF, Radio Shack only carried 35V and 50V in the 1000uF caps., so I bought the 35V ones and headed home, I removed the old caps. from the board, and installed the new ones. The 35V caps, are a little bigger, so its a tighter fit on the board, be careful. It took longer to remove the back from the TV than it did to do the soldering. YouTube.com has excellent videos on how to de-solder caps. on PSB's.
Total money spent on repairs:
$1.59 ea for 3 Caps. (part# 272-1032) $4.77
$2.99 for new soldering iron tip + $2.99
$1.00 donation for St. Jude's + $1.00
Total including tax $9.30
So for less than $10, I did a repair that my local TV repair shop wanted $575 for. Online stores want anywhere from $100-$275 for a PSB. If I get another 2 yrs out of it that's well worth $10.
Posted on Dec 31, 2008
Yes, those need replacing.
Posted on Jan 07, 2009
Lg 47 ld500 lcd tv wont power on
Not likely as you are hearing the main power relay click and it is after the fuse.
First place to look will be the power supply board inside the set--look for puffed up caps and or check voltages etc.
5_3_2012_2_44_29_pm.jpgcaps should have perfectly flat silver tops with no puffing up on top and no brown material leaking top or bottom.
May 03, 2012 | LG 47LD500 47" LCD TV
My 47Lf85 screen keeps rolling after being on for five min takes longer and longer to settle
You have a part or connection causing this----I would first open set and examine the filter caps (look to see if any are puffed up or leaking brown material on top) in the power supply for the set=follow power cord inside to the power supply board.
This is more common in sets one or two years old.
The caps (see photo) have a silver top which must be perfectly flat with no sign of puffing up on top or any sign of brown material at top or bottom edge.
Let me know if you have questions.
Mar 24, 2012 | Televison & Video
Technika stuck in standby
The standby power supply runs 7/24 and may be part of main power board.
Follow power cord inside to power supply board and as first step examine all the filter caps on it---silver tops should be perfectly flat and not puffed up or leaking brown material top or bottom.
This is the place to begin---see photo of typical cap.
Mar 21, 2012 | Televison & Video
My Samsung LCD model number LN-S4041D takes up to five minutes to come on, it keeps cliking or cycling like it wants to power on. I puchased this TV January 2007. Thanks Greg
This is acommon fault in the power supply - replace 2or4 capacitors 1000uF 10v withe 1000uF 16 or 25V.They are located on the main power board (middle board on chassis )the caps are located upper right of that board and they appesr bulged at the top (compared to the others near by) Caution Some of the larger caps may still hold acharge.
Oct 04, 2009 | Televison & Video
Power supply
Its possible that it is the power supply. If you wanted me to take a loot at it I could but you would need to remove the power supply from the TV and ship it to me. The power supply has been a common fail point of TV's, VCR's and other home electronics in the past several years. Let me know if this is something you would like to discuss further. I just need contact info.
Dec 29, 2008 | Akai LCT3201TD 32 in. LCD Television
I have a 32" HD AKAI TV that keeps turning itself off
If the service shops didn't charge people $200 to fix this I would not post.. But since they do - here's the $8 fix.
If you are electronically inclined, replace the three 1000uf 16v electrolytic capacitors in the power supply board located above the power switch. They are likely bulging out at the top and failed. They are the three in a row at the top - center of the board, located between the two black heat sinks. Make sure you get caps rated for 105c degrees! I recommend replacing them with 1000uf 25v caps. 35v caps will work but might be a tight fit as they are larger diameter.
Should cost you about $8 for the parts shipped. You can get them from partsexpress or digikey or any good local electronics store. Your local radio shack may have them but they won'y be 105c and thus may not last long.
Not handy, ask around, there is usually some electronic tweaker guy around that will install them for a few bucks.
This has solved the turns on / then off problem every time in the 3 I've done.
Oct 10, 2008 | Akai LCT3201AD 32 in. LCD Television
470uF capacitors
The 470uF/25V Caps are in the middle of the PCB alongside of the slab-looking aluminum heatsink. You should be able to see that the tops are popped up and the glue around them is brown from overheating.
Jul 21, 2008 | Philips HTS3450 System
Akai
There are reports that the power supply has dry o leaky capacitors. If you open the TV you will see the power supply # MLT169A.
I have fixed a few of this power supplies.
Apr 09, 2008 | Akai LCT3785TA 37 in. LCD HDTV
Akai lct3201 ad power supply
The MLT169A is a version number issued by MegaMeet in asia who built the supply. The correct part number for the SMPS for that unit is: E7802-005008 and unfortunately they are no longer available... However, there is some good news, those supplies can usually be rebuilt but you need to have the equipment, knowledge to make the repair...
Bill
Mar 26, 2008 | Akai LCT3201AD 32 in. LCD Television
Akai LCT3201AD 32 in. LCD Television Logo
394 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
